Home | Sampo | PME-42S6 42 in. HDTV-Ready Plasma Television | Removing back stand sup...
Sampo PME-42S6 42 in. HDTV-Ready Plasma Television
Problem for Sampo PME-42S6 42 in. HDTV-Ready Plasma Television
Removing back stand supports
By narcan8 on May 14, 2009
trouble removing the back stand supports so it can be placed on a wall mount
Solution #1
posted on Jul 11, 2009
Not Rated)
lastrong
Rank: Apprentice
Rating: 0%, 0 votes
remove the 4 recessed screws that are in the mounts then slide the mounts upward and they should come off. the 4 screws need to be completely removed to allow the feet to slide.
Was this helpful?
Yes
No
Solution #2
posted on May 14, 2009
Not Rated)
rulds2008
Rank: Guru  Televisions & Videos  Expert
Rating: 86%, 1028 votes
First I am not to sure about the brand you got there, But if it is not wall supportable you do not need to reove anything but by a wall mount that will hold the bottom in place and yes there are wall mounts for this tpye of arrangment see not all flat panels go on walls thus hence you cannot remove the stand easy. Try finding a wall mount the has a L shape to it, it will hold the bottom of the tv and it comes with a little strap to hold it back into securement. Please do not try to remove the stand I would suggest a diffrent wall mount- Rulds2008 TV expert for 20 years
Was this helpful?
Yes
No
Popular Solutions for Sampo PME-42S6 42 in.
Questions and Unsolved Problems for Sampo PME-42S6 42 in.
Do you recommend Sampo PME-42S6 42 in. HDTV-Ready Plasma Television?
Answer
Answer
my sampo PME-42S6 ha trouble powering on. It will start (blue screen and hour glass appear the turns... (More)
Answer
we have had our tv 4 about 7 years and over the past few months it has been going red! basically if... (More)
Answer
The T.V has all sorts of pink lines and other distortions on the screen if you hit the side of it,... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sampo PME-42S6 42 in....:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
