Question about D-Link / RangeBooster N 650 / DIR-635 / 300Mbps / 802.11n / 4-Port / Cable/DSL Wireless Router (DIR635)
Trying to setup router without cd drive or start menu
We have no CD drive so we cant use the installation wizard. This laptop does not have a start menu either. It is running Unbutu. how can i set up my D Link Dir-615 without using the installation wizard cd?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 75 Answers
Open your web browser. In the address bar type 192.168.0.1 and hit enter. You should be presented with the router's web interface. Your username is admin and the password should be left blank.
Posted on May 14, 2009
  • 2,260 Answers
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Posted on Apr 16, 2010
  • D-Link Master
  • 4,338 Answers
Unplug the modem,router and the computer.
Plug in the cable modem first, wait 30 seconds
Then plug in the router, wait 30 seconds.
Then plug in the computer. The computer should obtain an IP and you should be able to get online.
In Unbutu, you may have to go to network settings and set it to obtain the IP automatically or make it a static IP.
Click on this link. Or copy and paste it into your browser.
If I could be of further assistance, let me know.
If this solves your issue, please be kind to rate it.
Thanks, Joe
    Cheetah:
  • 49 Answers
I have a router model dir 635 that i want to use with a external antenna how do i set this up.
Posted on Feb 09, 2010
Wrt120bn wireless router cd installation
Are you trying to setup Linksys router?
You can run the installation CD to setup Linksys router or you can do it without installation CD also.
Connect the computer to the router with the Ethernet cable.
Open the setup page of the router.
Change the Internet connection settings.
Create a new wireless network.
Connect to the network.
I will suggest you a website that you can try to setup your Linksys wireless router without installation CD.
May 21, 2012 | Linksys Wireless-G WRT54G Router
The router installs fine on one lap but I still can't connect my other laptop
your first option is to go to http://192.168.0.1 Here Select admin from the drop down menu and leave the password field Blank.
Once the page loads youll see a series of options. this is the routers linux interface section. you will see D-link on the top left.
Select the first option Install router.
the steps would be as follows.
Step 1.
Insert the Router Setup Wizard CD in the CD-ROM drive. follow The step by step instructions. Once you done this And i believe you have already. see step 2
Step 2.
Select the Option
Setup on the Top > Internet is on the left side.
Under the Internet connection Wizard Hit the Setup Wizard button.
Step 3.
Now on the Setup page Same place where the setup Wizaed is. just below their is another option called Wireless Security Setup Wizard.
Press the Launch Wireless Security Setup Wizard Button.
Read the 3 steps then click the next button to continue.
Steps for step 3.
1. Enter a SSid this will be the network name you see when you want to connect to your own network. example.. MyHome
2. Select your security option then click next. (For simplicity chose WEP)
3. click apply.and let the router reboot.
when it comes back online you should see your network you just setup. our example was MyHome.
If you are new to router setup. use the Wep security called Good on your routers security WEP. and just write the key it gives you down. this is the code you need to connect your devices and is considered ok for a simple home network.
Nov 22, 2011 | D-Link DIR-615 Wireless Router
Install software without a cd rom drive
Connect an Ethernet cable between the network-port on your computer and one of the LAN ports on the router.
Now, you have a "direct" connection to the web-server that is "inside" the router. Open your web-browser, and connect to the web-server, and then you can run the "Wireless Networking Setup Wizard" to create your wireless network, i.e., pick an SSID and a password, and enable "WPA" (Wireless Protected Access) security.
Now, you can disconnect the Ethernet cable, and you can "find" the SSID that you have chosen.
May 28, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
How to instal printer on dilink dir-888
i 1 D-Link DIR-855 User Manual 0
Section 2 - Installation
If you are connecting the router to a cable/DSL/satellite modem, please follow the steps below:
1. Place the router in an open and central location. Do not plug the power adapter into the router.
2. Turn the power off on your modem. If there is no on/off switch, then unplug the modem’s power adapter. Shut down your computer.
3. Unplug the Ethernet cable (that connects your computer to your modem) from your computer and place it into the Internet port on the router.
4. Plug an Ethernet cable into one of the four LAN ports on the router. Plug the other end into the Ethernet port on your computer.
5. Turn on or plug in your modem. Wait for the modem to boot (about 30 seconds).
6. Plug the power adapter to the router and connect to an outlet or power strip. Wait about 30 seconds for the router to boot.
7. Turn on your computer.
These instruction are on the CD that came with the router
Here is the start:
D-Link DIR-855 User Manual 13
The DIR-855 includes a Quick Router Setup Wizard CD. Follow the simple steps below to run the Setup Wizard to
guide you quickly through the installation process.
Insert the Quick Router Setup Wizard CD in the CD-ROM drive. The step-by-step instructions that follow are shown
in Windows® XP. The steps and screens are similar for the other Windows operating systems.
If the CD Autorun function does not automatically start on your computer, go to Start > Run. In the run box type
“D:\DIR855.exe” (where D: represents the drive letter of your CD-ROM drive).
When the autorun screen appears, click Install Router.
Section 3 - Configuration
Configuration
This section will show you how to configure your new D-Link wireless router using the web-based configuration utility.
Web-based Configuration Utility
To access the configuration utility, open a web-browser such as Internet Explorer and enter the IP address of the router (192.168.0.1).
Select Admin from the drop-down menu and then enter your password. Leave the password blank by default.
If you get a Page Cannot be Displayed error, please refer to the Troubleshooting section for assistance
Click Launch Internet Connection Setup Wizard to begin.
If you want to enter your settings without running the wizard, click Manual Configuration and skip to page 19.
follow the prompts.
You also can go to D-Iink.com for setup instructions
Apr 20, 2010 | D-Link DIR-855 Wireless Router
Install disk says that op system, windows 7, does
Mar 28, 2010 | NetGear WGR614L Wireless Router...
I have been trying to install software for a WD Elelments
just copy all files from the cd into 1 folder, you don't need to copy it on external hard, you can copy it on local hdd. but you can if you want it. find the setup.exe file copyed from the cd and run it.
Dec 01, 2009 | Western Digital My Book Essential Edition...
How to set up wireless router without using installation cd.
type in model details and add driver after them in live search or google and youre sure to find a page which has the software you need.if you dont find anything using word driver then use word software
Jan 12, 2009 | Acer Aspire One PC Notebook
I just bought a D-LINK model WBR-2310 I started following the directions by trying to run the Wizard cd but nothing appears on screen, I did not connect the router yet am waiting for directions from the...
no you don't need SP2, but there is SP3. that would be nice.
anyway, connected the router first. then follow the instruction on the CD. without the router connection the CD is useless.
Dec 12, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Still trying!
To run the setup wizard manually, click Start, then Run.  Click the browse button and select your CD drive. Look for EasyInstall.exe and double click on it, then click OK to run.
Nov 11, 2007 | Belkin (F5D7231-4) Wireless Router
Computers & Internet Logo
1,975 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
