Question about Dishwashers
I have a user guide for my ASCO 1996 dishwasher however when we lose power it loses its settings. I have had a repair guy come out and charge me $100 just to hit the wine glass 5 times and reset. This time the drain cycle is not long enough and I know you can program it to give it a longer drain but I don't know how and these appliances don't come with programing instructions which seems completely stupid to me!!!!!
  • 2 more comments
  • angie644 May 14, 2009
    I don't think The last guy even read my question. I need a programing guide for the ASCO 1996. I know that pushing the wine glass 5 times resets the programing and that pressing something else a number of times sets how long the dishwasher drains. I need to know what to press to program the washer to have a longer drain cycle. The repair man that came the last time the power went out had a whole sheet of programing information that never came with my machine. Do you have that? my washer is not draining long enough so there is water in the bottom after the cycle is done.
    There is nothing wrong with my dishwasher except that the settings have been reset and the drain cycle isn't long enough. Over the last 6 years this has happened a couple of times in which the repair guy simply pressed a couple of the buttons and changed the settings. He had a sheet that told which buttons to press and how many times to press them to change the number of minutes that the drain cycle is set for. He gave me the sheet to copy but my copier wasn't working that day.
    I just need programing help.
    You were pretty prompt with the first response so I am wondering if you reveived my reply or are you still researching. Thank you
  • angie644 May 19, 2009
    There is not a drain cycle button. There is a picture representing a pot a cup a wine glass a shower an "E" which I assume is for ecomomy, a thermostat and a time delay. When I had a tech come out he pressed a series of buttons that restarted and then pressed one of the buttons a few times that changed the amount of time the drain would cycle. There is a program guide out there I have seen it. I either need the info off it or the guide itself.
  • 3,741 Answers
You will need to call the engineer at your place.as the settings are available with the service center sources only.the engineer that visited your place was either a ASCO  engineer or he has received the service manual  from ASCO techinician somehow. because the programm guide is not published online for the users. thanks.
Posted on May 20, 2009
    Novelist:
  • 130 Answers
Turn off the unit .press the drain cycle button and turn it on.after that hold a minute then check out.
Posted on May 15, 2009
    Scholar:
  • 123 Answers
. If the existing drain from your dishwasher drained into the disposal, and you want to do the same, then you must remove the plastic plug that is molded into the nipple. Knock out the plug using a screwdriver and hammer. Leave the plug in if you are not going to use this drain.
Drain line/air gap
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt
One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor
If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Posted on May 14, 2009
    Brigadier General:
  • 3,917 Answers
Scrape off big chunks of food before you put dishes in the dishwasher, but don't worry about rinsing them off. Most washers are designed to handle food particles. (Don't expect the dishwasher to remove burnt-on foods, though.)
  • Step 2 Position cookie sheets and large platters along the sides so they don't prevent the water from reaching the other dishes.
  • Step 3 Reserve the top rack for plastic items, glasses and mugs. (Make sure that plastic items are dishwasher-safe.) Set plates and bowls in the bottom rack.
  • Step 4 Be sure that glassware is put on the prongs. Loose glasses might break and make a dangerous mess.
  • Step 5 Put pots and dishes with baked-on food in the bottom rack facing down toward the sprayer arm.
  • Step 6 Set silverware handles down, except for knives, which should be handles up in the silverware basket.
  • Step 7 Fill both dishwasher cups with dishwasher detergent.
  • Step 8 Add rinse agent to rinse agent dispenser; replace top of dispenser.
  • Step 9 Close door securely.
  • Step 10 Choose a wash cycle appropriate to the load.
  • Step 11 Choose a dry cycle. Air drying saves energy, but may cause spotting.
  • Step 12 Start dishwasher.
  • Thank You
    • e-Guru
      e-Guru May 14, 2009
      Try to see if it flashes an error code, that could help identify the problem. Otherwise, if the problem is only with programming and not with the actual dishwasher, you might want to try replacing the program timer module.
    I have been wearing my fit bit all day. I just pressed the button to check my steps and the button is missing. What am i to do
    Edna, return under warranty for replacement/repair, if not to old and still under warranty. If not under warranty, see a local jeweler for estimate on repair. Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    Fitbit Return Policy and Warranty
    Button Fell off Charge HR
    Losing Faith In FitBit From Loyal User Of 2 Years RBRussell com
    Fitbit Charge Button Fell Off
    Aug 20, 2016 | Fitbit Charge HR Heart Rate and Activity...
