Was reviewing some unanswered posts and came across your concern.
Should you still be interested, here is PVS12701 AC Adapter with Power Cord.
You can also try calling Target Customer Service
1.800.440.0680 and inquire cost & availability of the charger's cord for the
TruTech PVS12701B.
Additionally, you may want to contact the manufacturer direct.
ALCO Electronics, Inc.
8392 Six Forks Rd., Suite 104,
Raleigh, NC 27615,
(800) 252-6123)
Should you need direct Customer Support, please try here.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
The S2is runs on 4 AA batteries. These are removed from the camera and recharged in an external charger. Such chargers can be purcahsed cheaply and Walmart or your local supermarket. Look for NiMH rechargable batteries.
Hello, If
this is the case your Rechargeable batteries (built in) could have been
dead..and needs to be replaced.Normally they die in 2 to 3 years depending on the frequency of usage. But before taking it to a repair shop
,make sure you check
the power cord as well,because sometimes one of the lead cracks at the
point that it attaches to shaver for charging,which the power cord needs to be
replaced. If you wish you can describe the problem more details than I may suggest something else. Regards.
Try resetting the BIOS in case something happened to it.
Power down your computer. Remove the power cord, the rechargeable battery and the BIOS battery. Wait 10 minutes. Reinstall the BIOS battery, the rechargeable battery and the powewr cord. Restart your computer and enter the BIOS setup.
If nothing happens, your video card may have failed.
If working properly, model 5510 will work either from the internal rechargeable batteries or directly from the cord. If your shaver no longer recharges, it needs to have the rechargeable batteries replaced.
This link looks promising, but you may have to consider purchasing a new one, hopefully not! I would assume that this one has such a lower price than the rest and lists contents as "charger" so I assume it contains the charger only. Hope this helps buy power cord for Panasonic cordless Hair clipper ER152 Google Search
As have been posted here
and here of similar concerns...
You can try calling Target Customer Service 1.800.440.0680 and inquire cost
& availability of the charger for the TruTech PVS12701.
Raleigh, NC 27615,
(800) 252-6123)
Alternately, you can just look for an AC adapter/charger that has the following
specs:
Input Voltage - your country's standard AC mains;
Output Voltage - 12VDC
Output Current - at least 1.5 Amp (the higher the better)
Connector - one that will fit and match the polarity of the TruTech PVS12701.
(am guessing crown type center positive, pls confirm with the store. It may
also help to bring along the unit when doing the purchase over the counter).
Hope that this be of some help/idea. Pls post back how things turned up or
