Dripping water from the pvc drain pipes of 2nd story eaves.
I have seen these pipes before, but just noticed I have seen these pipes before, but just noticed one of them draining a consistent amount of water, should I be concerned?
    Problem Solver:
  • 12 Answers
Yes, that is your emergency drain pipe. You need to have the a/c drained cleaned out. It is probably jammed up with algea. A professional should be called to blow it out. or get ahold of your Mr. Fixit buddy. If you leave it like this your drain pan will eventually rust out and cause major interior damage to your home.
Posted on May 14, 2009
Dripping from top
all the pvc pipes to the moter home are frozen how do i thaw them out ?
Dec 07, 2013 | Plumbing
Drain inside house from a c is over flowing.central air
I am a certified HVAC Technician. I have worked in the field since 1996. I have seen this hundreds of times, if not a thousand times, in the past. Every central air conditioning and heat pump system comes with TWO drain pans, The MAIN drain pan is located within the AIR HANDLER (blower) UNIT, while the EMERGENCY DRAIN PAN is extremely LARGE and sits under the ENTIRE AIR HANDLER (blower) UNIT. The ONLY time water will be INSIDE an EMERGENCY DRAIN PAN is when the MAIN DRAIN PAN condensate drain line is CLOGGED, causing the MAIN DRAIN PAN to overflow. What causes the drains pans OR the drain lines to become clogged is slime and scale from the condensate water as well as debris from within the attic that may have either been blown by the air or may have simply have fallen into the emergency drain pan; or some insects from the out of doors have traveled up into the PVC Drain line and built a nest on the downward side of the P-trap. The P-trap is designed to prevent critters from entering your home through the PVC drain lines. Most CLOGS occur at the P-TRAP location.
The BEST thing to do is:
1. Locate the WHITE PVC drain pipe outside your house and ensure there is NO water draining from it.
2. Locate the same WHITE PVC drain pipe inside your house. You should notice a "TEE" where two WHITE PVC drain pipes merge into ONE WHITE PVC drain pipe.
Follow the below steps, in the order shown:
A. FIRST, find another person to act as your second set of eyes at the end of the WHITE PVC Drain Line that is located outside of your home. That person will be looking for water or debris to EXIT the end of that WHITE PVC DRAIN LINE.
B. SECONDLY, locate the WHITE PVC "P-TRAP" inside your house. It is normally located within a couple to three feet of your indoor air handing (blower) unit.
C. THIRDLY, very gently lift the entire WHITE PVC drain line up in the air as high as you can without breaking it, and slam it down onto the rafters or attic floor or garage floor. You are attempting to dislodge the CLOG within the drain pipe WITHOUT having to actually CUT the PVC and without damaging or breaking the WHITE PVC. Depending on how old the system is, it may or may not be brittle; and it may not take much to damage or break the PVC, which will cause leaks. So, be very careful at this point.
D. Ask the person outside if anything has started to EXIT. You can ALSO usually hear water start to drain if you put your ear up to the drain line. If the person said "NO"and if you don't see the water level getting LOWER in the EMERGENCY drain pan, then REPEAT step "C" above.
E. If the person informs you that there IS water now starting to exit the WHITE PVC DRAIN PIPE, you should then wait until all water has drained from the EMERGENCY DRAIN PAN; and then pour at least 1 quart of BLEACH down that drain, from the EMERGENCY DRAIN PAN exit. The BLEACH will further clear out any SLIME which may be remaining within the "P-TRAP" and will also CLEAN OUT and DISINFECT that drain line.
If the above steps do NOT work for you, then prepare to go into the next LOGICAL phase of your attack. Please NOTE: I am limited to 10,000 characters in my response, so I'll repost additional STEPS in another RESPONSE. Good Luck!!!
Sep 05, 2012 | Goodman CLQ36AR49 Air Conditioner
I have a new furnace with a humidifier. Both work fine. The trouble is, the water running through the hose to the drain makes a LOUD dripping noise when it runs into the drain. Is there some way to stop...
Not seeing exactly what you have. I am guessing...does the humidifier have a trap on it coming out of the furnace?. Is this some type of over flow from the humidifier? If so...
