Question about Frigidaire Dishwashers
Dishwasher is heating too hot and melting anything plastic
The heating element is heating up way too hot...anything plastic being washed starts to melt
  • steve
    steve May 11, 2010
    Anything plastic is not supposed to go into a dishwasher.
  • 1462 Answers
SOURCE: GE PDW9700 - Heating Element turns on by itself and Burns my dishes
have experienced this problem on some zanussi machines. what is happening is that the machine continues thro cycle thinking there is water in machine when there is not. can be caused by:
slow pump rate caused by blockage especially near the drain pump inlet
faulty pressure stat
Posted on Aug 21, 2008
THENTHEREWER
  • 131 Answers
SOURCE: ge pdw7880j10ss dishwasher lower roller
(http://www.geappliances.com/service_and_support/parts/)
the correct # for your unit is pdw7880n10ss
just enter your model #(under repair or replacment parts)the site will walk you thru the rest.when you get to the parts list make sure you use the diagram to match your part exactly(click the red box at top of page)hope this helps.thanx for using fix-ya!!!
Posted on Nov 29, 2008
  • 3 Answers
SOURCE: plastic melted on Dishwasher heating element
youll have to run a whole cycle again and pay attention to when the heating element comes on again. Once its hot the plastic will be soft enough to remove it with a tight cotton rag. Use you oven mitts for protection. Hope this helps
Posted on Dec 01, 2008
  • 10865 Answers
SOURCE: Frigidaire dishwasher heated dry way too hot
Wow. So glad to hear that you had no permanent damage.
Posted on Jun 19, 2009
  • 572 Answers
SOURCE: plastic spoon melted on dishwasher element ? can
id scrap it with a knife and a fine sand paper
Posted on Feb 07, 2010
Water not hot enough
Before you start dishwasher on your sink start the hot water then after you start dishwasher then you can turn sink off. Hopefully this will help.
Nov 17, 2013 | LG Dishwashers
LG LDS581 dishwasher HE error mid cycle
HEATING (ELEMENT) ERROR // Water heating error
The manufacturer has assigned this error or fault code to indicate a problem with the water heating circuit. Turn off the circuit breaker to the dishwasher for 30 minutes, allowing time for the appliance to cool; then restart the cycle. If error returns, check the heating element for continuity and check the wiring harness for any obvious signs of damage. If the heating element shows infinite resistance after testing with an Ohm meter, replace it.
Oct 01, 2017 | LG 24 in. LDS 5811 Built-in Dishwasher
Our dishwasher started smelling like something is burning, I turned it off straight away, no visible smoke or anything but it hasn't been cleaning very well for a while now. Are these the death throes? Or...
Make sure there isn't any plastic on the heating element. Also check to see if there is any evidence of previously melted plastic. If it smells like plastic burning & you aren't using any heated options, cut the power & call for service.
Mar 27, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
My dishwasher isn't working, it fills with water then doesn't do anything. The water doesn't seem to be hot. Does it need to be heated before starting the washing action?
Try running your sink water till it's hot and then running the wash cycle. Not all washes have a quick heat element.
Dec 23, 2010 | Dishwashers
I a Westinghouse dishwasher 920 and a plastic spoon fell onto the element while it was on and its melted the spoon on the heat element and i cant remove it. how do i replace the element i am a motor mech...
Break as much of the plastic off as you can and just let the rest melt off or melt it with a solder gun . won't hurt anything. If you want is easy to replace just hall machine from hole and tilt back remove the wires and the nuts holding it on .
Dec 03, 2010 | Westinghouse Dishwashers
Plastic is melted onto the heating element. is this a problem? what should i do?
I am assuming the dishwasher is not working.
You will need to check where the plastic has come from. The temperature has to be very high for the plastic to melt. This can happen if the dishwasher heater has been on with no water in the dishwasher. Normally the controller should not allow this. Also the thermostat should cut in to prevent the temperature from going high.
Most likely it is not plastic but a problem in the wash pump which is causing some residue to circulate in the water and deposit on heating element.
In any case, try to scrape off as much of the material as you can and then run the dishwasher with a Finish dishwasher cleaning kit. The instructions are on the kit label.
Hope this helps. Please rate the solution.
Oct 10, 2010 | Jenn-Air JDB6510 Built-in Dishwasher
Dish washer gets to hot in pot scrubber mode
did it distort the spray arm? A lot of times if it's the spray arm that melted it's possible that it was jammed while trying to heat the water and the heat from the element would warp it.
Mar 24, 2010 | Frigidaire PLD4375RFC Dishwasher
Frigidaire hot water problem
no, i don't think so. the heating element is located under the inside tub and out of the dish area. if you could supply me with the make and model #, I will try and find the exploded view for you. the element is replaceable.
Dec 11, 2008 | Dishwashers
Plastic melted on Dishwasher heating element
Dec 01, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Aug 21, 2008 | GE Profile PDW8400J Built-in Dishwasher
Dishwashers Logo
41 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
