Question about Motorola Mobility RAZR V3i Cellular Phone
My Motorola V3i Buetooth will not connect as is it permanently busy.
I cannot use my V3i bluetooth function as it always return message "link is busy" everytime I try to pair, search new devices, or even power off the feature.
  • 490 Answers
Try to use the service after removing the memory card and than try, if the same problem presist than the problem is with the BT connector, it will be solved by any local vendor nearby u, and if it works after pluging out the memory card than format the memory card once and than try...... take the bacup of ur data first.
Posted on Oct 19, 2007
I cant listen to music connecting my bluetooth
check out that is the phone's bluetooth is properly paired with the bluetooth headset if not check it
search for the bluetooth devices from the search list of the bluetooth devices in the bluetooth menu of your phone
Mar 09, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Bluetooth powerfailed
try a reflash of the firmware on teh phone to correct this issue
Oct 29, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola V3i phone tool free download
what I need to know is where can i get free download for Motorola V3i phone tools to use my phone as a modem. Thanks. Richard.
Jul 14, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Bluetooth link busy
Try it with another BT and see if still shows the same.....if it does, then you might need to reset your phone....refer to user manual on how to reset phone. And if it worked fine with another BT device, then you might want to exchange/repair the jawbone....try this first, drain the battery completely from the jawbone, then recharge it and try to connect after charging..
Best of luck....
Jul 13, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola RAZR V3i Camera Problem.
Hey cmxa,
It is possible that the flex connection in the phone has become loose. (seems to be a common problem with the v3's) Or worse, your camera module has gone bad. Is the unit still under warranty? Send the unit in for repair, and they should be able to resolve it quite quickly.
Hope this helps,
Mar 29, 2008 | Motorola Mobility RAZR V3i Cellular Phone
"busy" camera
it sounds like its a software problem
Jan 21, 2008 | Motorola Mobility RAZR V3i Cellular Phone
V3i as modem
yep simply attach the cable start your motorola ponetools and tada you are done
Nov 18, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Bluetooth link busy
how can i get my h700 bluetooth to stop saying bluetooth link busy ?
Nov 10, 2007 | Motorola Mobility RAZR V3
Bluetooth connectivity
Bluetooth doesn't shut off on its own unless you turn off your phone. In the bluetooth options, you should be able to select "Turning Bluetooth On", "Turning Bluetooth Off", or "Using Discovery Mode (60 seconds)." Discovery Mode, which I believe is what your using, is only used when connecting to another device. My question for you is, what kind of device are you trying to connect to?
Sep 05, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Bluetooth failure
pleace select your bluetooth in your menu and you see bluetooth turn on for fuw minits or scoend set it for long time then start file copy
Jul 19, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
61 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
