Question about Campbell Hausfeld 1,350 Psi Electric Pressure Washer With Auto Detail Kit #PW1350
Motor on campbell hausfeld electric pressure does not start 1500 psi ilive in fl no freezing of water left in tank unit is 5 years old use once a year. thanks jim
3 Suggested Answers
  • 251 Answers
SOURCE: pulsing Campbell Hausfeld 1300 psi 1.6 gallon electric
the unloader valve is deffective , this has a small metal rod which activates a microswitch to turn the machine off , replace the unloader valve
Posted on Nov 19, 2009
  • 420 Answers
SOURCE: Gun
Replace the wand (Gun) The valve is not repairable.
Posted on Jun 16, 2010
Hookup
For the Campbell Hausfeld 1800 PSI model (PW182500AV), the garden hose connects to the pump inlet on the lower back of the pressure washer. The high pressure hose connects to the high pressure outlet on the lower front of the pressure washer. Here is the operator's manual that will show both connections. http://www.mowersatjacks.com/images/campbell-hausfeld/manuals/pw1825.pdf
May 18, 2013 | Campbell Hausfeld 1800 PSI Electric...
My 5 hp campbell hausfeld model hl 7017 pumps up to pressure but when it drops the motor starts but the compressor wont turn the belt just slips until pressure drops off to about 30 psi
Your tank check valve is not closing properly. It's a valve on the tank where the air line from the pump head attaches, It allows air in but not back out of the tank through the pump. When the pressure swtich turns the motor off, valve on the pressure switch lets the air out of the head so the motor can restart without any pressure in the pump head when the pressure in the tank drops. On rare occasion, you can clean the check valve out and it'll work again, more often than not you have to replace it.
Nov 24, 2012 | Campbell Hausfeld Maxus 60 Gallon (Belt...
I have a ch pw180500av which iused once a year ago its been in the cellar for a year anf now when i start the hose up it pours water out of the bottom help jim in pembroke ma
It sounds like somehow the pump has a crack in it. This will do that if water was left in it and it froze. How cold does your cellar get
Mar 17, 2011 | Campbell Hausfeld 1800 PSI Electric...
I have a Campbell Hausfeld RBPW1810 pressure washer, It has two detergent tanks. I cann't get either to work. I just purchased the unit in June if this year and this is the frist time I am useing the unit....
Sometimes thinning the solution will help, but in any case make sure the line from detergent tank to pump is sealed, otherwise it just sucks air. I use a small hose clamp at pump. let us know
Sep 22, 2010 | Campbell Hausfeld 1800 PSI Electric...
Gun
Jun 16, 2010 | Campbell Hausfeld PW1750 Electric Pressure...
Campbell Hausfeld 2000 Psi Gas Pressure starts and runs for a stort time then dies out and is hard to start with the water pressure still on. Will run for a stort time only after it has sat fo awhile....
Replace or clean with spray carburetor cleaner, the fuel filter which is likely plugged. Make sure the fuel tank vent is open. Sometimes, a fuel system cleaner is helpful like 'Seafoam". Make sure the oil is clean and topped up. A muffler can sometimes plug up and cause a similar problem. Hope this helps!
May 18, 2010 | Campbell Hausfeld 2000 Psi Gas Pressure...
Pulsing Campbell Hausfeld 1300 psi 1.6 gallon electric
Nov 18, 2009 | Campbell Hausfeld 1,350 Psi Electric...
Stops running after a few min. of spraying and won't start up . campbell hausfeld 1300 pressure washer
hi sounds like the rong nozzel in the lance and it's pulling to many amps so it overloading the motor and tripping out, take the lance off then try regards
Oct 25, 2009 | Campbell Hausfeld Tools 1300 Psi X 1.4 Gpm...
No air pressure past 60PSI on a 125PSI Campbell Hausfield WL61110
Your comperssor is oilless type and suffers from short cylinder / piston life. When the compressor no longer reaches cycle pressure the cylinder / piston should be replaced. These parts are available at www.chpower.com I believe that the part number is wl210300aj. Not expensive, enjoy.
Dec 13, 2008 | Campbell Hausfeld 26 - Gallon Air...
Campbell Hausfeld 1,350 Psi Electric Pressure Washer With Auto Detail Kit #PW1350 Logo
173 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Tim Venetis
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
