Question about Hobart Dishwashers
Conveyor runs for under two minutes,stops,upon restart control fuse blows
Conveyor runs for under two minutes and then stops. upon restart the control fuse blows.
  • 640 Answers
What is the make and model?
Posted on May 16, 2009
Why is my GE Advantium SCA2001 blowing the main fuse?
Yeah pal, you've not gone deep enough yet. You'll find a power wire bare inside the unit, pull it apart and tape that wire up to stop it from grounding out and blowing the fuse.
Aug 31, 2014 | GE Microwave Ovens
AC blowing warm air after restart in my S8
LET YOU TECHNICIAN MEASURE THE GAP ON COMPRESSOR CLUTCH.IS COMMON IF THE GAP IS TO BIG COMPRESSOR ENGAGE LATE.AFTER 2-3min.
LOCATE THE SENSOR FOR CABIN TEMPERATURE AND MAKE SURE IS NOT DUSTY . LET THE DEALER PLUG THE SCANNER AND READ THE LIVE DATA BEFORE START THE CAR.BAD OR DISCONNECTED SENSOR WILL READ -40*F. SELECT LIVE DATA AND WILL SEE THE SIGNAL FRO THE BODY CONTROL MODULE TO A/C RELAY(ON / OFF)
ENGINE DATA IS IMPORTANT TO. A/C CUT OFF ON OVERLOAD FROM ENGINE,POWER STEERING,ETC
Mar 29, 2014 | 2009 Audi A8
I changed the engine oil, filter and spark plugs in my 1999 Volvo 940 (1996 cc). Upon starting up, the engine runs at lower rpm and "hiccups" at idling.
Engine stalls or RPM fluctuates at idle up and down.
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve but always run a OBD2 fault code as well as the cleaning procedure. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Oct 15, 2012 | Cars & Trucks
Fuse in motor keep blowing and motor keeps running but once stopped won't restart
What year, make model and engine size there? Send details please.
Jun 27, 2012 | Cars & Trucks
BLOWING FUSE IN CONTROL PANEL
if not ignitor shorted maybe blower motor bad
Jun 10, 2012 | Hayward Heatpro 81k Btu Swimming Pool Heat...
My 02' mdx won't come out of park, keep blowing a 20 amp fuse. This fuse controls the Cruise, break lights, memory seat, horn and linkage. I have to manually delink. I have unhooked the comand...
Here is an idea, when do you blow the fuse key on, key on engine running, key on engine running hitting the break pedal? Try and get the key on without blowing fuse if possible, then one at a time try those circuit loads ie: horn, brake pedal and so on, if you isolate which load is pulling to many amps(blowing fuse) unplug that load itself, then restart testing, see if fuse stays ok. You can also substitue the fuse with a circuit breaker and unplug each load until click(of breaker) stops.
May 17, 2011 | 2003 Acura MDX
My stop hazard fuse keeps blowing on my 95 chevrolet k2500 Cheyenne. I do not have cruise control. i have disconnected the break relay and my turn/hazard switch. It still blows, yet when i unplug my break...
check the AMPS for all your fuses sometime a low amps fuse in the wrong slot can blow otherones. also sometime you can increase the fuse that keep blowing. try that first if that do not work you might need to run and electrican test on your fuse box to check if you have a short. also check your fuseable link on the fuse panel under the hood.
Nov 13, 2010 | 1995 Chevrolet K2500
My 2005 suburban AC is blowing hot air; one minute it was blowing out cool air and then it started blowing as if the heat was on....
If you touched any of the A/C controls within 45 seconds of starting your Suburban (after the battery change), you messed up the 'calibration mode' of the HVAC.
Pull the HVAC fuse (10amp) under the hood, and pull the two adjacent fuses (30 and 10amp) under the dash listed as 'climate control' in the manual.
Push the fuses back in, restart your car, but DONT TOUCH ANY of the A/C controls for 90 seconds.
I bet the A/C starts working again normally.
May 06, 2010 | 2003 Chevrolet Suburban 1500
My 7.75 Hp snowblower starts, runs 15 minutes, then stops.
check your eingine compression, sounds like it is worn hence the rough idle and loss of power under load
Jan 29, 2009 | Briggs Stratton H7159 & Stratton® 5500,...
Dishwashers Logo
148 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
