Question about Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook
Fuse values for PC's
I'm doing the level 2 certificate in maintaining ICT equipment and systems one of the main things i have to know is what value should be used for the power plug for my PC's base unit and monitor as i have to keep a system electrical safety inspection sheet.  I have to calculate the value of each fuse and enter the values.  But i don't know the values.
    Problem Solver:
  • 12 Answers
I'm not sure that I understand your question..if you are referring to the AC  power at the receptacle or what.
If you are asking what value fuse should be used for plugging in particluar equipment then you need to know the source VOLTAGE,  AMPS used bt the equipment and do a current calculation.
Google on the "electrical power triangle" or POWER FORMULA and you can see the formulas.
Posted on Oct 15, 2007
Defender 200 tdi difflock switch where is the fuse situated and what value is it please
This website has books on how to service, repair, operate, maintain etc, any vehicle, heavy equipment and you can find all wiring diagrams, engine, electrical, torque settings, error/fault codes, PCV, removal, installation, assemble etc, a lot more.
Try it
www.reliable-store.com
Jun 06, 2018 | Cars & Trucks
Tip
Adjust the level 2 cache setting
  1. Here'show:
    1. Launch the Registry Editor (Regedit.exe).
    2. Go to HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlSession ManagerMemory Management.
    3. Double-click SecondLevelDataCache DWORD value.
    4. Using the options below, change the value in the Value Data text box to a number that matches the size of your Level 2 cache. Then click OK. Level 2 cache Value Data setting
      256 KB 0
      512 KB 200
      1024 KB 400
    5. Click OK and close the Registry Editor.
    You may need to restart the system or log out of Windows XP for the change to take effect.
on Dec 16, 2009 | Computers & Internet
I don't know how to graph absolute value functions on Casio fx-9750GII.
When it is time for you to put an expression in absolute value, press the OPTN key, then F5/Num, then F1/Abs. Open parenthesis, input expression, then close parenthesis.
For fractions, use the key with the symbol a b/c.
A little friendly advice, please do invest some of your time reading the manual. Most Casio graphing calculators work the same way. What you learn on one, works on another.
Aug 19, 2017 | Casio Office Equipment & Supplies
Security fuse 1999 pontiac bonneville
Need a little more info . Security fuse ????? Do you mean anti-theft ? The SECURITY light is lit on the instrument cluster ? Content theft or vehicle theft ?
Vehicle Theft Deterrent (VTD) Description
Ignition Key
The ignition key for vehicles which are equipped with the PASS-Key® II system consists of the following components:
• A typical square ignition key blank
• A resistor pellet
The PASS-Key® II ignition key has the same mechanical key cuts as a non-PASS-Key® II ignition key. You can not service the key blank and resistor pellet separately. There are 15 different ignition key assemblies, each with a different key pellet resistance value.
When you service the PASS-Key® II system, obtain all ignition keys. Verify the proper key code values withJ 35628-A Interrogator.
Steering Column (Ignition) Lock Cylinder
The steering column (ignition) lock cylinder that is used with the PASS-Key® II system contains a set of electrical terminals. The terminals are used to contact the resistor in the ignition key.
The wire routing for the contacts inside the steering column is very critical. When you service the lock cylinder, maintain proper wire routing.
When you replace a steering column lock cylinder, make new keys. The new keys must match the following items:
• The PASS-Key® II code of the PASS-Key® II system
• The mechanical cut of the new steering column (ignition) lock cylinder.
Measure the resistance of the pellet on the key , go to radio shack an buy a resistor of same value an solder into wiring harness .
pulling fuse won't work , power's the PCM as well . Plus software in the PCM won't let it start if it doesn't see input signal from the Theft deterrent module .Take an get it fix right .
Feb 23, 2017 | Pontiac Cars & Trucks
Where can I find the cruise control fuse on a 2008 hhr
The odds of a fuse being the problem with a non operating cruise control are astronomical . Knowing how the cruise control works is a must in trouble shooting . The different modules involved ,the GMLAN serial data network etc... Here is the factory repair manual description .
