Question about RCA DRC8295N DVD Recorder/VCR
Starts to record ,then it will record for awhile,then stops,says clean dis.that don't help
When start to record,it will record for a while then it will stop an say clean dis.I have cleaned dic,when do I do nest
  • 55 Answers
Try to use a lens cleaner. If that doesn't help, then the writing part of the lens is going out and needs to be replaced.
Posted on May 14, 2009
My 2002 villager runs fine for first 2 minutes then starts missing badly.
Frank, have scanned and diagnosed by a good technician, estimate for repair. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Jun 01, 2016 | 2002 Mercury Villager
Car starts fine after sitting awhile. If you drive awhile then stop and try to restart it won't.
Check the electronics,cam sensor or crank sensor these are the culprits.
Aug 19, 2012 | 2006 Chevrolet Aveo
Car will start after awhile it bogs down and dies
The engine in this car is controlled by a computer, whenever you have a stall like this the computer will record a fault code for the event, you must have the system scanned to get that code, then based on the code you start the diagnostic to repair the problem, which in your case is likely a CKP sensor. But that is just a guess, don't replace anything until the testing confirms it is the problem.
Feb 02, 2012 | 2004 Pontiac Grand Prix
After my 92 rodeo runs awhile it falls on its face then starts to idle at about 2500 rpm and wont stop. When I shut it off and try to restart it it starts real hard and acts like its flooded and blows...
THROTTLE BODY needs to be taken apart and cleaned. Hand clean the sensor and idle valve, they are electric do not soak them, check them also, Idle valve likes to stick and position sensor likes to go out. HUNT
May 11, 2010 | 1987 Isuzu Trooper
I have a push mower i changed the spark plug it starts but then stops
Most of the starts but dies problems are caused by dirt/water/debris in the carburetor float bowl.
You can try draining the gas out of the carburetor float bowl by removing the float bowl nut located on the bottom of the carburetor.
Make sure the hole in the float bowl nut are clean. If the problem persists after draining the float bowl nut you will have to remove, dis-assemble and clean the carb with compressed air and carb cleaner.
Aug 19, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Ryobi leaf blower #8544,25.4 cc
I have a McCulloch, that the hose rotted off the fuel strainer in the tank, I replace the hoses, it ran for awhile then stopped, removed the carb. an have cleaned, { 7 Times} it runs for awhile then stops, Usually I dump lighter fluid in the carb. if it starts Ign is OK if not its a fuel problem. You could check on the filter, I still have a problem with mine, its a pain when your on the roof an it stops. so check the fuel filter is the only thing I could suggest to you GOOD LUCK
Nov 03, 2008 | Garden
Revving noise-wont record
Turns out the rubber disc grip on the spindle simply needs to be cleaned (using an alcohol wipe). This is the part that holds the disc firm while it's spinning...the noise and failed disc reads comes from this rubber getting dirty and allowing the disc to slip. Total time to fix including disassembly was less than 15 minutes!
Aug 16, 2008 | Panasonic DMR-ES10 DVD Recorder
How Do I Make An MPEG Recording?
You can record video with audio onto the Memory Card. Follow the instructions below. Recording moving pictures onto a MEMORY CARD 1. Insert a Memory Card into the slot on the camcorder. 2. Set the mode switch to MEMORY CARD position. 3. Set the power switch to CAMERA mode. 4. Press the START/STOP button, the images are recorded on the MEMORY CARD in MPEG4. * You can record 10 ~ 20 seconds continuously. * You can record a still image on the Memory Card by pressing the Photo button instead of the START/STOP button. 5. Press the START/STOP button to stop the recording. Notes: * Moving images that you recorded are saved in *.asf file format on the Memory Card. * The moving picture images on a Memory Card are smaller size and lower definition than those on a Tape. * The sound is recorded in mono. * The following functions cannot be operated in M.REC Mode. - DIS (Digital Image Stabilizer), Digital Zoom, Fade, Program AE, Digital Special Effect, Slow Shutter. * Don't insert or eject a tape during Memory card recording as it may record noise. * Don't eject the Memory Card during recording as it may break the data on the Memory Card or the Memory Card itself.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
RCA DRC8295N DVD Recorder/VCR Logo
174 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