I would suggest running a 3/4' pvc pipe from the hose coming off of the humidifier and at a point lower than the humidifier install a trap...like what you see under your sink. Come out of the trap and run the solid 3/4" pvc to the drain and put a 90 elbow turned down into the drain. Buy installing a trap you should not hear the loud dripping noise.
I hope this helps you...Jim
Feb 20, 2011 | Heating & Cooling
I have a Weather King AC/Furnace in the attic that's dripping water into the drain pan. When we purchased our new house it came with this unit and it never dripped ater. Now, the water is dripping towards...
I assume it is dripping water when the AC is running. If you look at the attic unit, there should be a PVC pipe running from the unit - probably an insulated PVC pipe. This pipe probably goes across the attic to the edge of the house and drains outside. The drain pan may also have a drain pipe, but the one on the AC unit is the issue, and is probably plugged. Go outside and see if you can locate the AC drain pipe. See if the ground is wet below the pipe and if water is steadily dripping from the pipe (with AC running). If the pipe and ground are dry, the pipe is plugged. If you have a wet/dry vac, try connecting it to the drain pipe outside to see if you can **** the pluggage out. If you can get it clear, water should start dripping out of the pipe. This same thing happened at our house. I decided to cut the pipe in the attic, and add in a PVC isolation valve, tee, and water hose connection with plug, so I can valve out the AC unit from the pipe, remove hose connection plug, and hook up a water hose and flush the line to outside. Lowe's sells all of the PVC pipe fittings. The water pressure from the hose will always flush out the algae and crud to the outside of the house. I can also remove the plug and pour a cup of bleach down the drain pipe every couple of months to keep algae growth in check. I also cut out the trap (u-leg) from pipe in the attic and purchased a ready made trap a Lowes (the contractor who built our house had made a lousy homemade trap). I purchased a few PVC elbows and installed the trap on the drain pipe outside. By the way, our AC drain pipe comes out of our wall outside and drains near our outside unit. Our secondary drain pan drain pipe comes out outside from an eave on the side of the house. I don't know what you drain line looks like (it may have a port to add bleach, or some cleanout provisions, maybe not). If you choose to modify/improve it, then make a sketch of it, go to Lowe's and get the PVC parts you need + PVC pipe primer and cement. PVC cement dries fast. Remember, the pipe must flow downhill from you AC attic unit. You can use a regular wood saw to cut the pipe. I hope this helps you. You need to keep the drain line clear as algae will continue to grow in it. Pouring bleach in the line every month or two helps. You also need to check maybe once a month that the line is draining properly (check to see if dripping outside). You can get some serious water damage to your ceilings if the water backs up and overflows. I discovered that our drain line was plugged just in time as our drain pan drain line was also partially plugged and drain pan was about to overflow.
May 08, 2010 | Weather King 12AJA4201AH Air Conditioner
Hi, Have a situation. My bath tub(2nd floor) is leakinge and water is dripping down to my living area (through the lower level cieling). 1) I ran the water and collected it in a bucket to see if it water...
You will have to bust out the ceiling where the dripping is occuring to get to the pipes. Before doing so, check and see if your house was built with an access door for the valves. (Look on the other side of the wall where the valves are.) I have the very same problem and am going through ceiling replacement after repairing the pipes. It is a mess. Good luck.
Nov 30, 2009 | Lefroy Brooks Bath Waste Trap for Exposed...
Excessive water dripping from Central A/C drian line
sounds like the overflow drain is picking up the water that means the main drain is clogged.you need to find the main drain pipe if lookin at the air handler in attic there should be 2 drains from unit one higher than other follow it and blow out drain they put the other overflow drain out the eve so if it stars leaking someone notices it and it doesnt damage cieling but it sound like it needs imediate attention befor it does go to the overflow pan and damage your cieling. i hope this helps and good luck
Sep 29, 2009 | Amana PTC153B35AJ Air Conditioner
Drain pipe under eaves on second story
Yes. You can buy couplings, elbows and pipes at a hardware store and divert the water precisely where you want it to go. Hope this helps.
Sep 11, 2008 | Kenmore 75085 Air Conditioner
Heating & Cooling Logo
264 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
