Question about Alpine PDX-1.600 Car Audio Amplifier
Alpine pdx 1.600keeps cutting out
I have a mono alpine pdx 1.600, When is on low, its good, But when you turn up the volume, and keep it high, it will cut out after a a couble seconds, The sub can hold 500 watts, and the amp is capable of seding 600 watts. The mono is hooked up to a capacitor whitch is hooked up to a four channel amp, Could the ground be the problem?
thank you
chuck
  • Sphynkter
    Sphynkter May 11, 2010
    Hi Chuck,
    What is the size of the power and ground cables going to and from the amp and capacitor? What is the load in ohms coming from the sub? If you don't know, tell me what kind of sub it is and how you have it wired to the monoblock. When the amp cuts out, is the amp very hot? Does your capacitor have a voltage display on it? if so, what is the voltage with the car running and the stereo on?
You need more batt, more amps, try new batt, capacitors are paperweights, spend on good batt.
Posted on May 14, 2009
I have this subwoofer eclipse 800 watts peak, 8 ohms , and i would like to know if the alpine pdx m6 can deliver 600 watts rms at 8 ohms too, o just at 4 o 2 ohms, i will appreciate your help.
No. It is optimized to deliver 600 watts onto either 4 or 2 ohm loads but will decrease to 300 watts into 8 ohms. However that equates to only about a 3dB difference in output level from the sub. 3dB is the smallest amount of volume difference the human ear can pick up. A doubling of volume requires a9dB increase which requires a tripling of input power.
Aug 09, 2016 | Alpine Car Audio & Video
Amp will play at low volumn but not when turned up
probably.
almost sounds like your speakers are worn out, and when you turn the volume up, they clip n no sound comes out.
Jul 31, 2010 | Alpine PDX-4.100 Car Audio Amplifier
My alpine clips out at high volume I took the subs out and hooked um up outside of the car and it was working fine. do I just have a short in a ire or is this the pdx 1000 safe mode. How can I get it fixed
Go to rockfordfosgate.com they have a woolfer wiring wizard that can help you make sure your amp is under the correct ohm load, if your woolfers are wiring up on a 1 ohm stable load the amp will overheat and go into protection mode and cut out.. Need the woolfers on a 2 or 4 ohm stable load, and the amp should run fine with a capacitor, and some good 0 to 2 guage cable, plus a good battery and alternator to feed it
Oct 09, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Pdx 4.150 amp suddenly cuts all sound from the amp when music is played loud/normal for me, unknown reason it just started doing it, I didnt change or add anything to cause this issue. All power and ground...
ALL THAT IS NOT YOUR PROBLEM CHECK ALL YOU POWER SOURCE AND IF ALL OK CHECK TO SEE IF ANY SPEAKER IS BAD OR GROUNDING OUT'' THE CAN COURSE THAT TO HAPPEN AND CHECK MAKE SURE RCA IS NOT PINCH ANY WHERE
Aug 05, 2009 | Alpine PDX-4.150 150W x 4 Car Amplifier...
Alpine PDX1.600 amp cuts off
Make sure there's no missmatched impedance. If your sub running 2 ohms then your amp has to be 2 ohms stable. Does the amp blow fuses or get really hot? If it does it can be a fire hazard and I would recommend taking it out of your car. It could be that you don't have sufficient grounding. The grounding needs to be very close to the amp and the paint needs to be thoroughly scratched off. Otherwise could be a blown transistor within the amplifier, you can check this by opening up the amp, running a multimeter and testing the transistors for resistance.
Aug 04, 2009 | Alpine PDX-1.600 Car Audio Amplifier
Alpine pdx 1.000 keeps cutting out
You are going to want to make sure all your power wires and grounds are 4 gauge as well as the wire leads to and from the capacitor-4 gauge also. make sure you have a very good ground - the power wire from the battery should hit a distribution block-from the dist. block a 4 gauge should go to the capacitor another 4 gauge to the mono amp and another to the 4 channel amp -every component should have a good solid ground even if you have to bust out a grinder and a drill and some self tapping sheet metal screws and go nuts on it- see if that helps you
May 26, 2009 | Alpine PDX-1.600 Car Audio Amplifier
Alpine PDX 1.1000 low power output - sub not loud
system not configurate properly go to a pro and let them do for you you have good equipment just need to put together rite.for wht you have you can get better sound than that,,good luck
Mar 30, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
My subwoofer stops when volume is increased
have u check the radio out do u have an eq
May 19, 2008 | Kicker CVR12 Car Subwoofer
PDX 4.100 In Protect Mode..
According to the manual, the issue could be:
  • Internal issue with the amp circuitry.
  • A short on the speaker output(s).
  • Power source voltage is too high (aka above 14.5V).
  • Overheating.
The easiest thing to do is to try removing the connections to the speakers at the amp and see if the issue disappears after each set has been disconnected. Keep removing wires until both LEDs stay blue.
Mar 15, 2008 | Alpine PDX-4.100 Car Audio Amplifier
Alpine PDX-4.100 3ch operation
use channel 1 and 2 as normal, use the positive from channel 3 and the negative for channel 4 as mono 1ch, your bridged output on the mono chan should be around 200watts at 4ohms.
Nov 25, 2007 | Alpine PDX-4.100 Car Audio Amplifier
Alpine PDX-1.600 Car Audio Amplifier Logo
350 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
