Question about ASUS Intel 810 Chipset CUW-FX Motherboard
I hav a P-III on Intel810. The problem is it does not boot.
The problem is that the CPU fans roll, but no beeps, no POST, infact no display (monitor LED "blinks" and not "ON" as it shud be) tried removing RAM and all other peripherals...still no success...is the motherboard faulty..Ive tried replacing the RAM also...will reseting the bois do it..if yes how to do it?
Thanks in advance
    Problem Solver:
  • 5 Answers
Id say remove the mother board completely....make sure nothing is plugged in except power supply ..check ur speaker on the jumpers..remove the ram and if no beep...ur prolly lookin at tryin another power supply or gettin a new board...acually www.geeks.com has a useful tool to check motherboards which is really cheap
Posted on Jun 11, 2009
  • 3,267 Answers
Resetting BIOS is simply removing the jumper which connects 2 pins from a set of 3 pins on the MB, very close to the BIOS chip,(else look it up from the users manual. Next use a working keyboard mouse. If you know how to handle the RAM then do so using an old news paper corner piece, for the carbon/dust and replace securely. Check the connections of the power/SATA/IDE Cables are snug tight. If that too fails, replace the power supply(SMPS)..............sodeep
Posted on May 14, 2009
  • 1,879 Answers
If it cannot even light the keyboard numlock led, the board is fried
I'm faced with a black monitor, no boot beep, with an operating fan and green light on. XP OS with an ASUS P5P800S motherboard, Thanks Jose
Remove all components from your mb and bios battery. Place jumper to clear cmos and make short to battery cmos. Leave 1min and after place cpu and one ram in mb. Replace jumper from clear cmos in normal position and verify. If not display, change ram.
Sep 26, 2014 | Computers & Internet
The desktop won't reboot. The power light stays yellow. I hear a fan running, but the monitor says no signal.
If your fan runs and the hard drive spins up, then you have a video card problem.
I'd do this: Disconnect everything inside the case but the CPU, memory, and video. Now try to boot. Also observe the fan on the CPU--does it spin?
If this fails, then your video has probably gone bad. Also--does your computer usually give you a "beep" when it starts up? If so, is it giving you a beep now? If not, you're failing the hardware startup test (POST).
So, your problem may be the video card. If your video is part of the motherboard, then you need to replace the motherboard.
Oct 01, 2009 | Computers & Internet
No monitor display
Remove all data cables and external cards and press RAM than try again
Jul 23, 2009 | Computers & Internet
Fan running, HDD light solid, no display
I assume there are no post codes (beeps)?
Pull everything including the video card, leave only the RAM and CPU installed.
Try powering it on, You should hear a long beep, then some short ones to tell you the video card wasn't detected.
If you still don't get any post beeps, try resetting the BIOS, and re-seat your RAM.
If it still doesn't post it could be a system board mounting issue, bad system board, bad RAM, bad CPU, or bad Power Supply
Jun 24, 2009 | E-Machines T2240 PC Desktop
PC not Booting up
Dissemble your whole PC. Clean thoroughly. Check BIOS battery with a multimeter. Try to boot without expansion cards. Change RAM if you have extra one. There are so many procedure you can take. Keep informing.
Feb 22, 2009 | Tyan Tempest i5000PX (S5380) (S5380G2NR)...
No beep,No Display on my monitor,only CPU heatsink fan is moving
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
Oct 29, 2008 | Asrock K7S41GX Motherboard
Pc is not booting and no display in monitor
First, try resetting the CMOS. If it is not working, replace the RAM. Could be a damaged RAM
Sep 11, 2008 | ASUS (P4BGV-MX) Motherboard
ASUS P4SP-MX motherboard no POST and no beep without ram
Try removing everything attached to it. The only thing should be the cpu and cpu fan. Turn it on. If it is the same, then it is your motherboard. If you do get the beeping, then start installing things one by one starting with the memory.
Jul 03, 2008 | ASUS P4SP-MX Motherboard
how to fixed your motherboard no display and no beep, 1st you must clean your memory using eraser and brush for painting if not display again try to clean your video card if have a video card using again the eraser and painting brush if not display again try to pull out the bass in the cdrom and floppy disk. if not display you must replace the memory and video card., if not display try to change your motherboard. The beep put speaker in the motherboard.. gudluck guys
Sep 10, 2006 | Asrock P4I45GV R5 Motherboard
ASUS Intel 810 Chipset CUW-FX Motherboard Logo
133 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
