No sound, no video.
Phillips Model number 32pf7321d/37 Relay clicks two times then red led blinks 5 long blinks then 3 short blinks. Should be Error 53.
  • 3,866 Answers
There are several cuase to this issue one being the power supply unit not providing power to the rest of the tv because of a blown capacitor or a resister gone bad. It look like you did some investigation and I can apprciate that but I been around for 20 plus years in this field to know a little more then a back yard fresh out of school tech not saying you are such but however if your the type of person that could repair this your going to need a OHM meter to check current SCHEMATICS to check how much current al you going to need to know about LOGIC BOARDS these will require some know how as well but check the PSU and RCT... Rulds2008 please rate me!
Posted on May 14, 2009
Powers on then off with 4 red binks then 2 amber?
A blinking red and yellow Status LED will indicate an Error Code that can help determine the cause of a circuit
failure.
• The number of Red blinks indicates the value of the (tens digit) of the Error Code.
• The number of Yellow blinks indicates the value of the (ones digit) of the Error Code.
Example: If the Error Code is "37", the LED will continuously blink Red three times, followed by blinking Yellow
seven times.
25846923-00ymvd0zfh3oypxbgkhcneuw-4-0.jpg See the following for a list of Error Codes.
To perform a System Reset, press and hold the Power button for 10 seconds. Or, unplug the set for 10 seconds
then restore power.
http://electro-medical.blogspot.com/
Sep 02, 2015 | Mitsubishi WD-73638 3D-Ready DLP HDTV
50PF9630A/37 Phillips 52" plasma clicks on, 20 seconds later blinking red light syndrome. No pattern, just on/off. Replaced power supply board. Same thing. What other boards should i replace? Than
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Nov 12, 2014 | Televison & Video
My 73" mitsubishi dlp WD-73827 turns off and has a red status light blinking. I have replaced the bulb and the heat sensor... any answer to what else could be the problem?
It is helpful to have the sequence of the blinking red light. This may help:
MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927
Page 43
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "DEVICE" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
POWER
LED
STATUS
LED
LAMP
LED
Power
Status Condition
Off Yellow Off Low
Power Excess heat. Check Lamp Filter
Off or On Off Yellow No
change
120w usage time over 7000 Hrs.
150W usage time over 3500 Hrs.
Off Off Blinks
Yellow
Low
Power Lamp Cover open
Off Blinks
Yellow Off " Filter Cover Open
Off Off Red Stby Lamp did not turn On
Off Blinks
Red Off Low
Power Fan Stopped
Off Red Off " Circuit failure (short or DVI
connector unplugged)
Abnormal LED Indications
Error Codes "DEVICE" & "MENU"
Error Codes Description
12 No error detected
22 Recovery from Reset
32 Lamp cover is Open
34 Lamp abnormality
35 DM Fan failed (Chassis Fan)
36 Exhaust or Lamp Ballast Fan failed
37 DMD Engine Fan failed
38 Lamp temperature abnormally high. Remove Lamp to check filter.
39 DMD temperature abnormally high
41 Short is detected (Standby Power Supplies)
42 Lamp Fan failed
44 DVI cable between Format and Engine disconnected
46 DMD Temp. Sensor not detected (check DT connector))
47 DM Temperature too high
48 Engine power supply short detected
51 Speaker Drive circuit short detected
52 HDD excess temperature (V30+ & V31 only)
55 HDD Fan Stopped (V30+ & V31 onlyt)
Jul 18, 2014 | Mitsubishi WD Televison & Video
My tv (32PF321D/37) won't turn on and the power light is flashing red six times, pausing, then doing it again. Any ideas?
Check bulging capacitors in power supply that causing 6 red LED flashes. Replace them and fix the problem. philips-32pfl5322d-37-04.jpg?w=770
Feb 01, 2011 | Philips 32PF7321D 32 in. LCD Television
After turning of the TV for a few minutes, it won't turn ON. The power LED turns green for a second and then becomes red and flashes, Philips Model 32PF7321D/37
grodmx74, You or electronics technician will need to find the "thermally-intermittant-hair-line-fracture" of a component soldered to the switch-mode-power-supply printed circuit board with aid of large magnifing glass or use a 10x or 20x inspection microscope, and then resolder the connection. 12fixlouie
Apr 02, 2010 | Philips 32PF7321D 32 in. LCD Television
My Phillips Flat TV (Plasma) Model 50PF9431D/37 is Blinking an error code of 6 long and 3 short red blinks I am assuming it is an error 63. I have to unplug the cord and plug it back in up to 6 times...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting the number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Sep 02, 2017 | Philips Televison & Video
My Phillips flat screed TV model # 37PF7320A 37 won't turn on. When I press the power button the indicator light blinks 1 long red then 4 short. I tried to change both of the fuses but I couldn't find...
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this i have the same tv it works like new
May 11, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
42pf7321d/37
relay clicking is a power board failure --- part of the board still works to supply power to the flashing lights--- the lights are related to an error code while in protection mode
Oct 12, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 42PF5321D/37 Error Codes
replacing ssb for 4 blink error was correct as error is communication failure specific to micro processor on ssb. getting an alternate error after replacing ssb would suggest either wrong ssb or defective ssb. verify vendor number on ssb tuner on original and new ssb and if same reorder that board and if not order per original board
Jun 30, 2008 | Philips 42PF9630A 42 in. Plasma Television
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
Electro Med Services...
