Question about VeriFone Omni 3700
Green button sticking
I have a omni 3740 & the green button located in the bottom right does not function correctly, I have to press it hard & sometimes a couple of times before it works
Why my cash register te2400 not funtion after i replace barcode scanner? After beeps not funtion and light..help me
Posted on Jul 20, 2015
    Problem Solver:
  • 5 Answers
I have that problem a lot with this model. Unless it's 'sticking' which would mean its dirty... this in my opinion needs to be repaired. That is what i always do in this case.
Posted on Aug 03, 2009
How do you set the time & date
Hi kearnst,
You can easily change the time of your Timex watch by following the steps below.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds).
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
Hope it helps.
Thank you for using FixYa.
Jul 25, 2011 | Timex 1440 Nylon watch
Hey, i have a problem with my sony PSP when i start my PSP the green power light is on but there is nothing to display and the memory stick light keeps flickering too , please help ???
Hello there
You'll need to hard reset your PSP and restore it to its factory settings. Once this is done, your PSP should work perfectly.
Hold the power button on the right side of your PSP down until the device completely powers off. Wait at least five seconds after the power is off before proceeding to the next step.
Press and hold the Select and Start buttons located in the bottom right corner of the PSP.
Press and hold the Square and Triangle buttons (located on the directional pad) while continuing to hold the Select and Start buttons.
Press the power button while holding these four buttons. When the flash (logo) screen appears, you can release the four buttons and your PSP will be reset to its factory settings and the screen will no longer be blank.
Oct 10, 2010 | Sony PSP (Piano Black)
Omni 3740 not printing dark enough
The print on our Omni 3740 is not working. We have to push the cover down hard to make it print. I think the roller is not pushing hard enough or the clamp to hold the cover is out of alighnment. Need help.
May 26, 2010 | Office Equipment & Supplies
Need to reset password for verifone omni 3740
If you press the F2 and F4 buttons and enter 1 Alpha Alpha 66831 and the terminal goes back to the idle screen then the system password has been changed or the battery is bad in the unit and will have to be replaced. Either way it will have to go to a repair facility to be corrected.
Aug 12, 2009 | VeriFone Omni 3700
Omni 3740 SYS Mode file group 1 password?
Where did you purchase the machine from? Or do you know what companies have downloaded onto it previously? They must have changed it at some point.
Jun 02, 2009 | VeriFone Omni 3700
TV Locked - Omni v6833nf
Use the original Omni remote to turn on the TV. press the "Function" and "Mute" buttons at the same time. Omni technical support: (416) 260-0047.
Mar 25, 2009 | Televison & Video
Verifone omni 3740
Most likely:
1, alpha, alpha (little gray button between the four purple keys), 66831, enter
Sep 23, 2008 | VeriFone Omni 3700
WASTE TANK ALMOST FULL
Try following reset procedure:
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!!!
6. turn off printer by button POWER.
If reset does not work, you have to take apart the printer and empty the ink tank located at the back bottom right corner of your printer, replacing the sponge inside.
Here is an alternative procedure
1) With the printer power turned off, while pressing the Resume/Cancelbutton, press and hold the Power button. (DO NOT release the buttons.The LED lights in
green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3)While holding the Power button, press the Resume/Cancel button 2 times,and then release both the Power and Resume/Cancel buttons. (Each timethe
Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
4) When the LED lights in green, press the Resume/Cancel button 4 times (Each time
the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
5)After the function (menu) is selected, press the Power button. The LEDlights in green, and the selected function is performed. (When theoperation completes,
the printer returns to the menu selection mode automatically.)
You find reset procedure here.
Here is also a reset software, http://rm1.biz/resetprinter .
Aug 21, 2008 | Canon PIXMA iP90 Mobile Printer
I hope you can help
That would need to come from your credit card processor.
Mar 08, 2008 | VeriFone Omni 3700
VERIFONE OMNI 3740 INK RIBBON
We found that it was neither the thermal paper roll nor the thermal component. The cover did not close tight enough and that caused the print-put to be light or missing printed areas.
Jan 04, 2008 | VeriFone (M19755014US1) Magnetic Card...
Retail Supplies Logo
186 people viewed this question
Top VeriFone Retail Supplies Experts
Da Doc
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
