Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
The temperature controls for the refrigerator are not responding. The freezer controls respond just fine. My fridge is set to 34 and I need to get it back to 37 but it won't change the numbers.
My temperature control for the fridge on my subzero 650 is not working. the freezer control works fine but the fridge "cold" and "warm" controls do not respond.
  • madhubian May 14, 2009
    Thank you!
    Sergeant:
    Champion:
  • 214 Answers
Please switch off your refrigerator for at least 8 hrs. than again switch it on. if your problem is not cured than it is sure that your refrigerator have the blower problem because for this reason only, the problem arrises ....... please visit your service authority...........have a nice day:-)
Posted on May 14, 2009
The temp says 14 and 8 but should be -21 and 3? Can anyone help
Controlling the Freezer temperature
The freezer temperature can be set between -14°C (8°F) and -25?C (-14°F) to suit your particular needs. Press the freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at -16?C (4°F). The temperature display will move sequentially from -14°C (8°F) and -25?C (-14°F). When the display reaches -14?C (8°F), it will begin again at -25?C (-14°F). Five seconds after the new temperature is set the display will again show the actual current
freezer temperature. However, this number will change as the Freezer adjusts to the new temperature. The top and bottom guards in the freezer of this model are the two star sections, so the
temperature in two star sections are slightly higher than other freezer compartment.
Controlling the Fridge temperature
The refrigerator temperature can be set between 7?C (45°F) and 1?C (34°F) to suit your particular needs. Press the fridge button repeatedly until the desired temperature is shown in the
temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the fridge button to set your desired temperature. After a few seconds, the Fridge will
begin tracking towards the newly set temperature. This will be reflected in the digital display. The temperature of the freezer or the refrigerator may rise from opening the doors too frequently, or if a large amount of warm or hot food is placed in either side. This may cause the digital display to blink. Once the freezer and refrigerator return to their normal set temperatures the blinking will stop.
If the blinking continues, you may need to "reset" the refrigerator. Try unplugging the appliance, wait about 10 minutes and then plug back in.
The refrigerator does not work at all or it does not chill sufficiently.
• Check that the power plug is properly connected.
• Is the temperature control on the display panel set to the correct
temperature? Try setting it to a lower temperature.
• Is the refrigerator in direct sunlight or located too near a heat source?
• Is the back of the refrigerator too close to the wall and therefore keeping air from circulating?
Dado
Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
Freezer goes -9 and fridge goes to 40 I have set it to 0 for freezer and 34 for fridge it changes on its own
Depends on type of refrigerator freezer you have, but you need to realize that the evaporator (cooling coils) are in the freezer, and the cold air produced in the freezer is then circulated via an evaporator fan into the refrigerator section. The thermostat the cycles the compressor motor is located in the refrigerator, and the compressor will run until the temperature reaches the desired level in the refrigerator. On most units, the freezer temperature setting simply regulates how much cold air is circulated into the refrigerator.
What you are describing is that the freezer is working fine (almost too good), but the air is not properly getting to the refrigerator area. Several things can be causing restricted airflow, including a faulty evaporator fan, icing of the evaporator coils because of a malfunction in the automatic defrost system. Check to see if there is frost or ice build up in the back or bottom of the freezer. The proper temperatures should be around 0 F for the freezer and 38-40 degrees F for the refrigerator.
Feb 25, 2015 | Refrigerators
I dont now how to set temperature for samsung rsh1nhmh . All the light in the house vent off and the plugs . Now on the frige screen is only a flashing light. Nothing else
The refrigerator temperature can be set between 7?C (46°F) and 1?C (34°F) to suit your particular needs. Press the Fridge button repeatedly until the desired temperature is shown in the temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the Fridge button to set your desired temperature. After a few seconds, the Fridge will begin tracking towards the newly set temperature. This will be reflected in the digital display.
http://safemanuals.com/314159.php?k=2f8f21dfdc6e62cb4825d07d38bad88d&ID=471000&q=SAMSUNG%20RSH1NHMH
Nov 18, 2010 | Samsung Refrigerators
Refrigerator (Samsung RS2555SL) quit cooling on both sides. Front panel was blinking at set temperatures (34 fridge side/0 freezer side) but inside was warm. I unplugged for 5 min and ran self-diagnostic...
hello dont know if you have the same model
but this may be worht a look
samsung fridge freezer problems
http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01"> name="allowFullScreen" value="true">http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344">
Sep 28, 2010 | Samsung RS2578BB Side by Side Refrigerator
Kenmore elite fridge, french doors, bottom freezer: water does not come out cold. What should the temperature settings be at (for fridge and freezer)?
Fridge 34-38 degres
Freezer below 29
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 17, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
MFD2561HES The fridge temperature wants to fall to from set temp 40 to 32. I set it higher and it climbs back up in time but will lower itself back down in a day or two. Why would it continue to cool...
The control board in the control panel should be regulating the air damper correctly. If the control board is responding this way the the damper is told to open too wide allowing colder temperatures into the fresh food section. The thermistor also may not be working properly or may and the board could be the total problem. This is going to be something that an Authorized Maytag Technician will need to have a look over. Switching the Control Board Part number W10207861 Temperature Control Board and 12002356 Thermistor just may solve this. Sea Breeze
Oct 23, 2009 | Maytag MFD2560HES Bottom Freezer French...
The refrigerator ignores temperature setting.
Hello, This problem is going to be the cold control/thermostat, this part can be located in the control console inside the fridge bhind the freezer temp control knob (can also be found sometimes in the freezer depending on type/model) The reason your food in the fridge is freezing is because the thermostat controling the freezer temp is not shutting down and the air being blown into the fridge is too cold. Replace this cold control/thermostat and you should be fixed. If you have any other questions or concerns please feel free to comment again and give me some time to respond. Good luck! Mike
Sep 08, 2009 | Kenmore Refrigerators
Kenmore Elite 18.5 cu ft fridge - heavy condensation/ice build up
mam please check the settings of the freezer and the refrigerator settings should be in normal mode and if u find it in normal mode then the problem is here the temperature controler is not responding to cutt off and cutt in the freezer so please check this operation.
Sep 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Hotpoint ffa97p - the fridge is too cold and not responding to temperature changing
I'm assuming you're meaning that you reset the "cold control" in the refrigerator area and it is not responding. Try resetting the T stat in the freezer to between 2 1/2 and 3 1/2 and see if the unit continues to run on. If I have this the other way around, set the "cold control" the same as the T stat. The "cold control" is just a flapper door, it doesn't control the compressor only the T stat in the freezer does..
If the T stat is set as I said and the unit just keeps on running and never shuts down except to defrost, the T stat is bad and needs replaced.
There is a chance that the flapper door in the "cold control" is stuck wide open. Removing the cover and inspecting it might tell you if that's happening.
Jul 09, 2009 | Hotpoint Refrigerators
Freezer cold but not freezing
Check the settings for the freezer control. Refrigerator temperature control normally controls the run time of the compressor. if the freezer control is set to low the refrigerator temperature will be fine and the freezer will be warmer. Setting the freezer control to a colder setting will hold back more cold air in the freezer and reduce the air volume supplied to the refrigerator. Check and make sure the condenser coil is clean.
Jun 08, 2008 | Liebherr Premium CTP 3153 Top Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
581 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
