Vacuums Logo
A
Anonymous Posted on Dec 15, 2013
Riccar 8850 red light is on and won't go off, I changed the bag but do not know what the light indicates
Thatvacguy.com
Level 3:
  • Riccar Master 1,619 Answers
  • Posted on Jan 13, 2015
Thatvacguy.com
Riccar Master
Level 3:
Answers
1619
Questions
0
Helped
604641
Points
3345
The light indicates a restriction, a full bag or clog or something restricting the airflow
5 Related Answers
Anonymous
  • 97 Answers
  • Posted on Mar 09, 2009
SOURCE: no suction
Replace your belt. Remove the baseplate, remove the brushroll, place a new belt around the motor pulley, then around the pulley on the brushroll, and pull the brushroll back into place in the nozzle. Spin it by hand to make sure it spins, (otherwise you'll break the belt again,) and then replace the baseplate. Party.
-R
Anonymous
  • 438 Answers
  • Posted on Mar 18, 2010
SOURCE: My Riccar 8850 stopped running.
Greetings from GoVacuum,
If the light on your Riccar 8850 is coming on, but the motor is not coming on, this indicates that your motor has gone bad. There is a reset switch on the back of the vacuum cleaner that sometimes trips if the bag is too full, or the filters are not maintained, but when this happens nothing on the vacuum comes on including the headlight. If the headlight is coming on, this indicates that electricity is making it down to the headlight, and the current is going through, but just not activating the motor. This is a tell tale sign of your motor being bad, and needing replacement. You can purchase the motor for the Riccar 8850 (12 AMP, 2 stage motor, Riccar part D113-1700 $122.44) from GoVacuum by giving us a call, as we don't yet have this part on our website.
I hope this helped you. We have been fixing Riccar's for over 30 years, and they are great vacuum cleaners, and the age of the model 8850 is probably the life expectancy of this vacuum cleaner.
Chris Jones
GoVacuum.com
Testimonial: "Thanks for the information. I pressed the reset button and everything is working fine again."
Anonymous
  • 1654 Answers
  • Posted on Apr 04, 2011
SOURCE: model 8850 riccar no suction
The bag has a cardboard collar with latex. It must seal over the inlet. Make sure not to tear the bag when replacing.
Is the cover closing properly? The cover seals against a gasket. The same with the filter.
If this is ok, then there probably is still something clogged in the system, Up inside the bottom of the vacuum there is a hole where the dirt goes in to get to the bag. That's where the clog probably is. Also if If the belt is stretched, then it can't turn the brush rol under load, if you haven't chenged it in the last 6 months, then I would put a new one one. Also check the dirt inlet by the brush roll for a blockage. Last but not least, the base plate on a vacuum must fit tightly against the bottom of the vacuum for it to get good suction. this is a culprit on a lot of repairs so make sure the bottom of the vacuum is put togethere correctly and tightly.
Anonymous
  • 1157 Answers
  • Posted on Jul 04, 2011
SOURCE: My Riccar Vacuum cleaner just stopped working
Hi susanchri43,
Have you tried resetting the machine using the reset button on the back of the vacuum? If not please press the reset button. Here are additional troubleshooting steps that you may apply to determine what's wrong with it.
1. Ensure that the power cord is firmly in. You may also try to unplug and replug the power cord.
2. This vacuums are equipped with a thermal motor protection circuit that will shut the vacuum down if it detects excessive heat up. Overloading due to a clog, or the bag being full can cause heat up.
3. Check the hose pipe or the upright's mouth and remove any obstacles. Use a broom handle to poke any debris that may become trapped in the hose.
4. Unplug the machine and use your fingers to pull out any debris in the machine's mouth. Cut any thread or string that may have become wound around the rollers. Plug the machine back in and press the reset button on the back of the vacuum.
5. Switch the carpet switch to the "Carpet" position if you are using the vacuum on carpet and the vacuum won't pick up debris. Turn the tool activation switch to the "Off" position. Take a look at the light marked "Brushroll." If it's illuminated, remove the cause of the jam at the brushroll.
6. If the vacuum allows dust to escape, check if all the covers are tight. The filters and vacuum bag must be installed correctly. The filters snap into place and cannot be washed and re-used. Make sure the base of the bag collar is on the bag supports.
Hope it helps.
Thank you for using FixYa.
Anonymous
  • 30 Answers
  • Posted on Jul 13, 2011
SOURCE: riccar 1700 won't power on, outlet is working, no
If this problem happened after you replaced the filters, check that the filters have been installed correctly because some filters have sensor magnets installed on them and unless they are in their correct position, the machine wont power on.
I hope this helps you
MobileJB
Riccar 8850 Upright Vacuum Cleaner. I need a wiring diagram for it please?
Question edited for clarity and typo.
There is no wiring diagram available
https://www.google.com/search?q=riccar+8850+wiring+diagram
There is a video though
Or you could ask the maker?
