Question about Lexmark X1150 All-In-One InkJet Printer
Black ink I CAN NOT GET MY BLAK INK TO PRINT,I HAVE SET AS MY DEFAULT,GONE THROUGHH SEVERAL TROUBLESHOOTING IDEAS.WHEN I PRINT THE TEST PAGE NO BLACK, I HAVE A LEXMARK X1150 CAN YOU HELP PLEASE
  • 62 Answers
Did you remove the tape from the cartridge when you installed it?
Has it ever printed black from this cartridge before?
You may need to wipe the cartridge with a moist paper towel at the place where the ink comes out. If there is dried up ink the nozzles could be clogged. Try running the Lexmark Solutions Center from the Windows Start menu (Start -> Programs -> Lexmark 1100 Series) and make sure the black ink level is good. You can also select "Clean Nozzles" in there and that may help.
Posted on Oct 16, 2007
SOURCE:
- I have just changed the black ink and now it wont print so I have changed the black ink again and it still wont print anything black - any ideas
The black ink nozzle in the print head might be blocked. Print a test page with a huge black image. Like: just start word, create a square through "illustrations" and fill it completely with black. Print it once or twice and see if finally the black ink may come out.
Through printer properties (windows control panel) there might be additional cleaning options.
Feb 24, 2015 | Office Equipment & Supplies
My HP C4780 PRINTER WILL PRINT A TEST PAGE BUT NOTHING ELSE. How do I get it to print?
Check the settings in Windows Print Manager.
Make sure that the paper quality matches what is in the printer. If set to glossy, minimal ink is deposited on the page. Also, check the print quality - draft quality provides a minimal amount of ink as well.
Jan 17, 2015 | HP PS C4780 All in One InkJet Printer
Black ink will not print
Have you tried setting the color to black cartridge only. You may be printing the black with a combination of colored inks. I occasionally have a similar problem. Sometimes I can get the black to work by taking a paper towel dampened with distilled water and holding it against the cartridge print head until I see black ink coming out. Replace the cartridge and try printing again. If this doesn't work try a new cartridge and run through your Printer Settings, making sure they are all set properly.
Mar 17, 2014 | Hewlett Packard Printing & Imaging HP...
Canon iP6600D printer keep printing in Blak ink only
1st option, set the default profile in the printer properties. if it doesnt work. this will change all the settings that you might missed to check to go back to factory setings. also, check if your color cartridge is ok and with enough ink and not dis abled
2nd option, run any 3rd party software that can fix some windows system files or something like that. try to scan pc for viruses
3rd option, reformat your pc. maybe windows files that allows your printer to work are having problems or corrupted, base on the thing that you mentioned that it goes back to the grayscale settings
May 27, 2013 | Canon PIXMA MP210 Photo All-In-One Printer
My black ink wont work.
refill of cartridge several times is not that advisable. time comes that ur cartridge will be damaged. possibility of damaged:
1. the circuit itself in the cartridge might be broken
2. overload of ink.
recommendation:
1. replace a new one or secure other cartridge w/ same spec of ur current cartridge.
Apr 08, 2010 | Dell 924 All-in-One InkJet Printer
New catridge's blak ink not functioning
your print head dirty. so tyr clean with wet close until recavered. if not better soak bottom print head with wram water until all dry ink gone.
Aug 10, 2009 | HP DeskJet F380 All-In-One Printer
My brother mfc-240c doesn't print black. I replace the black with a new cartridge as it still wouldn't print black. I also tried to clean all the colors numerous times, but to no avail. I don't know what...
Wow, something similar just happened to me the other day, my black ink ran out & when I replaced it, it just wouldn't print, I kept trying to print things and it sounded like it was printing but then it would just shoot out a blank page of paper (I was trying to print BLACK). So, I went to the Brother website for troubleshooting tips and it said to make sure I had the ink cartridges installed properly so I took the black cartridge back out (it WAS installed correctly, but I was willing to try anything at this point), so I took it out, gave it a blow, like how you would blow on the old Nintendo game catridges when they did not work-I'm not sure if this did anything at all but it's what I did) and then I put it back in). The machine asked if had just replaced black I said "Yes", then it did another "cleaning", as it does when you replace any cartridge. Then I went in the menu to have it print out a "test page" (the instructions for this were in the troubleshooting tips on the website), the test page printed out with NOT all the little black squares as IT SHOULD BE so when it asked me if the test page was ok, I said "NO", then it did ANOTHER CLEANING and I did another test page, this time it worked ok, then I was able to print.
So, bottom line is, maybe take the ink out, make sure you installed it correctly, put it back in, print a test page, if the test page does nto come out right, then tell it it is no good by selecting "NO", then it will do another cleaning and then maybe it will work, if not, then check for more troubleshooting tips on their website, good luck.
Jun 25, 2009 | Brother MFC 240C All-In-One InkJet Printer
3 issues, Will not print black but says still ink, now page shows amt gone and cannot find the ink when I open it.
Here are several documents that i want you to check to somehow solve the issue.
Step one: CLEANING THE INK CARTRIDGE: DOCUMENT
Step two: Checking Ink level : DOCUMENT
Setp three: Try replacing the BLACK INK CARTRIDGE.
adonscott
Jun 28, 2008 | HP Photosmart C3180 All-In-One InkJet...
Lexmark X1150 All-In-One InkJet Printer Logo
102 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
