Question about LaCie 3 TB Biggest Quadra External Quad Interface RAID Array 301249U
XP won't recognize entire drive
I attached a Lacie Big Disk Quadra 3 TB external hard drive to my XP system. XP only recognizes it as 746 GB. I tried disk management and DISKPART. Not sure why it won't see the entire drive.
  • Hari Saryono
    Hari Saryono May 11, 2010
    is your BIOS recognize the full drive as 3 TB? if not, the problem is on your Motherboard bios. But i suggest to upgrade your service pack to 3
  • ikkenom May 11, 2010
    Control Panel -> Administrative Tools -> Computer Management -> Storage -> Disk Management (local)
    Does it show the entire size?
    Or, since 3TB is greater than 2**32, what it may be showing is the amount ('764GB') by which the size of the disk exceeds 2TB.
    (2TB + 764GB) when measured in units of Kb (1024 bytes) is approximately 3 * 10 ** N, when report in units of thousands (1000) of bytes.
    If you use DISKPART to partition the drive into two equal-size partitions, do you get 1.38 TB per partition?
2 Suggested Answers
SOURCE: Lacie Big Disk Quadra 3TB won't work with xp-32bit
One way around is to install Mac Drive on your system. First you format your hdd in HFS+ on a mac platform, with any size you want.Then, after you installed Mac drive on your PC, it will work.
Posted on Jul 17, 2009
My 500gb lacie d2 hd quadra is no more recognized by my macbook pro sys 10.7.3 (lion)???...
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.
Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
if still no luck
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
May 10, 2012 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
I have a 1TB LaCie 2Big Quadra. It has 2 500GB and runs on RAID 1. I replaced both 500 GB LaCie drives with 1.5 TB LaCie drives, but my computer only recognizes the original 500 GB. I formatted both...
I have the same problem too on my 2big form lacie . If I use 2x 1,5 tera disk in "fast mode" or in "big mode" my disk manager only shows 746 gigs available (it should be at least 2,5 terra).
If I use "safe mode" so my system can see 1,3 tera available, wich is normal for a raid mirror configuration.
I hope to find a solution quickly.
Dec 13, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
I had 4 LaCie 2TB Big Disk Quadra, Item 301343U. They are connected to a Nitro 8-PORT FIREWIRE 800/1394B PROFESSIONAL (N8PFW8HR) hub. The hub is connected to a LaCie Firewire 800 PCI card. I am running...
Let's not take this as a solution so much as an intuition. I believe you may have run up against a limit of physical disk space that XP can administrate.
DO me a favor and don't give my rating a thrashing if I'm wrong.
Best Regards,
Marcus
Sep 23, 2010 | LaCie Big Disk Extreme with Triple...
Won't recognize drive
Have you checked the disk properties to see if the 400 GB of data is still showing. may be your data might be hidden foir some reason. can you give more details pls
May 05, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I have the same issue
Win XP will not be able to recognize whole 3TB storage drive. You need to use some kind of 3rd party utility and then partition it and format as well.. AS a note win xp size is limited up to 80-100 GB.
Sep 22, 2009 | LaCie 3 TB Biggest Quadra External Quad...
I'm running Windows XP professional. Have plugged in my Lacie d2 Quadra (500 GB). Device manager shows that it is working properly, but it is not initialized and it doesn't show up on my windows...
1.
log onto d computer as administrator
2.
start->my computer->manag
3.under storage->disk management
4.ef intialize ndcovert disk wizard appers click next ef not skip to step 8
5.on d selct to disk intialize page click next
6.on d select to disk covert page click next
7.on completing dhese two click finish
8.right click u r external drive nd click format
9.in d format dialog box type d name for u r external hard drive nd then click ok
10.click ok again
Sep 14, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
WIndowx XP can't see my LaCie Big Disk 3TB
did you checked disk management? is it formated to basic or dynamic?
Jul 10, 2009 | LaCie 3 TB Biggest Quadra External Quad...
Jul 01, 2009 | LaCie 3 TB Biggest Quadra External Quad...
Deference Lacie d2 Quadra1TB/Lacie big disk ?
It's all about the interfaces.
The Quadra has four interfaces: • eSATA • FW 400 • FW 800 • USB 2.0
The triple has all but the eSATA interface listed above.
For doing video work you want a big drive with a fast interface. If you have eSATA available then that's the fastest. If you don't then you're just as well off to go with the triple interface. The FW 800 would be the next fastest, then the USB 2.0, then the FW 400.
Because of the way that data is transferred I believe that when doing video work you would be best served by the FW 400 instead of the USB 2.0 even though the USB is faster I don't believe it is a full duplex communication so the FW 400 is actually better for video.
Apr 03, 2009 | LaCie Big Disk Extreme with Triple...
Pc not recognizing drive when turned on
Maybe this can help you:
http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Have you tried the disk on a different system?
Jules
Apr 02, 2009 | LaCie Big Disk Extreme with Triple...
LaCie 3 TB Biggest Quadra External Quad Interface RAID Array 301249U Logo
486 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
