Question about Symbol MC5040 Pocket PC
Trigger won't scan
I can connect to the net and am able to scan. When I press the two side buttons the scan feature works. For some reason the trigger won't enable a scan. Can you help me?
    Problem Solver:
  • 13 Answers
Nokia N97 32GB unlocked ( Brand New )
Specifications
* Size: 117.2 x 55.3 x 15.9 mm* *18.25 mm at camera area
* Weight: Approx. 150 g
* Memory: Up to 48GB (32 GB on-board memory, plus 16GB expansion via
microSD memory card slot)
* Display: 3.5 inch TFT with up to 16 million colors nHD 16:9 widescreen
(640×360 pixels)
* Talk time: Up to 320 min (3G), 400 min (GSM)
* Standby time: Up to 400 hrs (3G), 430 hrs (GSM)
* Video playback: Up to 4.5 hours (offline mode)
* Music playback: Up to 37 hours (offline mode)
* Image capture: Up to 5 megapixels (2584 x 1938) JPEG/EXIF (16.7
million/24-bit color).
* WiFi and HSDPA
* DVD quality video capture and 16:9 display
The Nokia N97 32GB is made in Finland and it is the leading phone in the
Market, beating the Nokia N96 16GB and also the apple 3G 16GB..
Nokia N97 32GB is touch screen and is one of the Smartest technology.
Be one of the first to have this phone, We have sample units available for Sale..
Feel free to contact us, we are always online to give you a reply...
NOTE:
If you send us a mail today, we will reply you today.
dialaphonemobile@gmail.com
Posted on May 14, 2009
How do you fix a jammed trigger on the Ryobi 10 Amp Electric Power head
Not really a fix but it worked for me. I opened up the case. Their is a little black box with a red button that must be depressed. Pulling up on the trigger pushes the button. Their is what i call a counter press above the trigger. By pressing it, it makes room for the trigger to slide up and press the red button. There isn't much you can do improve this process. But i took the two springs off the trigger and depressed them trying to shorten them thus reducing the force needed to press. The counter press in spring load. I carefully stretch it by pulling on the end directly above the trigger(not against the frame). This took some pressure off the counter press. I finally took a small file and carefully filed down the edge of the counter press where the trigger presses against. This makes it slide upward easier even if the counter press isn't pressed down fully when you squeeze it. The trick is pressing the counter press first, but doing these things has made my trigger a lot smoother. It use to be a hard press to activate, but now it is 10 times better than it use to be. Good Luck!!
May 17, 2014 | Ryobi 10 Amp Electric Power Head RY15122
Scanner & Printer Features are missing in the system setting.
Print scan card not in unit? ( a SD card on left rear under a cover)
Feb 05, 2014 | Ricoh Aficio Mp171spf Copier,Fax,Net...
Framing nailer won't fire nails
Usually safety foot is not making full contact to trigger mech. First test trigger valve. Remove nails, remove the trigger to expose the trigger firing pin. Connect air and test fire by pushing in the firing pin with your finger (dry fire onto wood or old coiled rubber hose, use very quick pushing action against trigger pin). If the gun works, replace parts and adjust the safety foot so that the lever below the trigger is pushed all the way up and lever depresses the trigger pin all the way in. Good luck
May 26, 2012 | Air Tools & Compressors
How does the framing nailer work with a black button grey button
Dewalt has two triggers available for their framing nailer. The black trigger (390746-00) is a bump style trigger. While holding the trigger, you will be able to fire a nail by pressing nose against work. This trigger is preferred by most framers because it is much faster. Gray trigger will only allow one nail to be fired. Bumping will not work with the gray trigger. With trigger released, you must place the nose against work then pull trigger to fire. To fire next round, you must release trigger, pull gun off the work, again place nose against work then press trigger. Check dewalt web site for recall information. Some dewalt framers have been recalled for faulty trigger. Good luck with your projects.
Aug 11, 2011 | Dewalt Round Head Framing Nailer D51845
I have a turbosteamer 220 hand steamer. It heats up but won't spray steam
It's most likely the trigger not engaging the piston that releases the steam. Due to the fact that the plastic inside the 220 holding the trigger in place has cracked on both sides.It will need to be taken apart.That's another issue.Be easy on the trigger press down gentle.....
Jul 27, 2011 | Vacuums
I DONT KNOW HOW THE SCANNER WORKS.WHERE TO INSERT THE PICTURE I WANT TO SCAN.
Which device do you have? If it is an all-in-one that does not have an automatic document feeder (ADF), you lift up the scanner cover and place your photo face down on the glass. If there is an ADF, place the document face up in the feeder. (Using the ADF is not recommended for pictures.)
If it is a stand-alone scanner, the cover is more obvious. For single-sheet scanners, check the manual for which side of the document needs to be forward.
Depending on the OS and software installed, you launch your scan program and adjust the resolution and destination and press scan. (If you have an all-in-one, you may need to install the manufacturer's full-featured software first. Otherwise you will only get printing enabled.) If you use a generic OS driver, the buttons on the unit will not trigger the computer responding to the commands.
Set the destinations for scanner buttons in the software before using the unit buttons when using the full-featured software. Check the manual for specific information. The button presses are noticed by a monitoring program. If that isn't running the unit buttons will not work.
I hope this helps.
(Windows XP, Vista and Win7 all accept scans in Paint (File > Import from Camera or Scanner > New Scan). Vista and Win7 also have Windows Fax and Scan that can acquire scans.)
Sep 14, 2010 | Office Equipment & Supplies
Can not unlock saw
there is a safety button[usually by thumb area when u grab handle ] on most saws that has to be pressed as well as the switch when using circular saws
Jan 18, 2010 | Saws
Dispenser not dispensing water when we press the button inside the refrigerator. It was fine this morning. Just suddenly stopped working. Hoses all still connected.
Seam than you either have a bad water valve or you water line has froze up Disconnect the water line going out of the water valve but live the one going in still connected and whit pressure and fridge plug up. have some towels handy, Ask a helper to press the water trigger if water squirt out of the valve when the trigger is press That means than the water line has froze up and you have bad thermostat and is letting get to cold on the fridge side. Id you don?t get water to come out test if you are getting power to the valve when triggered if you do get around 120volts then change the water valve
Jun 06, 2009 | Kenmore Refrigerators
Laser does not trigger
open the OTL program.
go to 1 - Test Apps
go to 6 - Next Page
go to 1 - Auto Wedge On
do the tests now ;)
Feb 28, 2008 | Symbol MC1000 Barcode Scanner
Special Applications
Some applications require multiple connections, such as Internet gaming, video conferencing, Internet telephony, VPNs, and others. These applications have difficulties working through NAT (Network Address Translation). If you need to run applications that require multiple connections, specify the port normally associated with an application in the Trigger Port field, select the protocol type as TCP (Transmission Control Protocol, UDP (User Datagram Protocol), or both, then enter the public ports associated with the trigger port to open them for inbound traffic. The Trigger port is an outgoing port (from LAN to WAN) that the application will send out. Step 1 Open your web browser and enter the IP address of your router (192.168.0.1). Step 2 Enter your username (admin) and password, if any. Step 3 Click on Advanced tab on the top and then Applications on the left side. Name - This is the name referencing the special application. Trigger Port - This is the port used to trigger the application. It can be either a single port or a range of ports. Trigger Type - This is the protocol used to trigger the special application. Public Port - This is the port number on the WAN side that will be used to access the application. You may define a single port or a range of ports. You can use a comma to add multiple ports or port ranges. Public Type - This is the protocol used for the special application.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Symbol MC5040 Pocket PC Logo
224 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