    Do you know what the problem may be?
    Ford Focus cutting out and losing engine power, mileometer going ...
    www.rac.co.uk > ... > Technical and Maintenance Questions
    RAC Limited 10 posts - ‎6 authors
    About five weeks ago, after driving for 1/2 mile, my car cut out with no warninh ... 26-08-11, 12:04 #1 ... I have a 51 Ford Focus 1.6 petrol, about 77000 miles on the clock. ... to check it wasn't anything I was doing, and whilst it wasn't half as bad, he did ... My main concern is the power failures causing the car to actually cut out ...Missing: kuga ‎11600 ‎stutters
    Petrol in a diesel car - Guide and Videos - Auto Fuel Fix
    My Escape is sputtering / losing power. - Ford Forums - Mustang ...www.fordforums.com/f59/my-escape-sputtering-losing-power-191329/Old 07-08-13, 07:22 PM Thread Starter. Escape2009. Registered User. Join Date: Jul 2013. Posts: 5. My Escape is sputtering / losing power.Engine power loss and sputtering - CarGurus
    Dec 01, 2015 | Cars & Trucks
    I have skoda octavia 20 diesiel 2007 .sometimes it will loose power ,i pull over for a few minutes and then start up again and its like arocket again ,any ideas,
    You definitely should get it checked at a VAG-COM tester. The Dealer has one, but can charge quite a lot on it's use, and often tries to bundle some nonsense fluid checks, etc. to get a salty invoice. Some independent repair shops and DIY-repair guys have it also and can do the check quite cheap.
    But as a guess:
    If the engine dies totally, it's most likely happening because the CPS (Crankshaft Position Sensor) is breaking. Usually this starts happening with the engine being warm or hot.
    If it's only hard to start, and loses some power (goes into safe-mode) it might be the valve-cam position sensor that's breaking.
    Or it might be that the turbo loses pressure, meaning that the pressure regulator valve is stuck.
    Jan 26, 2015 | Skoda Octavia Cars & Trucks
    Dishwasher shuts off during cycle
    Since the troubleshooting and repair process is too lengthy to include here, please go to the following link: http://www.appliance411.com/service/repairmanual.shtml
    to open [or download] the service / repair manual. It is free.
    Scroll about half way down the page, in the left column, under Maytag products, select the Maytag / Jenn Air / Jet Clean II "Tall Tub" Dishwasher repair manual... it covers your model dishwasher..
    It includes a troubleshooting guide as well repairing instructions
    Best wishes on your project.
    Dec 01, 2013 | Maytag MDB9600A Jetclean II Built-in...
    I have replaced alternator battery and computer and i am still having problems with the car. it stalls out and i lose power to everything. can anyone help?
    Alternator was replaced and computer and battery,so this wasnt the problem, when you say it loses power and stalls out are you still able to crank the vehicle?If you can its not the the charging system,You have to inspect the ignition switch the electrical part,it sound like the problem reside there
    Mar 23, 2012 | 1996 Oldsmobile 88
    HI MY VAN ISCONSUMING OIL AND IT DOESNOT HAVE
    if its a 3.0l v6 then your valve guides have fallen down into valve pockets. head removal and repair would be required. a spark plug could be oil fouled from the oil consumption causing low power
    May 04, 2010 | 1996 Dodge Caravan
    Car is losing power and speedometer not working
    The alternator is dying...
    It is not charging your battery. Don't use your headlights (big power drain) until you have the electrical checked.
    AutoZone will analyze (free) w/o removing alternator (IN-CAR test)
    Hope this helps, soon!
    Sep 13, 2009 | 1996 Honda Accord
    We have the same problem
    get another opinion
    dig conts vary
    c atkins carlyle
    c www.morningstarcorp.com
    u r looking 4 auto start module
    most asm can b fitted to this unit
    Aug 31, 2009 | RTO ASCO 165 Series 200A Automatic...
    Dishwashers Logo
    107 people viewed this question
    Top Dishwashers Experts
    Owen Barnes
