Question about Medion MD-40954 Notebook
Medion laptop still wont load
I have had some instructions and followed them but still no joy with laptop. i have pressed f8 gone into safe mode and i still keep getting the same message up. its a medion mim2230
How to turn off safety mode
Don't want to be offensive but that's called Safe Mode.
If you are able to load your OS in normal mode then you need to access "System Management Utility".
Press Win+R -> type "msconfig" in run box then click ok, in the new window go to boot option at the top and select safe boot.
In case you cannot load the OS in the normal mode then you need tap either F8 or F5 (function keys) repeatedly once you get the bios screen on the start up.
Jul 19, 2014 | Medion Computers & Internet
Blue screen
Which operating system you are using??
You can follow the given steps to avoid blue screen error..
Start Windows in Safe Mode:
Step1: Turn on your computer and press the F8 key repeatedly from your keyboard. You must press F8 before the Windows logo appears. It will display the Advanced Boot Options screen.
Step2: From Advanced Boot Options screen, choose Safe Mode option then press Enter.
Step3: If Windows loads and works fine in Safe Mode, a bad driver is probably causing the error. Uninstall device drivers and reinstall them. If Windows experiences issues in Safe Mode also, repair your hardware.
Startup repair:
Step1: Shut down your computer and then restart it in Safe Mode (see step1).
Step2: From Advanced Boot Options screen, select "Repair Your Computer" and hit Enter. Choose your preferred keyboard layout and then click "Next."
Step1: Click "Startup Repair", and follow the on-screen instruction .Startup repair can solve this problem.
System Repair:
Step1: Follow step1 and step2 from Startup repair section.
Step3: Now select system restore from the System Recovery Options menu. And follow the on-screen instruction to select a restore point.
**If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Jan 24, 2013 | Acer Aspire Computers & Internet
I forgot my password
Hirens really works and is free. Burn to CD and follow instructions. Tested, but had to do twice.
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode. XP only.
  • Login as other user (if other user is available) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
  • Free software option would be Hirens Boot CD. This one is command prompt only. http://www.hirensbootcd.org/ Must follow instructions exactly.
Nov 22, 2012 | Acer Aspire 5610-4648 Notebook
My laptop does not boot {its a dv500 pavilion}
Try this, start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to, select, either Safe Mode Desktop, OR System Restore, chooses System Restore, and now choose a time Before you had the "Problem" and follow instructions, through until the end, & reboot. This should get you back.
Mar 04, 2010 | Computers & Internet
My A30 ibm laptop wont start up??
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Mar 03, 2010 | IBM ThinkPad A30 2652 Notebook
My toshiba l300 wont let me acces my internet.
Mar 02, 2010 | Computers & Internet
Cant get past microsoft windows loading bar
Feb 26, 2010 | Toshiba Satellite L355D-S7809 Notebook
My friend has a advent 4211-b netbook was working fine until it would not let him load xp or reboot in any mode it just looks as if going to load then goes straight back to load windows normaly
Try to start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 25, 2010 | Advent 4211c Notebook
Aspire one notebook wireless connetion there one day gone the next! have updated atheros drivers to no avail. just wont connect, gives me the WZC service error msg
Hi
Thank you for your query
Please try the folowing
Hi
The error message indicates that you have corrupted system files
Please try the following
1) Start Laptop
2) Continuously press the F8 key until a startup menu is repsented
3) Choose safe mode from the menu
4) Once safe mode has loaded up click on Start>Programs>Accesories>System Tools>System Restore
5) From system restore choose 'restore my computer to an earlier time'
6) From the calender presented please select a date in bold lettering back a few weeks before this fault was seen
7) Choose the date and click next..............follow the instructions through
Feb 22, 2010 | Acer Aspire One PC Notebook
Wont get past Microsoft Windows XP loading screen on Acer Aspire1
Feb 17, 2010 | Acer Aspire One AOA150-1126 Notebook
Medion MD-40954 Notebook Logo
178 people viewed this question
Top Medion Computers & Internet Experts
Larry Chandler
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