Vacuum Cleaner Operating Instructions
Riccar http://media.riccar.com > 8000_Owners_Manual
How to Replace the Agitator Belt. (Models 8750 8850 & 8800 only). Unplug the units power cord. Turn the unit over and remove the bottom plate as described in ...
13 pages
My Riccar 8850 is very hard to push, even moreso on heavier pile carpet. Know any reason why? Also see my "more details" section.
adjust the setting on the vacuum head to pile or plush carpet
it is a simple lever that raises the hood to allow more air under it to make it easier to push
What size vacuum bags does my ricar 8850 take
Riccar style A or B bags will fit. So will Panasonic U, U3 or U6.
Get red light off after changing filter
Depends on which model you have. If it's a red light it might be your full bag indicator. If it's glowing red you might have a clog somewhere .
Need to change the light bulb on riccar 8850 vacuum
Remove the bottom plate to be able to pull the light bulb out and replace it.
4helpful
Stopped running. Filter was clogged. Cleaned filter and changed bag, but still won't start. Motor was warm when it stopped.
Hi There,
This sounds like the Thermal Switch in your motor tripped. All Riccar vacuum cleaners have a motor reset switch, that will shut the motor down when it gets hot. Usually it's caused by a full bag, clog, or dirty filter.
Try resetting the thermal switch first. If this doesn't work, you may have done some more serious damage to the motor, and it might be a good idea to take it into a local Riccar dealer in your area.
Here's a step by step guide on how to check the reset switch on your Riccar 8850:
To reset the thermal fuse:
  1. Unplug the vacuum cleaner
  2. Check for problem – over–filled bag, clog in hose, clogged filters, etc.
Remove the vacuum bag, and see if you can visibly see any obstructions, or replace the bag if it's full:
Also inspect the Secondary filter while you have the vacuum bag removed from the machine. If the filter is clogged or dirty, rinse under warm water, and air dry completely before reinstalling it into the vacuum. It's best to wash this filter every 30 days, and replace after 4-5 washings.
Here's a link to the secondary filter on our website if you ever need to purchase one:
Riccar 8800 Series Secondary Filter
Your Riccar 8850 also has a set of exhaust filters that are on the front of the vacuum, near the bottom where the upright body meets the agitator housing. These filters when clogged may also cause the thermal switch to trip. These filters are recommended to be replaced every 6-12 months, and are not recommended to be washed.
Here's a link to 2 sets of the exhaust filters for the Riccar 8850 on our website:
Riccar 8850 Exhaust Final Filters, 2 Sets, 4 Total Filters
It's also possible that you may have clog in the suction port inside of the agitator housing. Remove the bottom plate from the vacuum, and look for the tube that runs on the left hand side from the tray to the rear of the agitator housing. Make sure that this tube is clear from obstructions:
Locate "tripped" fuse – the small white button located on the bottom of the back side of
the main body (roughly one inch to the right of the left wheel)
Using a pencil, paper clip or other pointed object, push the reset button in, you should hear a clicking noise when it resets.
Plug the vacuum cleaner back into the wall, and try turning the vacuum on. It should come right back on. If not, it's best to take your machine into a local Riccar authorized repair facility for further more advanced diagnosing.
Please feel free to ask any follow up questions by adding a comment to this repair, I'm always more then happy to answer any and all follow up questions if you need some clarification. If this was helpful, please rate the repair helpful or leave some feedback for me. Thanks so much,
Chris Jones
Govacuum.com
3helpful
Where is the reset button the riccar 8850?
If you look down at the base of th vacuum cleaner at the vacuum bottom in the back, right above the rear wheels, you will see a small red button. Take a ball point pen, and while the vacuum is plugged in, go ahead and push the red button or the reset switch. Did the vacuum come on?
If not, it may another simple problem of the cord/ plug going bad.
I think if it just stopped workint all or a sudden, it's prbably the reset switch.
If this was helpful to you, please help other Fixya users find the repair by clicking the thumbs up icons.
Thank you,
Chris J.
GoVacuum
1helpful
My Riccar 8850 stopped running. Changed the bag and cleared all hoses. Light comes on but the motor doesn't operate. I can turn the brush freely by hand.
Chris Jones
GoVacuum.com
9helpful
Where is the reset button located?
The reset buttons on the Riccar vacuum cleaners are located at the bottom of the vacuum cleaner in the back, underneath of where the wand sits on the vacuum cleaner.
Here's a picture of a Riccar 8925 which replaced your 8850 a few years ago, but the reset switch will be in the same exact location on all Riccar uprights;
Here's a closer look of the reset switch;
I hope that I was able to answer your question. You can avoid the reset switch flipping in the first place by always ensuring that you change the bags frequently and when full, as well as the motor filter that sits underneath of the bag. Also keeping the vacuum from clogging will prevent this.
If you found this repair solution helpful to you, may you please click the 4 Thumbs Up Icons in the top right hand corner to help me out here on Fixya? I really do appreciate it, thank you so much.
Chris
GoVacuum
2helpful
No suction
-R
Top Riccar Vacuums Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
