Question about Lexmark X2500 All-In-One Printer
I have a lexmark all in one and was trying to make a copy
The copy came out blank, last time I used my printer or copier was in JAN 2009 worked fine then?
  • Lexmark Expert
  • 228 Answers
It seems there is a possibility of a problem with the printer itself, or perhaps the cartridges. You should first self-test the printer. Since we are unsure where the problem exists, we must do eliminative troubleshooting to rule out parts of the printing system. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.
Please disconnect and then reconnect the power supply on the printer and make sure it makes a setup noise when the cable is reattached. Will the printer perform a form feed with paper loaded when the purple/silver button is pressed?
Next, I'd like you to attempt this printer self-test by following the steps given below:
1. Make sure the printer is off.
2. Press and hold the "Color Copy" button.
3. While holding the "Color Copy" button, press and release the "Power" button to turn the power on.
4. Wait for the "Power" light to flash off and on.
5. Release "Color Copy" button.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know.
Posted on May 14, 2009
A neighbor just gave me this printer...It says low
If you don't want to spend money on ink the a Lexmark is the last printer you need. It's cheaper to buy a new one!
Dec 28, 2009 | Lexmark X7350 All-In-One Printer
My printer is malfunctioning. nothing prints
It is likely clogged nozzles in the ink cartridges. Try the nozzle cleaning utility in the Lexmark Solutions Center (installed with the drivers) several times. If it does not correct the problem, but you can get even the faintest lines to print, you will have to replace the cartridges. If it doesn't help at all, you could always try replacing the cartridges anyway.
I know they are expensive. So if it helps, The Fine Print offers refurbished cartridges for a lot less and will even give you a little credit to recycle your used-once cartridges.
Jun 11, 2009 | Lexmark X6170 All-In-One InkJet Printer
Copies are blank
This is most probably a problem with the laser unit on the printer. Try cleaning/replacing it. You will need to take it to a reair agent.
May 19, 2009 | Panasonic DP-150FX Laser Printer
Carrier Jam(lexmark x5320)
In this case unplug the power supply from the Printer........... 1. Open the Printer Cover.......... 2. Remove both the Catridges from the Printer............ 3. Move the Catridge Carrier which holds the catridge from right to left and from left to right for about 10 times............ 4. Try to make a copy without the catridges........If this works and it gives a Blank Page out............ 5. Insert both the catridges turn the printer off and turn it on again........... 6. Now it should work fine........ Good Luck......
Jan 22, 2009 | Lexmark X5470 All-In-One InkJet Printer
Posted by rhung33 on Jan 16, 2009 Under Window DOS prompt and Unix Sun Solaris 8 Station , using LPR -p command to print txt file to cause Lexmark T644 printer '' Flushing buffer '' and...
The printer can't handle the data it received and flush it out of its buffer. Goto Menu->Settings->Postscript Settings and turn "Print PostScript Erro" on. When the same print job prints, you should get a page printed out telling you what the printer doesn't like. You may also want to try forcing the printer into Postscript mode. Your PS file probably contains a PJL to set the device to PS mode before it prints. When the printer expects PCL data and received PS data(or vise versa), you can get this behaviour
Jan 16, 2009 | Lexmark T644 Laser Printer
MP870 won't copy.
Try cleaning the heads and check print head allignment on the printer, this can usually be done through the printer software or your pc settings
Aug 21, 2017 | Canon PIXMA MP780 All-In-One InkJet...
When l print paper is blank,when l copy its ok
hey scousemanc
well do one thing make a fresh installation again . go to www.lexmark.com download the drivers.
after installing it , do self test in the printer . if you go to menu options in the printer u will get self test option.
either wise try use different USB port , and make a fresh insatllation, and chekc it
Feb 07, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X2500 All-In-One Printer Logo
123 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
