Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Panasonic PT53wx53g Rear Projection TV screen cracked
I cracked the protective plastic screen on my TV.  Can standard low glare plexy glass be used to repair the television?
    President:
  • 3,130 Answers
You can try it, but through my experience, it just does not look good. You may not have a problem with it. Give it a shot. Good Luck.
Posted on Oct 16, 2007
Where can I get a replacement plactic screen cover
This set has 3 screens---the outer one is really only for glare--clear plexigalss--no longer available from Sony.
Sony 4-070-602-01
SCREEN, FRESNEL Sony 4-064-343-11
SCREEN, LENTICULAR Sony 4-058-894-11
SCREEN, PROTECTION (CONTRAST)Outer one is (Contrast) the other two inner ones are showing as available and about 180 each.
You would have to either have someone dismantle or do it yourself---most of these sets you have to remove all three screens from the rear of the set---then remove the outer contrast one if it is scratched or cracked--
If you get it out and measure it: It is possible you may be able to find a company who can cut you a plexi-glass piece to replace it with--lots of work to do this and you have to use extreme care when you remove the two inner screens--easy to damage them---Usually the inner two are taped along all the edges to keep dust etc from getting between them and the front one is a short distance forward of them.
The front protective screen is really only there for glare and to protect the inner screens from damage---I have seen people who had a cracked outer one just dismantle and remove that one---put the others back and use the set that way---have to be careful as the inner screens are easy to scratch or damage with the outer one removed.
Also---I have seen several where someone removed the outer one and got a piece of plexi glass big enough to put on the outside of the front of the set---secured all around the edges with velcro--does not look as good as the original but prevents glare and protects the inner screens.
If this told you something you did not know or helped you rate this solution as I do this here for free.
SD TECH
Jan 03, 2010 | Sony KP-53V80 53" Rear Projection...
I have a 51in Toshiba that nees a protective screen.
The plexi glass if a "special formulation" and costs around $350 if available!. I would go to some repair shops and see if they have old junker sets (city dump) that you can get the screen and if you have to cut it to size.. Cheap fix...
please rate!
Mar 11, 2009 | Hitachi 51SWX20B 51" Rear Projection...
Need plexi-glass cover off my mitsubishi hd 1080 projection tv.
the plastic trim pops off and there are screws that hold the glass in place that you have to take out to be able to remove the plexi. it takes about 20 minutes to do
Jan 27, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Screen broken or cracked
you will need to call rca and order one from them
here is a customer service number you can call for more details on how to get the screen
877-794-7977
Dec 10, 2008 | RCA HD52W59 HDTV Projection Television
Broken protective plexiglass ...
it is not tecomended that you remove this especally around children. i say this but i personally have one like that but i have no children. the other reson is the screens are easy damaged and they are 250 to replace. You can get another front plexi these are known as the supersheild. or if you can find the right size plexi glass it might find another option. It can be watched but like i said it will just lead to more problems without plexi
Nov 02, 2008 | RCA HD52W59 HDTV Projection Television
How do I remove the outer protective screen on my Mitsubishi WS-55315?
There are trim pieces around the edges that can be removed by sliding a knife underneath and lightly prying. They should remove fairly easily, don't force them as they may break. Use the knife on the cabinet side and pry toward the center of the screen.
The tear on the inner screen may be best left as is.
lexan would be better than plexi as it is tougher, but try to get anti-glare if possible. Anti-glare plexi would be better than regular lexan.
Feb 17, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Panasonic HDTV 1080i Screen
Usualy Panasonic have 3 layers on the screen. From inside to outside is: fresnel, lenticular and protective. If only the one from outside is broken don't wory. It;s just protective and the film it's just a filter to improve the black level. You can use it like that but be carrefull because the lenticular it's not protected anymore and if you scrach it ... And do not try to clean it with anything else just dry rag.
Dec 10, 2007 | Draper Replacement Surface ONLY for...
Sharp 61R WP4h
side fade is down side of projection tv's
there is no harm other than you have to be careful now.
Dec 04, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
393 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
