Question about Apple iPod nano
Water in my ipod no longer works
Wter in my ipod any advice
    Scholar:
  • 34 Answers
I recently fix the same unit (my mother dove in a pool with it on). The trick is, you wil have to open it up and dry it out. If you are willing to do this, just google opening a nano and you can see tips on how to open the back plate while minimizing damage.
Once opened you have a few options:
- shake out whatever water you can
- use a hairdryer for 10 mins or so to blast warm air in there to dry it more
- put it out in the sun for a few hrs on a towel
The more innards you can take apart the better as you will want to make sure that no contact points have oxidized (eg back of the wheel, battery contacts etc).
Hope that helps. If you are not the DIY type, then you could try a repair shop, but some may tell you just to replace it.
Posted on May 14, 2009
Low water pressure
Copy following link for low pressure troubleshoot.
Requires water pressure gauge on water heater drain valve
http://waterheatertimer.org/Low-hot-water-pressure.html
Apr 21, 2013 | Water Heaters
Shuts off and light blinks looks like a water bucket that flashes
Check the wter tank it must be full and needs emptied before the unit will continue to run. If your runnig a drain hose, then the hose may be plugged or the float switch for the bucket is either hung up or malfunctioning.
If this was helpful a vote with the thumbs up would be greatly appreciated for the free advice.
Thanks and if you need more let me know.
Aug 23, 2011 | Sovereign ARP-1000E Air Conditioner
Gldl500mobb wter not draing from bottem of unit
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Feb 21, 2011 | Maytag Dishwasher
My kid was playing with it and now i cant unlock my screen
Hello :
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod.
good luck .
please rate !
Mar 30, 2010 | Apple iPod nano 3rd Generation
Spin cycle is the only that works
Check for water supply for proper fill. Then other timer circuits.If wter gets filled, fault may be with the water level sensor/wire.
Mar 28, 2010 | KitchenAid KAWS750L Top Load Washer
Not clear how the water works - does it need access via a tap?
wter line needs to be installed to provide water to water feed valve located in back of refrigerator,usually a blue component requiring a 1/4 in. connection recommend a copper line vs.plastic
Mar 10, 2010 | Refrigerators
No hot water entering tub
shut off water to washer,remove the hot wter hose,turn water back on,if water comes out of the hose you have a bad water valve on the washer part number 285805,very easy to change
Feb 21, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Water dispenser not working
See my earlier post of 6-4-09 for the solution to this problem. There is a GE part you can buy the solves the problem. It is part #WR49X10173 -- it's called a "Dispenser Water Tube Heater Kit". The part costs $32-35. GOOD LUCK!!
Apr 12, 2009 | GE GSS25SGPSS Side by Side Refrigerator
KITCHENAID MODEL KSRJ25CNST-00 FRIDGE QUIT MAKING ICE WITH OUT ANY WARNING. WTER IS WORKING.
I have this model and it has stopped making ice for two different reasons. These solutions may not fix your particular problem, but they worked for me.
Problem #1: the water inlet to the ice tray is frozen shut.
Solution #1: Raise the door that hides the ice tray. The water inlet is the black rubber nozzle on the right-hand side that points down into the ice maker. Squeeze the rubber nozzle between your fingers to break up any ice that may have formed inside the nozzle. This will clear the water path into the ice maker. Lower the ice tray door.
Problem #2: an ice cube is stuck in the ice tray.
Solution #2: Raise the door that hides the ice tray. Look for any pieces of ice that were not completely ejected from the ice tray - they are usually partially ejected and are very easy to see. Carefully (but it may require a good deal of force) remove ice cube from tray. Lower the ice tray door.
I hope this helps.
Aug 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Apple iPod nano Logo
51 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
