Question about Frigidaire 36 in.GLGC36S9E Gas Cooktop
Loud whining sound when oven or burners turned on
My gas oven - model fgf326asf is making a loud whining noise. It occurs when I turn the oven on or the burners on or both. My boyfriend thinks its the gas regulator. What do you think and is it possible for us to fix it ourselves? Thanks much!!!! Joy
Amana counter top gas stove when plugged in start making clicking noise and you can smell gas .
on most, your push down and turn to hi to open gas valve and turn on piezio to light burner. it sounds like you have a knob already turned on . the control under the knob may need replacing. kinda an easy replacement if you get new part. check out repairclinic.com for video(maybe) but for parts for sure. be careful. gas is explosive.
Mar 16, 2015 | Amana Cooktops
All 4 electrodes spark when only one is turned on
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 20, 2010 | GE 36 in. JGP628 Gas Cooktop
On our 6 burner gas coocktop, the right two burners don't light
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 10, 2010 | Thermador SGS36GS Gas Cooktop
Spark ignitors went on stove top
Jan 09, 2010 | Whirlpool SCS3014LS Gas Cooktop
Spark ignitors on ge jgp636 either don't work or lght wrong burnr
Dec 19, 2009 | GE Profile JGP636 Gas Cooktop
Viking cooktop gas unit ignition clicks on all burners when I use
Dec 05, 2009 | Viking 37 in. DGCU165 Gas Cooktop
5 burner tappan stove. oven takes a long time to reach 350 and doesnt stay hot also a hissing sound when you first put on, called the gas co. and it wasnt gas leaking. a loud popping sound also
By this description you gave it sounds as your oven burner has a flash back ,when it is like that does your flame look very yellow and gives off a Funny Smell ( which i Will think it is CARBON MONOXIDE . Remove the Oven burner make sure you watch for any wires attached to the burner (yes even in a Gas Stove) that would be part of your safety device . Make sure there is NO Rubbish in your Burner and your Burner
Well . Clean it out Make sure your Injector is Clear Carefully replace your Burner Making sure it fits over the Injector ,Replace any wirer if you removed any and relight
Jul 14, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Clicking sound whenever I turn on a burner
There is no problem. The click your hearing is the spark module igniting the gas. The clicking will only occur while the know is turned to ignite and will stop after your turn the knog to any other setting.
Jun 17, 2007 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Frigidaire 36 in.GLGC36S9E Gas Cooktop Logo
318 people viewed this question
Top Frigidaire Cooktops Experts
Dan Webster
Dan Webster
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
