Question about Motorola Mobility i670 Cellular Phone
Why does my phone turn off by itself when i close it? I have to actually turn the phone back on to use it.
    Problem Solver:
  • 15 Answers
Hi
i hope u r using a flip model, if so pls check for the connectivity of the battery which may look good,
pls check by moving the battery when the mobile is switched on. i too have the same problem
thx
Posted on May 14, 2009
How can I stop my Sony Experia miro from turning itself off and on again? It wipes off my call log and contacts sometimes when it comes back on and I have to import my contacts to get them back. It ha
There are a couple things you can try. First of all, back-up your phone, then do a factory reset from the settings.
The second thing you can do is to fold a piece of paper a few times and put it against the battery, then close the back. Use something to basically hold the battery tighter in the phone, and see if this stops the restarting. It's possible that the phone is restarting because the battery isn't securely in there, so some pressure on the battery, when the phone is closed again, might help to keep it wedged in there tightly.
If neither of these things help you, it is possible that the phone has a hardware fault, and is restarting because something is wrong with the actual circuit board or something inside of the phone.
You could either send it in to get fixed, or you could replace the phone with a new one.
However, it's always best to start with the free options first.
So, use something to hold the battery tightly in the phone, and/or factory reset the phone to ensure it isn't a program that is causing the phone to crash and restart.
Best of luck!
Nov 26, 2014 | Sony Cell Phones
TV TURNS ITSELF BACK ON AFTER BEING TURNED OFF
The most common thing is malfunction in your remote control. Try moving the remote control to another closed room, and see if it still does it. If it does... well, I know how to setup a TV to turn itself off after a period of time you set, but how to turn it on? no.
Also something, might be stupid, but I'd tell it anyways, is that someone is fooling you by ór using the remote control, ór having another remote control, and turning it on all the time.
And another thing. By "off", do you mean standby? or actually turned off by pressing the button? Because this is only if it is turned off with the remote control. If it is explicitly turned off by the button, then it might be a malfunction on your tv, meaning you could call the support of the company that makes these tv's, and if it is actually a malfunction, you could get a new tv for free, if your warranty hasn't outdated yet.
That's all I can think of, I hope it helps.
May 04, 2010 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Shutting off and on
That actually is a flaw in the Sansung phone itself, its something in the manufacturing. When getting large messages or multimedia messages the Samsung will power itself on and off. Had the same problem with Samsung.
Apr 06, 2010 | Samsung SGH-E251 Mobile Phone - Black
My palm centro was hot cyncing intself
I just googled this issue b/c my daughter got a hold of my phone and somehow (as only an 8 month old can) hotsycned my phone. O
ut of total frustration at the thought of having to replace my phone, I took the battery out and left it on the counter for about a minute. It works fine now.
Aug 04, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
W980 turns itself off when I close the flip
call the service center if they didn't actually fix it they should have a limited warranty on their repair
Jul 24, 2009 | Sony Ericsson Walkman W980i Cellular Phone
Sunroof on 2003 jetta tdi won't close. it has power, and operates, but will always reopen, by itself, when it is almost closed. ???
There may be something obstructing the path. Possibly the wind deflector? It's also possible that the sunroof knob is out of sync with the sunroof itself. Try putting your key in the drivers door lock, turning and holding that position while the sunroof closes. (not sure which way you have to turn) You can also close it manually with a hand crank (which is actually an allen wrench)
Jul 12, 2009 | 2003 Volkswagen Jetta TDI
When closed, the outside screen does not light up.
Took battery out and turned back on. I guess maybe should power up and down every once in a while, it might reset things. Ended up no big deal. thanks.
Jan 16, 2009 | LG CU500 Cellular Phone
My H350 turns itself off in standby mode
IF YOUR BTHS IS PAIRED TO ANY PHONE . IT WILL CONNECT AUTOMATICALLY WHEN YOU PRESS ANY BUTTON ON YOUR PHONE.
Nov 21, 2007 | Motorola Mobility H350 Wireless Headset
5 year old Jenn Air double oven
the door switch contacts are stuck closed causing the oven to stay on.if you can access the door switch try to wd-40 on it.if that doesnt help you need a door switch.
Aug 16, 2007 | Jenn-Air JMW9527C Stainless Steel Electric...
LG KG-800 with Mac OS X (eject issues)
First scan your mobile with anti virus and then format your mobile next connect and add files and close all the programs running and refresh your system and then click eject or in taskbar click on safely remove hardware and disconnect it.
Aug 10, 2007 | LG KG800 Cellular Phone
Motorola Mobility i670 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
