Question about Samsung Digimax S730 Digital Camera
Model # s730 problems WHEN i TURN ON THE CAMERA THE LENS DOES NOT EXTEND OUT AND THE CAMERA SHUTS OFF THEN BEEPS A COUPLE OF TIMES.
  • 6 more comments
  • Anonymous Dec 16, 2007
    i turned my camera on it makes beeping noises and shuts off
  • Anonymous Feb 04, 2008
    the lens is completely our and it beeps a few times and shuts off.
  • acschmidt Feb 11, 2008
    i have the same problem, i turn it on, the lens donĀ“t gou out, it beeps twice and turn off.
    what can i do to solve it?
  • Nottellin Mar 08, 2008
    My camera will turn on (with the lens out) and then it will beep 3 times and then turn off without pullin in da lens!!!!!! i know it aint tha batteries b/c i have rechargebles and i charged em' all night!! no i didnt drop it on da dang beach whoever came up wit dat solution is pretty dang dumb omg!!!
  • Anonymous Mar 24, 2008
    When I press the power button the camera just beeps and lens is not extending
  • Anonymous Mar 31, 2008
    I have the same problem
  • drew79 May 29, 2008
    Alright, this is really pissing me off. The other day, I was taking a few pictures. My camera said that the memory was full and it shut off. I couldn't even turn it back on to delete pics/vids. I pulled out the memory card and deleted some pictures to make room. Now I can't turn it back on. When I try, the lens doesn't extend. It beeps a few times, then turns itself off. I'm about to throw it out the window and never buy a samsung product again. I visited their web site and it says I need to have the original receipt for any warranty claims. It was a freaking wedding gift!
  • ali-li May 30, 2008
    when i turn it off the lens dont come out and it wont shut,when i turn it on it is zomed ,my batteries be fully charged but when i put them in my camera it says low battery then shuts off,sometimes it just make a loud beep and cut off,my pictures are blurry,my memory isn't full but when i try to take a picture or video it says memory full,when i take a picture the botton get stuck and a red eye blinks,before i take a picture it freezes,the flash dosn't work,when i press the zome botton down it beeps then turn off and i think this ia all
Commissioner "Solution 3- Gently smack it against your palm, hitting the edge where your USB cable plugs into the camera. Thats usually where the guide pins and lens barrell will be located."
This worked, I repeatedly palmed it while powering up. If only I found this solution a year ago. It now a backup to my s1050
Posted on Dec 07, 2008
Just got done reading about this problem I had the same thing going on remember I HAD the same thing happening and i followed this step cause it was only 95 bucks and no tworth fixing. Beat the **** out of it with a sledgehammer - This step has yet to work for anyone but it does make me feel better about the whole situation.
Thanks for the help
Posted on Oct 12, 2008
O.K. - The 3 beeps error indicates that the lens is stuck and the camera cannot boot up, therefore shutting down. A common problem among all digital cameras and all brands, the only way to "fix" it is to reseat the guide pins into the guide slots. If your camera is under warranty, see if it is covered. You might get lucky. If not, and repair is too expensive, AND the camera is otherwise useless, you may try:
1- Gently grabbing the lens barrell and slightly pulling on it. AND I MEAN SLIGHTLY. This has worked for me countless times. The lens barrells tend to get stuck when opening and projecting out. So help it a little. Then press your power button and cross your fingers.
2- Simply, AND GENTLY, with even pressure, grab the lens while pressing the power button and see if it reseats itself. Listen for a slight click indicating the pins have been reseated. Then turn the power back off and see if the lens retracts.
4- Dismantle the camera and try reseating the guide pins. Good luck working with no space and tiny parts. Also good luck just putting it all back together. Much less with a working lens.
5- Beat the **** out of it with a sledgehammer - This step has yet to work for anyone but it does make me feel better about the whole situation.
Posted on Jun 27, 2008
  • commissioner Jun 27, 2008
    Just give it a tug. But be gentle....
I have the same problem. so i called samsung. mine is still under warranty so they said to send it in for repair.
Posted on Mar 27, 2008
Same thing happened to me I just returned it
Posted on Feb 09, 2008
Perhaps u dropped ur camera on the beach and sand went in between the shutters
Posted on Dec 31, 2007
SOURCE:
My camera turns on then beeps 3 times then shuts off is it broken or is there a reset button?
The three beeps mean that the lens motor is unable to extend the lens assembly.
This could be due to a low battery situation, but the most likely cause is the lens drive train stuck or jammed. You'll find generic instructions on solving some cases of jamming here.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Unfortunately, more serious cases (due to falls, shocks, and most of all, the camera being turned on while some resistance prevents the lens from extending: e.g., if the camera accidentally turns on while in a pocket) require the repair shop.
Apr 27, 2010 | Samsung Digimax S730 Digital Camera
When turning on my camera the stays on for only a
2 possible problems..
This is due to one of two problems:
First and easiest: the batteries are dead. Im sure you know how to fix that problem.
Second: your lens is jammed. The camera tries to turn on and extend the lens but since it is stuck, can't do so and gives up, beeps, and shuts off.
To fix this problem, send it into a repair shop. it shouldn't cost that much.
I hope that helped.
Regards,
Jeep Brainy
Aug 11, 2009 | Samsung Digimax D53 Digital Camera
My samsung l830 camera lens is stuck open and when i press the power button it beeps 3 times and remains blue then does nothing
If the lens on the camera is stuck out, look to see if it's a little crooked. If it is, try to gently straighten it. If it still won't retract, try to gently push it in as you turn the power on.
If it won't turn on (the green light blinks and it beeps 3 times) push and hold the 'power' button and the 'play' button at the same time for a few seconds - it worked for my S730. Good luck!
Jun 28, 2009 | Samsung Digimax L830 Digital Camera
I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
Jun 17, 2009 | Samsung Digimax S500 Digital Camera
Camera will not stay on
Did you try changing the batteries?
Dec 06, 2008 | Samsung Digimax S730 Digital Camera
Samsung S730
no solution ours does this
waste of money return it if u can
Aug 11, 2008 | Samsung Digimax S730 Digital Camera
Camera beeps loud 3 times and shuts right off!!
sounds like a lens error, does the lens extend or retract? You probably have to get the lens back on track, use gentle pressure wiht the camera face down on a towel covered table and turn on to see if the camera tries to retract the lens. I really dislike these types of cameras that extend the lens everytime, if it turns on in your pocket, your doomed!
May 27, 2008 | Samsung Digimax S500 Digital Camera
Won't turn on
I had something similar happen after five minutes. The included batteries are crap, try some rechargeables or brand new alkaline. Be warned this camera likes to eat alkalines but does well with nimh.
Sep 02, 2007 | Samsung Digimax S730 Digital Camera
it's the batteries. you need to get 2500 mah rechargeable ni-mh batteries. should work fine after that.
Aug 17, 2007 | Samsung Digimax S730 Digital Camera
The lens doesnt close and when i turn the camera on it bips three times and the screan shuts off. the lens wont close.
The batteries need to be changed. The digital batteries sold at the stores die out too fast. I had this same problem. In result, I purchased rechargeable battieries.
Nov 19, 2006 | Samsung Digimax S500 Digital Camera
Samsung Digimax S730 Digital Camera Logo
129 people viewed this question
Top Samsung Cameras Experts
Jerry Z
Andy Bale
Andy Bale
Are you a Samsung Camera Expert? Answer questions, earn points and help others
