Question about Hitachi P42H401 42 in. Plasma HDTV
Colored wavy lines on screen
I have a 1 year old hitachi 42a01a plasma tv. after a few minutes the tv is turned on,color wavy lines appear across the whole screen which increase gradually in their intensity. soon the picture is barely visible as only this noise/lines appear on the screen. sound is ok. if I restart the tv it works for a few minutes and then the same probem occurs.
  • neeraj0272 May 15, 2009
    hitachi technician says that it is because of dust. he cleaned the main board and it worked for a month but the problem resurfaced. now he says that i have to replace the main board at one-third the cost of new set.
  • Hitachi Master
  • 3,866 Answers
This is a Logic board problem, not so easy to replace in Hitachi but well worth the repair if I had your zip code I could recommend a person or three. But the problem is a problem in the logic board and will beed replacement, Thanks for using Fixya.com
Posted on May 14, 2009
54inch Hitachi TV has double figures and colors red, yellow-not normal. Set approximately seven -eight years old. Lost remote control and direction book in moving. Is the set worth getting fixed? Generally...
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 11, 2010 | Hitachi 57F500 57" Rear Projection...
Have Panasonic TH-50PX60U HD Plasma. Purchased
Filter capacitors (more than 1) in the main power supply
May 02, 2017 | Panasonic TH-50PX500U 50 in. Plasma...
Wavy lines appear across the screen
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 01, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
Jan 26, 2009 | Televison & Video
All color guns out of alignment
Needs convergence amps replaced. Sometimes resistors burn and need to be replaced. This repair requires soldering/desoldering equip. and a trained eye, but usually can be done for 175.00-325.00 at a reputable service center. Good luck, Russmann.
Nov 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Vertical color lines
I had the same thing happen to me this morning. I turned on the TV and it had colored vertical lines through the whole screen. I called Sony and they had me unplug the TV for about 15 minutes. This solved the problem. They said the boards just needed to be reset. It fixed the problem and I am happy with my Sony once again.
May 22, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Long power up time, wavy "static" lines, and red/orange problems
part of it sounds like your coax cable is not connecting properly. pull it out and make sure the pin at both ends of the coax cable is straight if bent replace coax cable.
Dec 28, 2007 | Hitachi 32UDX10S 32" TV
Phillips 42in plasma lines ocross screen
Are the solid horizontal black lines or colored lines. If colored lines there is a posibility that your Y-main, and upper and lower Y-buffers are bad. If black you have a bad plasma panel.
Oct 08, 2007 | Philips 42PF9630A 42 in. Plasma Television
Color line across the center of a black screen
Hi. this is caused by dry solder joints on the frame o/p IC. Resolder all legs of frame chip. Should sort that out.
Sep 06, 2007 | Toshiba 32A60 32" TV
Hitachi P42H401 42 in. Plasma HDTV Logo
337 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
