Question about Whirlpool Washing Machines
Whirlpool awo3761 how do i claen the pump
My whirlpool awo3761 is registering fh on the digital display and telling me to clean the pump. How do i do this?
  • Whirlpool Master
  • 3,361 Answers
Remove the lower panel on the front of the washer. The pump will be just inside. Twist the pump knob to unscrew. Clean it. Replace it.
Posted on May 14, 2009
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Water coming from hole in front of pump filter it is a whirlpool 6th sense model awo3761/5/S
First you can loose the pump filter and there will on flat shaped line will be present in it in the filter just insert it then try to thread it it will be easily closed
Feb 16, 2010 | Whirlpool Washing Machines
Whirlpool AWO3761
hi we have a whirlpool awo3761/5 when wash is selected it goes to start but then doorlock flashes a nowt happens, i have just replaced with new doorlock this morning and with fingers crossed tryed again it looked promising but doorlock started to flash again and nothing happens pls pls help
Sep 07, 2009 | Whirlpool Washing Machines
I have AWO3761 and increasingly frequently the clean pump light is lighting up and FP is diplayed during the wash cycle. The machine is still full of water so I empty it and take the filter out which is...
check your drain hose sometimes coins get through the filter and get into the hose also the pump may be bad the impeller sometimes break and it will not pump out the water
Jul 11, 2009 | Whirlpool LTE5243D Top Load Stacked...
Clean pump
front load washers have a catch basket befor the pump that is easly removed be hind the lower pannel allways un plug appliances be for removeing any covers sears and partselect have some diagrams that may help you will need the model #
Jul 01, 2009 | Washing Machines
F H displayed on front
it means no water is entering unit,,,check hot and cold hose,,,clean your inlet screen ..look for a kink in your hoses,,also check and make sure water is leaving unit,,if water isnt leave than ,,unit will not let water in ,,in case of an overfill..if you need help cleaning pump filter let me know...onthejob
Jan 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
We have a whirlpool 6th Sense AWM 6145/3 which has just started stopping during the wash cycle and on the digital display the letters F H come up. We rent our property and have moved several times and have...
FH is the code for no water flowing in...
is there water flowing in?
if there is none, the water solenoid is the problem,
if there is water going in, then the flow switch is the problem.
here is the transcript from the web..
FH ERROR CODE
If after 30 seconds the control does not detect water entering machine and then valves
will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow sensor has
detected 48liters of water passing through it, but has not detected the pressure switch
trip, the valves will be turned off and the error code will flash.
and here is their solution
water source opened
flowmeter
pressoswitch
wiring to valves, pump,
flowmeter, pressoswitch
hoses
either one of those parts...
tnx 4 using fixya,
drcool
Sep 13, 2008 | Whirlpool Washing Machines
Help with whirlpool awm 8103/1
You probably need a new heater element
Nov 25, 2007 | Whirlpool AWM6120 Front Load Washer
Washer will not complete a cycle
hi,
i have a whirlpool 6th sense washing machine, it has come up with clean pump, does anyone know where the pump is on the machine, as i have lost my instruction manual.
regards
jackie
Nov 08, 2006 | Whirlpool AWM8143 Front Load Washer
Washing Machines Logo
330 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
