Question about Kenmore 62602 Electric Dryer
62802 stops running after a few minutes
Dryer stop running after a few minutes. Somtimes I can start it back up and sometimes it tries to start when I push the start button but won't stay running.  Before it stop sometime it will make a squeeling sound at the back of the drum.
any info would be greatly appreciated
  • Anonymous Mar 16, 2014
    dryer starts, runs for a few minutes, then shuts itself off and not hot inside the drum
  • 114 Answers
It sounds as if you have a defective drive motor.  After the motor runs for a while and heats up, the internal thermal switch cuts it off before it gets too hot and becomes a hazard.  Once the motor cools down and the thermal switch makes up again, it will run and then repeat this process.
Posted on Oct 17, 2007
I have a DV42H5400 dryer less than a year old that runs for a few seconds than stops. No error code but the cooling light flashes. After a few minutes it repeats the process.
Clothes Dryer Stops and Starts ' HomeTips
Apr 23, 2015 - The dryer's heating element works and the motor runs smoothly, But it... and then running the dryer with nothing inside for a few minutes-if it ...
Sep 26, 2015 | Dryers
I have a maytag dryer that sometimes when I hit the start button will start and run for only a few minutes and stop and wont start again for a while and does a humming noise when it does star why?
Sounds like the motor is going into thermal overload (Getting hot) it may be caused by the motor itself, or could be overloaded by bearings or fan etc
Jul 28, 2014 | Maytag Dryers
When pushing the start button the dryer will come on for about 10 minutes and then stop. Then sometimes it doesnt come on at all
If it starts right back up after stopping there is an electrical problem maybe at the motor start switch. If you have to wait for an hour before it will start again then the problem might be that the motor needs to be cleaned of a lint build up.
Oct 23, 2012 | Roper RES7646KQ Electric Dryer
The Dryer started a dryer cycle but after few minutes stopped.
check your outlet for 220v but it is probably the thermal fuse that has opened up.
Jul 29, 2010 | Kenmore 62802 Electric Dryer
Turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Aug 31, 2009 | Kenmore 73952 Gas Dryer
Dryer will run for a second and sound three beeps and stops.
Sounds like the door switch has gone bad., but your description is confusing.
First, it takes a few minutes for you to feel the air blowing hot, particularly when the dryer is in a cold garage. The heating elements have to heat up the mass of the metal, and any clothes in the dryer.
The timer design is such that it can not speed up (the motor inside wont start running faster, due to it's electrical design.).
I am suspect that the door switch has failed for some reason, because reading between the lines, I think you are saying when you release the Start button, the dryer quits operating. If the door switch is bad, then it will cause that condition to happen.
Jan 18, 2009 | Kenmore 62802 Electric Dryer
Dryer stops after a few minutes of a full load.
You will have to replace the moisture sensor. The heat from the small fire may have damaged it. It's not that hard to do, but the part costs @$60.
Dec 16, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer won't stop running - Second try
The push-to-start switch is the easiest and cheapest to replace. You can check it by starting the machine then, unplug it, remove one of the wires from the switch, then plug dryer back up. Dryer should not start. If your model has an even heat board and two relays under the console, your problem could be with them if switch is not bad. Reply back if you need to know how to check them.
Sep 24, 2007 | Kenmore 62802 Electric Dryer
the dryer wont stop running only when open door will it start a fire?
Sep 14, 2007 | Kenmore 62802 Electric Dryer
Kenmore 62602 Electric Dryer Logo
333 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
