Question about Broan-NuTone CV554 Cyclonic Bagless Central System Vacuum
The vacuum is always on unless i unplug it
I have a nutone cv554 central vacuum. I can't stop it without having to unplug it. I even disconnected both switch from inside the vacuum and there is 3 other parts. I'm wondering is anybody might be able to help me in finding what part is defective
thank you
Claude
  • 58 Answers
Sounds like your controll relay went bad in the main unit its an easy repair but i would still have a reputable vacuum shop do it.
Posted on May 29, 2009
Nutone cv353 unable to stop
You may have a stuck relay or one of your access port switches may be bad. According to the owners manual: "A complete check of all Wall Inlet and Power Unit low voltage control lead connections (external yellow leads). Turn system off by removing fuse or tripping circuit breaker at
house fuse box."
Dec 27, 2011 | Broan-NuTone CV353 Central Vacuum
When the switch is turned on the vaccum cleaner starts running instead of,when the hose is connected. removed the earth lines from the unit and truned on the vaccum cleaner. It did the same. What might...
Dirty switch at vac where hose connects go to radio shack get some tuner cleaner spray. spray this switch and plug hose in and out a few times spray again see if this works
Feb 26, 2011 | Broan-NuTone CV554 Cyclonic Bagless...
CV-353 will only go off by unplugging. Electrical disconnected from ports to unit. Checked push pins on all ports and they are moving in and out.
http://www.centralvacuumstores.com/cvs/trouble_help.php#runs_continuously
Here is a link to find a local dealer:
http://dealer.nutone.com/DealerLocator.aspx?unit_id=002&cata_id=8
Dec 23, 2009 | Broan-NuTone CV353 Central Vacuum
Vacuum won't shut off
the relay is most likely the problem, they get burnt and the contacts stay together leaving the unit on. Try www.builtinvacuum.com for parts.
Aug 20, 2009 | Broan-NuTone CV450 Central Bagged Central...
NuTone Central vac won't turn off
If the central vacuum tank will not turn OFF even with the switch in the “OFF” position, then the low-voltage wires should be disconnected from the tank. If the tank continues to run and still will not turn off, then most likely the relay inside is defective (but it could be a defective and/or shorted ON/OFF switch). If with the low-voltage wires disconnected the tank is able to then be turned off with the switch, then there is a short in the low-voltage wires or a hose is plugged into an inlet somewhere. ~ TTURAMBAR
Mar 11, 2009 | Broan-NuTone VX475 Bagged Central System...
Motor won't shut off on central vacuum
Your relay is bad. This is very easy to change out yourself. There are several websites that sell this part online. Some websites offer free tech support.
Mar 01, 2009 | Broan-NuTone CV350 Performance Bagged...
the parts are available. go to:
NuTone Customer Service
Email or Call 888-336-3948
Hours: M-F 8:30 am - 5 pm EST
please rate my answer as a fixya!
Feb 26, 2009 | Broan-NuTone CV353 Central Vacuum
Nu-tone 475 keeps running even without hose plugged in.
If the central vacuum tank will not turn OFF even with the switch in the “OFF” position, then the low-voltage wires should be disconnected from the tank. Once this is done, if the tank continues to run and cannot be turned off with the switch, then most likely the relay inside is defective and needs to be replaced (but it could be a defective and/or shorted ON/OFF switch). If with the low-voltage wires disconnected at the vacuum tank, it can be turned off with the internal switch, then either there is a short in the low-voltage wires, or else there is a hose still plugged into an inlet somewhere. ~ TTURAMBAR
Nov 11, 2008 | Broan-NuTone VX475 Bagged Central System...
My nutone cv556 wont shut off
It sounds like the relay is bad. This website has a pretty good trouble shooting page.
https://www.centralvacuumstores.com/cvs/trouble_help.php#wont_turn_on
Sep 28, 2008 | Broan-NuTone CV450 Central Bagged Central...
CENTRAL VACUUM SYSTEM
Disconnect the inlet piping from the unit and check the suction there. Be sure that the utility inlet on the unit is closed. If you have good suction, you have an open/broken pipe somewhere, or possible an inlet valve or vacpan that is not sealing when closed. The easiest way to find it would be to install your tubing back into the inlet of the unit, turn the unit on, and walk around the house listening for air leaks. Good Luck!!
Jun 29, 2008 | Broan-NuTone CV353 Central Vacuum
Broan-NuTone CV554 Cyclonic Bagless Central System Vacuum Logo
129 people viewed this question
Top Broan-NuTone Vacuums Experts
Gerry Harvey
Gerry Harvey
JoeVacs
rdjagger
Are you a Broan-NuTone Vacuum Expert? Answer questions, earn points and help others
