Question about Saeco Talea Touch 14-Cup Coffee Maker
Doesn't start up properly...
I wanted to clean my Saeco Talea Touch today..But after some time I got message "Prime water circuit"" And it starts to make some noice..After a minute or so .I get a tool in the window ."Restart to solve problems."But it doesn't help...
Actually I decided to day to deliver to a service point for Saeco in Warsaw ,Poalnd.
Anyway ,thank's..
Best regards
Johnny
Posted on May 15, 2009
  • Gert Hansen
    Gert Hansen Jan 26, 2014
    Hi Johnny, what was the problem mine have the same fault? Br. Gert
What to do when prime water curcuit comes on
When prime water circuit comes on turn on the steam/water valve may need to select hot water the machine will run water until primed
Nov 16, 2014 | Saeco Talea Touch 14-Cup Coffee Maker
Saeco talea giro flashing red exclamation point
take out the coffee waste bin, on the side facing into the machine, there's a little metal bit, it's a kind of sensor.
Clean it if it's dirty with a screwdriver or some wire wool.
Have you cleaned the brew group lately?
Sep 06, 2014 | Saeco Talea Giro Espresso Machine
My Talea touch plus is struck in the cleaning cycle after a de-scaling.
Normally it drips at the beginning and then becomes a steady stream throughout the shot. The truly determining factor is how fast the shot is coming out. You want to get 2 to 2 1/2 ounces of espresso in 20 to 25 seconds. If it's coming out that slow it's going to be a lot longer, and odds are the grind is still a touch too fine still. Sounds like you need to just tweak a bit to get an even better shot. Also, keep in mind with the Saeco supers, there is a 2-3 shot delay in changes you make in grind before it makes an effect.
Jul 22, 2012 | Saeco Talea Touch Plus Automatic Espresso...
My Saeco Talea Touch machine stopped working this morning after a first cup of coffee. The error code on the screen said Restart to solve the problem (with a wrench key). I restarted the machine but the...
Had the wrench icon problem on a used Talea Touch that I bought.
Don't know how it started with the previous owner.
Solution - cleaned compressed coffee grounds from the grinder discharge. You need to manually spin the motor to clean all grounds from the rotation discharge gate.Also needed to probe and press the electrical connections to the motor. The brush spring and capacitors are press connected.
This solved the problem.
I've owned abnd repaired many Saeco machines. They are poorly designed and over priced.
None the less the majority of their problems can be fixed by simply cleaning the components.
Enjoy
MDR
Sep 08, 2011 | Saeco Talea Touch 14-Cup Coffee Maker
What is message "prime water circuit" not in
Fill the water tract with the water. For example - swith the steamer to hot water dispence and run water for several seconds (untill it goes smoothly).
Mar 18, 2011 | Saeco Talea Touch 14-Cup Coffee Maker
Seaco talea ring plus Q: what i have to do when
Press hot water button and open valve to run the pump.
Aug 22, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Jun 20, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Saece Talea - Dispensing failed
Take out the brewing unit and clean it in hot water.
/Mirran
Aug 30, 2008 | Saeco Talea Touch 14-Cup Coffee Maker
Saeco Talea Touch 14-Cup Coffee Maker Logo
1,658 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