Cruise Control Description and Operation
Cruise control is a speed control system that maintains a desired vehicle speed under normal driving conditions at speeds above 40 km/h (25 mph). Steep grades may cause variations in the selected vehicle speeds.
The following are the main components of the cruise control system:
The accelerator pedal
The brake pedal position (BPP) sensor
The body control module (BCM)
The cruise on/off switch
The + RES switch (equivalent to resume/accel switch)
The - SET switch (equivalent to set/coast switch)
The engine control module (ECM)
The clutch pedal position (CPP) sensor, if equipped with a manual transmission
The throttle actuator control (TAC) motor
The vehicle speed sensor
The body control module (BCM) monitors the signal circuit of the cruise control switches, which are located on the steering wheel. The BCM relays the cruise control switch status to the engine control module (ECM) via the GMLAN serial data circuit. The ECM uses the status of the cruise control switch to determine when to capture and maintain the vehicle speed. The ECM monitors the vehicle speed signal circuit in order to determine the desired vehicle speed. The ECM uses the TAC motor in order to maintain the vehicle speed. For further information on the TAC system, refer to Throttle Actuator Control (TAC) System Description for the 2.2L engine or to Throttle Actuator Control (TAC) System Description for the 2.4L engine.
Ignition voltage is supplied to the cruise control switch from the 2-ampere EPS fuse located in the integrated BCM fuse block. The cruise control function switches are arranged in a resistive ladder design, with each cruise control function switch having a different resistance value. The BCM detects a specific voltage value that is associated with the cruise control function switch being activated. When the normally open cruise control on/off switch is turned ON, the switch closes and the BCM sends a GMLAN serial data message to the ECM indicating that the on/off switch is active. Similarly, when the normally open + RES switch or the normally open - SET switch are pressed, the switch closes and the BCM detects the predetermined voltage signal on the cruise control switch signal circuit. The BCM sends a GMLAN serial data message to the ECM indicating that the + RES switch or the - SET switch is active. The + RES switch or the - SET switch will remain inactive when the BCM has not received the predetermined voltage signal from the on/off switch.
Unless the air bag light is lit too , your best bet would be to take your vehicle to a qualified repair shop.
Aug 09, 2016 | 2008 Chevrolet Chevrolet HHR LT
Value of Schwinn bike #S4973TGA
Value is dependent on type of bike (esp. # of speeds), equipment level and mechanical/paint condition. Check Craigslist for similar bikes. Serial number is not helpful - need model of bike.
How to determine the year value etc of your bicycle
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Apr 04, 2016 | Schwinn Cycling
1 dollar silver certificate
www.antiquemoney.com/value-of-1-silver-certificate/
Jun 24, 2014 | Event Planning & Celebration
How to fix remote connection?
It depends on the problem you are having.
Most often remote connection problems are caused by firewalls
Are you trying to connect across the internet or are your two machines on the same LAN.
Are you only running windows firwall or do you have a third party firewall installed.
I suggest you run off the firewalls first and try to connect on the LAN and then add things back in one at a time until you solve the problem.
There may be more than one thing blocking you.
I hope this helps
Sep 10, 2009 | Microsoft Windows XP Professional
Whenever I open yahoo, the home page opens but if i try moving to the next page it brings a message certificate error"navigation blocked".The same problem happens in facebook but all other websites are...
when u see that error clik on it and view certifacate then u can install from there its very easy then close interent explorer and open again then it not need certificates.
Jun 04, 2009 | Computers & Internet
Calculate the value of pi
#include <iostream>
int main(int argc, char *argv[])
double arctangentOfOne = 0.0;
for(int i=0; i < 1000; ++i, std::cout << 4 * arctangentOfOne << std::endl) arctangentOfOne += (i%2==0?1.0:-1.0)/(2*i + 1 );
system("PAUSE");
return 0;
Jan 15, 2009 | Microsoft Windows XP Professional With...
Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook Logo
78 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
