Question about EnGenius EOC-3220 (EOC3220)
Problem using 2nd hand AP senao EOC3220 EXT
I have senao EOC 3220 EXT that my friends gave it to me and i don't know how to use it.As far as i know, this thing can use to connet to the internet with wi-fi device.
maybe some body can tell me step by step how to install it to my PC.
p.s
i still don't have the wifi device installed on my PC.
Great thanks 4 all
  • 481 Answers
You can use this unit either as an access point, to provide wireless access to a network you already have, or as a bridge, to access a remote wireless network someone else has.
Note that you own the EXT model, meaning that you have to attach your own antenna to the connector before it will function. There is no internal antenna on this model.
Configuration instructions are available at
EOC-3220 Series User Manual
Factory reset instructions are available at:
http://engeniustech.com/datacom/support/general-details.aspx?id=65
Posted on Oct 28, 2009
My Seneo 3220 has changed its mac and gone to Realtek,can not log on to it any more,think its lost Engenius software. nigel 2205
I have no idea what it means for a Senao to "go to Realtek."
Here is the factory reset procedure for the Senao EOC-3220:
An RS-232 null modem serial cable is required for this procedure.
1. Connect the EOC-3220 to your computer with a null modem serial cable.
2. Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears:
a. Give this new connection a name. Ex: EOC-3220.
b. Select correct COM port. Ex:COM1.
c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
Oct 25, 2010 | EnGenius EOC-3220 (EOC3220)
Resetting my EOC-3220 via serial cable
The # will only appear if you monitor the EOC through the power-up sequence. If you are cabling into a running EOC, that # has already gone by. By that time, you no longer need to wait anyway, just type.
If you can't type in the text window, you may have HyperTerminal set up wrong, or may have the wrong brand or model serial cable. The EOC is pretty good about accepting input when it is supposed to.
However -- as long as you know what the current IP address of your unit is, you should be able to browse to it over the main ethernet cable and make whatever changes you need that way. The MAC address allow table isn't going to affect your local access in any fashion, it only controls who can connect wirelessly. This may be faster than trying to figure out how your serial connection is faulty.
Aug 12, 2009 | EnGenius EOC-3220 (EOC3220)
How do i reset my engenius senao eoc 3220 outdoor radio
back side one reset button is there pull out the power cable then pull in that same time you have to press the reset button for three to five sec then all lied's blink all to gather then your default ip address is came then you again configure at default ip
Apr 15, 2009 | EnGenius EOC-3220 (EOC3220)
My senao eoc-3220 is showing SSID as 802.11g-SSID. But it does not acquire an IP automatically. I tried using defaults but that does not work either. Trying factory reset does not work because the "#"...
Hi
I had the same problem. This may be as simple as pressing the enter button on your computer keyboard after all the activity stops. This brought up the number sign for me after which everything else in the reset procedure worked fine.
Dec 22, 2008 | EnGenius EOC-3220 (EOC3220)
Getting to setup pages
look at your DHCP client table on your router to find the IP address of the device.  You can identify if via the MAC address on the table (and sticker the 3220)
May 28, 2008 | EnGenius EOC-3220 (EOC3220)
EOC-3220ext Loosing its wired connection with lan
Try to Flush DNS Cache
ipconfig /flushDNS
Also
May 08, 2008 | EnGenius EOC-3220 (EOC3220)
SENAO EOC 3220 CONNECTIVITY PROBLEM
hello!
-- try to change wireless channel on your access point
-- try to enable wireless security on your wireless network
-- try to assign static ip address on your wireless computer
Apr 26, 2008 | EnGenius EOC-3220 (EOC3220)
Comando para ver clientes conectados
After logging into the EOC-3220 with Telnet, enter:
cat /proc/wlan0/sta_info
Mar 20, 2008 | EnGenius EOC-3220 (EOC3220)
Resetting the senao eoc-3220 long range wireless access point/bridge
Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal. c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
Feb 21, 2008 | EnGenius EOC-3220 (EOC3220)
I made firmware 1.39 to SENAO ECO3220
hey maick, I have the same proble, but I fix it, try this: 192.168.1.254, for me work fine, after that I reload the new firmware. now is working fine. good luck, jose luis Ogawa
Jan 19, 2008 | EnGenius EOC-3220 (EOC3220)
EnGenius EOC-3220 (EOC3220) Logo
339 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
