Question about Xerox Phaser 8560MFP Laser Printer
Blurred Images I need to take out the encoder from my Xerox 8560 so that I can clean it and stop getting blurred images. How do remove it?
  • Xerox Contributor
  • 185 Answers
You don't need to remove it.
Remove the right cover, and the fan on that side. Partially remove the clear plastic cover of the encoder and go in with Isopropyl and Qtips.
Also clean the nearby wires and anything that could transport the oil
-Whit :)
Posted on Jul 31, 2009
How do I find Drum Encoder Disk on a Xerox 8560? I'm getting random blurring
To find the encoder, remove the right cover and remove the only fan on that side.
Loosen the clear cover and clean the encoder and entire area thoroughly, including the wires.
If the problem returns, you may need to purchase a whole drum 020K14790
Whit
Item, Inc
Aug 25, 2010 | Xerox Phaser 8560MFP Laser Printer
I'm getting blurred images. what will be the
Blur images can caused dirty lenses please clean the lenses if the problem persist then take to any service center and do cleaning of the internal parts as sometimes due to moisture this type of problems are created.
Feb 16, 2010 | Canon PowerShot A710 IS Digital Camera
Viewfinder shows blurred images
First, rotate the mode selector dial to "Auto", then check to ensure that you're not in macro mode. Also make sure that your lens is clean and there are no smudge marks.
If you've done all the above, and you're still getting blurred images, this then might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Dec 19, 2009 | Canon PowerShot A80 Digital Camera
My print jobs keep coming out with smears in certain spots and now the entire print job is blurred. I've cleaned it several times. How do I correct that myself?
If the entire page is blurred, it is probably a dying wave amp board. Time to start shopping because the repair bill is more than a new 8560.
Jul 08, 2009 | Xerox Phaser 8400 Laser Printer
I HAVE A XEROX 8560 THAT I AM GETTING BLURRED PRINT WITH, I DID THE CLEANING CYCLE AND THAT WORKED FOR A DAY AND A HALF. NOW THE FIRST TWO PAGES LOOK GOOD AND ALL THE REST ARE BLURRED?
Oil from the drum has ran off over the drum encoder position sensor.
Take the right cover off and find the fan. Remove it and loosen the clear plastic sensor cover underneatch. Clean the sensor and generally with Isopropyl and Q-tip.
Clean the nearby wires and anything that might be transporting more oil back to your sensor
Apr 16, 2009 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560
On the right side of the machine. There is an encoder mounted to the end of the drum shaft. They are known to become contaminated with the silicon lubricant from the maintenance kit. That causes the drum to spin off speed somewhat randomly. You can take it off the shaft and clean it well with alcohol. Sometimes they need replaced, but if it is as intermittent as you are suggesting cleaning it should take care of your problem. Not all that uncommon.
Feb 07, 2009 | Xerox Phaser 8560MFP Laser Printer
Phaser 8400 blurred print
If it is blurred, the problem is the drum motor encoder. It picks up the silicon lubricant from the maintenance kit, and once its gets contaminated it causes the drum to run the wrong speed.
What you have to do is remove the right cover, looking from the front.
Then locate the drum. Its about mid way back on the machine. The encoder is in that area.
If you go to Xerox.com, there is a parts list and diagrams located under drivers and documentation.
Look up the parts list and the Drum encoder to locate it. It is not real hard to find, or remove and clean. What you want to clean it with is alcohol. No no, Not vodka..... use a strong rubbing alcohol to break down the silicon and clean the encoder, then put it back on the machine.
It may need replaced, but the majority of the time, cleaning the encoder resolves the problem.
You may just want to write down the part number when you locate it, just in case you would have to order one. But I really believe cleaning it will resolve your problem. It does fix the blurrs about 80 percent of the time.
Sep 20, 2008 | Xerox Phaser 8400 Laser Printer
Phaser 8560 blurr
There is an encoder on teh drum motor that picks up lubricant from the maintenance kit and causes those blurs. It eneeds cleaned or replaced
Jul 11, 2008 | Xerox Office Equipment & Supplies
Fujifine pix A330 produce blurred image on all picture taken
continuous blurred images? or only occasionally (say in low light)?
Mar 30, 2008 | Fuji FinePix A330 Digital Camera
Xerox Phaser 8560MFP Laser Printer Logo
366 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
