Question about Rockford Fosgate Punch 201S Car Audio Amplifier
201s amp isn't working
I have just bought a second hand 201s amp, wired it up and it isnt working. there is power getting to the amplifier as i have tested it with a tester but there is no sound coming out the other side. i am at my wits end and am out of ideas.
  • mnbv Dec 02, 2007
    i hooked up amp and all but the led light isint going on and no sound NOTHING
  • 631 Answers
The meter set to DC volts
The black lead on the ground terminal of the amp
The red lead alternately on the remote and the B+ terminal
You should have read 12+ volts. If you did, and the power light was not on, the power supply was not producing regulated voltage. This is generally due to blown power supply transistors.
Ordinarily, if someone wants to repair their amp themselves, I'll try to walk them through it but this amp requires more than basic skills and tools to replace the power transistors. This is best left to an experienced tech. Try to find a reputable repair shop in your area to have it repaired.
If you can return it, you should do so. Do not remove the back cover if the tamper-evident seals are intact. If you do, the seller will almost certainly refuse to refund your money.
Posted on Oct 16, 2007
I bought a second hand Fishman LoudBox Performer. The problem is that the Aux-in for the headphone doesn't work. So sick... What can I do? tnx
I don't understand your question. The "Aux in" is just that an input that goes to the power amp. Please note that the Fishman Loudbox does NOT have a headphone jack so don't be disappointed as there plain isn't a headphone jack on this unit. I would recommend that you get a small headphone amplifier for the purpose... or even go to a thrift store and get an old stereo system that has a headphone jack and use that.
Aug 01, 2011 | Fishman Loudbox Performer Amp Acoustic
Where does fuse go on punch 201s
there is no fuse for this amp you need to use a cable that goes to the battery that has a fuse
Nov 26, 2010 | Rockford Fosgate Punch 201S Car Audio...
Rockford 201s 600 watt amp turns on but no sound going to the subs and where is the fuse on these?
there is no fuse you need a cable that goes to the battery that has a fuse check you're ground
Nov 02, 2010 | Rockford Fosgate Punch 201S Car Audio...
Need a diagram
you have to take a positive cable with fuse placed near to the battery to your amplifier B+ and a thin wire from the jvc sterei to the amp for the remote REM and an RCA cable for the sound system the negartive wire keep it short as you can and connect it to the chassis
Apr 24, 2010 | Rockford Fosgate Punch 201S Car Audio...
Power/ Ground Problem. Im running a 6ga Power wire to the battery (approx 6')with a 40amp fuse. The amp turns on, then about 10 seconds later blows the fuse. The ground is the same ga wire and is grounded...
1. Start by undoing your ground.
2. Use a jumper cable to hook up the ground to the battery ground.
3. Install fuse and test.
If it continues to blow you have an internal amp problem.
If it fails to blow a fuse you have a problem with the chassis ground.
If it is a ground issue you can chase down the various ground straps and clean the connections or you can run another ground cable to the chassis (body) ground to the battery to reestablish the connection.
Feb 10, 2010 | Rockford Fosgate Punch 201S Car Audio...
No end caps,what are they
The end caps screw on to both ends to hide the cables and wires. Not required unless you don't wat to see any wires in a surface mount type install. Does not affect performance
Apr 29, 2009 | Rockford Fosgate Punch 201S Car Audio...
Can a rf 201s amp push 4-6x9s and 4-104s door speakers
Hello jon_jonmay,
Wiring 4 speakers to each of 2 channels, you will need to wire them series-parallel and run them at 4 ohms. If you wire all 4 parallel, the load will be 1 ohm and the amp is only stable down to 2 ohms.
According to your manual, the 201s will deliver 50 watts into each channel at 4 ohms . So it will be supplying about 12.5 watts per speaker which is about what you get with the average factory radio. They will work OK, but they're not going to be very loud.
Hope this helps.
Apr 21, 2009 | Rockford Fosgate Punch 201S Car Audio...
Fosgate 201s amp, high level inputs... where do i hook these wires....
Hello mhjoubert,
On the Punch 201s, the high-level inputs are located just below the gain control. When used to power a sub, most commonly these are connected to the rear speaker wires of your receiver. If the amp is used to power a set of normal speakers, you would connect them to whichever set of speaker wires you intend to power.
Actually, it's probably a better idea to install a low-level converter on the receiver speaker wires and then use the RCA connections for input. This way, you have better control on the input signal, lessen the possibility of induced noise, and do not need to worry about an impedance mismatch causing problems.
You can download a copy of the Rockford-Fosgate manual here:*&p_li=
Hope this helps.
Apr 11, 2009 | Stingpro ST444 1850 Watts Complete...
Rockford Fosgate Punch 201S Car Audio Amplifier Logo
177 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Level 1 Expert
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
