Question about HP DesignJet 5500PS InkJet Printer
Ink Cartridge won't reseat
I have a HP 5500 - Magenta (UV) is at 35%. In the middle of a print a message comes up to reseat magenta - won't reseat. I've cleaned the chip, jiggled the connections - no luck, this has happened before, I had a spare last time. this time, no spare and the jobs got to go out before I can get one. Any advice?
thanks
greg
  • 679 Answers
When you put a new refill in an inkjet printer, the brain of the printer sends a small electric charge to the cartridge. Try going into the menu of the printer and check or click on the instalation of a "new" cartridge. It will send the charge to the ink and that may be the problem. If that dosen't do it, then see if you can reset the machine by disconnecting the power and any cables for a minute, and retry it then
Posted on May 14, 2009
Hp 3210 not printing magenta and leaving large quantities of magenta ink in printer blobs on right side of paper
defective cartridge; make sure you buy ANY cartridge from a REPUTABLE, not cheap, cartridge company.
Dec 24, 2012 | HP Photosmart 3210 Printer
I have a canon IP 4200 printer. The ink cartridge light on the Magenta ink cartridge doesn't work so it won't accept/recognize that a new ink cartridge has been installed. Is this something that...
It sounds as though you have a break in the carriage ribbon cable. A new carriage would hopefully cure it but its just possible the logic board has failed and is not sending any signal to the magenta ink tank. Its certainly repairable but you would need to know the costs and the labour charge to see if its worthwhile.
Aug 27, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
Why is the magenta ink getting everywhere: all over the inside of my printer, all over my paper, everywhere?
Check your print heads and the cartridge. replace the cartridge. if that doesn't fix it, call hp RIGHT AWAY. Leave positive feedback!
Jan 13, 2011 | HP 645A Magenta Toner Cartridge (C9733A)...
Keeps asking for ink and it has ink
Try removing, and then reseating the MAGENTA cartridge.
If you replace the MAGENTA toner-cartridge, does the problem go away?
Jul 30, 2010 | Xerox Phaser 8560DN Laser Printer
I have tried to print but I am notgetting the magenta to come to the printhead. I have gotten valuable help on fixya but now I need the magenta to print
The most obvious thing would be to double check to make sure your ink cartridges are inserted correctly
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jun 19, 2010 | HP Photosmart D7260 Printer
How do we bypass the expired ink cartridge message on the HP D7360. Magenta ink cartridge is not empty.
Take out both the cartridges > wipe it with clean cloth> then the ink part of the cartridge wipe it with plain white paper> let little bit of the ink come out on the paper & put them back again in the printer>restart pc + printer - ur done. no more messages on your printer>then print a test page-simple.
Jul 27, 2009 | HP Photosmart D7360 All-In-One InkJet...
HP Officejet d145 print head problem
Did you replace the PRINTHEAD, or did you replace the INK CARTRIDGE? They are not the same on the D145.
Good chance that you may have replaced the ink cartridge, not the magenta PRINTHEAD which sits under the ink cartridge.
PS - in my experience, non-HP ink cartridges clog up HP printers with separate printhead mechanisms... any possibility here?
Jul 26, 2008 | HP OfficeJet d145 InkJet Printer
7310 won't print magenta
Either you are out of magenta ink or your cartridge is dirty. Just because you've run a cleaning job doesn't mean the printer will fix the problem. The best thing to do is take your cartridge out and use a paper towel to gently clean the head (where the ink comes out). Once you wipe away the gunk you should still get the three colors on each pass of the paper towel over the head. If you only get two colors (yellow and cyan) then your magenta is empty or dried out (happens with ink cartridges used past their expiration date). The only thing you can do then is get a new in cartridge.
Nov 22, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP DesignJet 5500PS InkJet Printer Logo
381 people viewed this question
Seeker5211
Seeker5211
