Question about Cell Phones
Want to fit a new speaker to nokia3109c phonebut cannot strip it
  • mickyb804 May 16, 2009
    What i mean is that i cant take it appart.
    **** B
    Phone now apart,thank you
  • Cell Phones Master
  • 13,433 Answers
You can't strip it? as long as the new speaker is the same as the old one, it will fit, if its anything else it very likely won't fit. What do you mean with strip it can you get the phone apart or?
Posted on May 14, 2009
  • Ekse May 16, 2009
    take the phone apart as much as possible, take out the back cover, take out battery and sim card, unscrew all screws that you find and also look under soft objects and labels and other covers for screws.
    ones all screws are out you will have to carefully snap the phone open there will be plastic holders in place on the sides of the player use a small flat screwdriver to do that. you will get the phone apart eventually if something doesn't snap open then double check for screws and hidden screws.
Wiring harness does not fit from my old deck to my new one
If you meant that you are changing the INDASH set with another model, the wiring harness will not match unless it the same model/make.
Now it is possible to source the harness which fits to some model but other wise you might need to manually STRIP the wires on the harness and connect from the given wires . Since all the connections are available it is only important that the leads are tested to be connected, the +B switched, + continuous, the Ground and then the speakers, front and rear. If amp is used then connected the switched power to the amp.
Jul 27, 2011 | Car Audio & Video
Hi, Ive just purchased a pair of Monacor SP-60/8 speaker units from Wilmslow audio. These have been supplied as direct replacements for the HB3 midrange units. However when I attempted to fit them ,they...
Thin rubber sealing strip tube (hollow in the centre thus compressible, lightly glued/ fixed into the rebate and screw the speaker in on top of it. It would have to be thin enough not to interfere with the speaker mechanics, even when it squashes. Maybe a window maker could source something like that? I dont think foam would be rigid enough which is why i suggested rubber.
If you haven't already ground off the corners I'd speak to the supplier with a view to getting the correct replacement, but then presumably you would have done that anyway.
Dec 30, 2010 | Heybrook HB3 Speaker
I am changing out a Clarion ARX7570z to NZ500. Have most of the bugs worked out but I need a wiring diagram for the ARX to figure out the which wires are which. HELP!
the wiring diagram is out dated for the cassett player ....
here is what i know
red is ignition swichted
yellow is contstant power
black is ground
blue power antenna
blue with white strip amp turn on
gray + f right speaker
gray/black strip - f right speaker
white is + L front speaker
white with black strip is - L front speaker
green is + L rear speaker
green with black strip - L rear speaker
purple is + r rear speaker
purple with black strip - r rear speaker
your orange with white strip is illumanation not used
100% of all aftermarket radios are color code this way if you have install diagram for new radio it will be the same as old clarion radio ..
but make sure u have a digital volt meter to check power on red and yellow wire and comming from the factory harness be for you connect new radio just to make sure it does have powers and check other wire for power also just so you dont blow up new radio ... you can blow up a radio by connecting a wrong wire faster than you can blink your eyes ..... if you need a wire diagram for you modle car email me with it a http://www.tintingbyfredjohnson.com and go to contact and send email
Dec 28, 2010 | Clarion ARX7570z
I need an encoder strip.dell will not answer any of my email requests.know where i could get one
hi ., it s not easy to get an encoder strip that actually fits with a dell printer .
in case the strip is in good condition , and only is hanging loose ..u can try to fit it with ur own hands . on either side .,
the model 926 is a very old printer , and so honestly ..the money he would want to spend buying a encoder strip ....u can actually get a new printer with new warranty +new carts + tech support ..
good luck .
Jul 23, 2009 | Dell 926 All-In-One InkJet Printer
Headphone jack must be moved around to get right speaker working
You will find that sound comes from the right side speaker only when it is bent at a certain point. By trial and error you can roughly locate the point. Then you can cut the wire at that point, cut 1 inch each from both ends, strip the cables, and connect the conductors. What has happened is, due to unusual bending, the conductors to the right-side speaker has damaged (broken). After roughly locating the place and removing 1 additional inch each, you will remove the wire section with the broken terminal. Now you can strip the wires and make the connections again. If you are not good at stripping and soldering wires, better to to take it to an electrician. (You need to take only the headphone pin and parts attached to it). This repair won't cost much. Good luck!
Jun 25, 2009 | Logitech Z-2300 Computer Speakers
I am intstalling a new stereo into my mother inlwas 2005 hyundai accent. The problem I am running into is, after i accounted for the speaker wires, there are still 6 wires left: black, grey, blue, pink,...
Hello tinman3110,
Here's a link to ModifiedLife which shows the 2005 Hyundai Accent wiring chart. Some of the colors are duplicated, so for tapping and splicing, you will need to test to see which wire is which. For example, the chart shows "blue" for both external amp trigger and left rear speaker negative.
To avoid tapping into the car wiring, a better solution is to use a vehicle specific wiring harness. SonicElectronix sells the Scosche HYO3B which appears to fit the Hyundai Accent. Metra and others also make wiring harnesses and the Metra part number 70-7301 sold by www.installer.com appears to fit.
Hope this helps.
Jun 01, 2009 | Car Audio & Video
Speakers wont fit in car
Look at the old speakers to find out which cable is positive (+) and the other negative (-). Cut the connectors off one at a time, strip the wires, connect them to your new speakers. Negative to negative positive with positive then tape them good with black electrical tape. That's all! If the cables are to short connect more speaker wire.
May 07, 2009 | Car Audio & Video
Mission 764 wire connections
Yup, Thats about the shape of it - use a nice think solid core copper mains cable. That's waht was fitted to my recently retired 764's when I bought them new many moons ago.
Jan 04, 2009 | Mission 780 Main / Stereo Speaker
Rear speakers in audi 1999 audi a4
You don't want to fit that - it's the factory amplifier for the rear speakers (the rears are amped, the fronts are not). You need to run new wires from the head unit back to the new rear speakers so that the speaker-level outputs from the new head unit are used to drive the new speakers.
Dec 16, 2008 | 1999 Audi A4
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
