Question about D-Link DHP-301 Transceiver
Open the frequency from 137-173mhz in th-th-k2e transceiver
I have th-k2e transceiver (kenwood) i need to open the frequency from 137-173.995 MHZ by diagram or feature
now only 144-145.995mhz
best regadrds
  • kenwoodptt May 16, 2009
    spark9 you sent wrong picture
    i need for handheld radio kenwood TH-K2E not for station radio
    TH-K2E OR TH-K2AT IT'S SAME
    its very bad solution? may handheld radio is kenwood TH-K2E i can transmission frequency on the 144-145.995 only
    i need to use it for all frequency ( i mean the transmission frequency start from 137-173.995HMZ) IS IT CLEAR?
    and i paid already 9.99 dollar
    what i will make in my radio radio for get all frequency 137-173.995mhz with clear pictures or clear diagram.
    best regards.kenwoodptt
  • 202 Answers
Google mods dk look under kenwood modifications. you will have to join membership is free basis a fee for premium downloads. you can get this mod free.
Posted on Jul 23, 2009
How to modify kenwood th234 from channel mode to vfo mode?
[PDF]Page 1 INSTRUCTION MANUAL KENWOOD ...
manual.kenwood.com/files/B62-0790-10.pdf
o Contains 60 memory channels programmable with desired frequencies and ... o Do not modify this transceiver unless instructed by this manual or by ... BASIC TRANSCEIVER MODES . ..... 1 Press [VFO] to select VFO mode. P1'I switch, and ...
[PDF]INSTRUCTION MANUAL - Kenwood
manual.kenwood.com/files/TH-D7-English.pdf
memory channel to be named using up to 8 ... Do not modify this transceiver unless instructed by ...... In VFO or Memory Recall mode, use the keypad to select a ...
Modifying the Kenwood TH-78a handheld transciever
www.welcomehome.org/rainbow/.../kenwood/kenwood-th78-mods.html
Nov 17, 1995 - (When William's early-model TH-78 was upgraded his mods (removed .... channel (if in memory recall mode) or last frequency (if in VFO mode).Missing: th234
Dec 21, 2015 | Phylrich Mirabella 3/4 Inch Thermostat,...
Why does my kenwood TH-K2 fm transceiver will not transmit
Users Manual (download if you don't have it)
TX I
NHIBIT
You can inhibit the transmission to prevent unauthorized
individuals from transmitting, or to eliminate accidental
transmissions while carrying the transceiver.
1 Press [MENU].
2 Turn the Tuning control to select Menu No. 25 (TXI).
3 Press [MENU].
4 Turn the Tuning control to select "ON".
5 Press [MENU] to store the setting or [PTT] to cancel.
"TX INH" appears and an error beep sounds if the
transceiver tries to transmit while TX Inhibit is ON
May 11, 2014 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
Communication not good &battery cannot charge
If your area is big or has a lot of concrete, then you will need more then just a few cheap radios from thailand, Given range info from broshure is always meant above flat area - not inside building
Sep 23, 2009 | Motorola Walkie Talkie 2-Way Radio
Open the frequency in th-k2e from 137-173.995 MHZ
might check dxmods.com that site has great mods for most transceivers
May 14, 2009 | D-Link DHP-301 Transceiver
Some bands OK some not. No transmit, no readout on some.
reset all settings to factory defualts.
If then still problem arise problem is there is some difficulty in demodulation of high frequency signal u have to change the receiver.
Mar 31, 2009 | Radio Communications
My th-79a shows channel numbers only
RTFM Page 29
Press [BAND] + POWER ON to toggle Channel Display
Gerard - PE1OUD
Mar 04, 2009 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
Unlocking Kenwood TH-22AT
http://www.radiomods.co.nz/kenwood/kenwoodth22.html
Dec 20, 2008 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
Motorola and Kenwood compatibility....
Hello!! First of all, any radio in the right frequency will work with any other, to work just need the following features: -Frequency, 154.700 which is correct as you said. - the Squelch code, this could be PL or DPL. The XV2100 has a table of codes that you can try, as you dont know this code form the Kenwood, you will need to check one by one. If you have the chance to send the Kenwood to some to "Read" the radio parameters( freq.,Code, ETc) you can look those parameters on the XV. Hope this can help, any comments neto-rola@hotmail.com Good Luck
Jan 20, 2007 | Motorola XV2100 (1 Channel) 2-Way Radio
D-Link DHP-301 Transceiver Logo
1,377 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
