Question about Sharp AR-5320 Black and White Copier
The copier is giving an error message U6 what does this mean
    New Friend:
  • 91 Answers
It's a communication error between the base machine with the LCC ( Large Capacity Tray ) Try reset by following this step :
Press [#] [interupt] [c] [interupt] [1] [6] [start]
The copier will be reset and hopefully your error code too.
Posted on May 15, 2009
What is u6-6000
Hello, the error U6-6000 (U6-6) CRUM control ASIC has failed
Nov 03, 2015 | Office Equipment & Supplies
What does u6-03 mean?
This refers to the LCC (large capacity cassette) is not lifting the paper. Sometimes the paper can foul when incorrectly loaded & the copier cannot recognise the paper present in the cassette. To reset the error use SIM 15.
Jul 24, 2014 | Sharp AR-M355N Grayscale Copier
We are having xerox 1038 model usa made . we are getting the error u6 when we switch on our machine . so plz suggest us the best possible way to fix up the problem ...`````
U6-1 The main PWB failed checking the ROM.
Shut down and restart the copier. If it appears again U6-1, replace the main PWB.
U6-2 The main PWB failed checking the RAM.
Shut down and restart the copier. If it appears again U6-2, replace the main PWB.
U6-3 and U6-4 The main PWB failed to check the battery MNV (U6-3). Or the main PWB does not properly initialize the NVM (U6-4).
Follow the procedure in the development of memory to initialize the NVM, code 20-96. Shut down and restart the copier.
Jul 20, 2011 | Office Equipment & Supplies
Xerox workcentre 518 gives U6 error whats the issue?
Press 0 button when U6 displayed; If it is U6-0, check control panel connection for proper contact; if U6-1, check paper tray pcb connection to mother pcb.... The paper tray pcb is located at rear side. open back cover and reconnect it.
Jan 05, 2011 | Xerox Office Equipment & Supplies
Error code U6-3
Hello, Assuming this error is persistent and a simple reboot will not clear it. This error means that there is an Memory Error. This might be caused by an improper grounding (earthing) of the machine.
To fix this error, in case the problem is not grounding, parts need to be replaced. So I would advise you to book a visit.
Oct 04, 2010 | Xerox WorkCentre Pro 428 Copier
When i print one document on my xerox docu color 4lp on the printer display's this message "U6-4 Cycle power"
U6-4 sounds like an NVRAM error and could be a bad board.
I think they probably be the Main System Controller Board 160K58571 or the Engine Controller/MCU 160K60530
Whit
Item, Inc.
Aug 10, 2010 | Xerox DocuColor 4LP Laser Printer
My ecosys fs-3900dn printer gives this error 0150:0119695
It is a "mechanical error". The part after the colon is the number of pages printed. It's probably worthwhile taking the trays, toner and cartridge out and opening all the access doors and checking for something obvious before calling in an engineer.
Jul 19, 2009 | Kyocera FS-3900DN Laser Printer
I Have Xerox 5821 Star Copier and it got U6 error. Help me out
U6 code means that you have a problem with the exposure lamp or exposure lamp circuit working properly.Hold down the 0(zero) key while turning the unit on and punch in the codes 20 start 3 this will enable you to clear the code unless you have a permanent problem where a part has to be replaced
Apr 21, 2009 | Xerox 5100 Copier
Phaser 7300 Error Code/Message
Seems to be something to do with the Ram.
More help HERE
Jun 01, 2008 | Xerox Phaser 7300DN Laser Printer
Sharp AR-5320 Black and White Copier Logo
138 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
