Sony Cyber-shot DSC-H5 Digital Camera Logo
Posted on May 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello... I've been using my sony DSC H5 which is great but recently when I hold the shutter button down halfway to focus does not lock in the image but it does auto focus when pressing the shutter button down. I someone knows a setting to check please let me know since I am unable to find it. thanks....
Anonymous
Level 2:
Sergeant:
  • Expert 246 Answers
  • Posted on Jun 04, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
246
Questions
0
Helped
102564
Points
760
You need to replace the control assembly, see the solution here:;
http://www.fixya.com/support/t1811939-shutter_button_popped_off_am_out
I have a Sony H5 camera. I just notice that if I go to take a picture I press the button, the green light flashers and then it snaps it with pressing all the way down
Greetings - That's how the camera was designed to work. Pressing the shutter half way down makes the camera auto focus. When it's in focus it turns solid green and you then press the shutter all the way down.
I suggest you read the getting started guide that comes with your camera or on line HERE.
Enjoy your camera and thanks for using Fix Ya
Mikeywaf
I have a Sony DSC-W50 Cybershot camera that won't take pictures or videos anymore. It powers up fine and the screen works, but when I hold down the shutter button all the way, it focuses and nothing more.
I have a Sony DSC-W50 Cybershot camera that won\'t take pictures or videos anymore. It powers up fine and the screen works, but when I hold down the shutter button all the way, it focuses and nothing displayed
I have a Sony Cyber shot DSC-H2. When the shutter button is depressed halfway, it does not focus as it should do. Is there a simple solution to this?
The Sony DSC-H2 and DSC-H5 have a terrible shutter button design and the tiny little "bubble" that is responsible for the "half press focus" can be easily damaged.
If you do a Google search for "Sony shutter button repair" you will see the #1, 2 and 3 links are all for www darntoothysam com. We have done hundreds of this repair over the years!
The repair service is just $70 total IF we can repair it without replacing the part, installation and return shipping of the camera. Please visit our site, we would be happy to service your camera.
Hope this helps!
Thomas D.
Owner, Darntoothysam.com
Affordable Digital Camera Repair
Sony cybershot DSC-H5 shutter button is not working
The shutter button can't be turned off. What are your symptoms so we can help you.
1helpful
3answers
I have a Sony DSC-H5 and the shutter button does not allow me to push it half way -- only all-the-way -- the macro won't focus.
It is a common problem on this model. You need to replace the control assembly to fix the problem. Here is a link to show you how to replace the assembly and where to get the part.
How to replace the shutter button on SONY CyberShot DSC-H5 digital camera
1helpful
Shutter speed very slow and has trouble focusing. When I press the the shutter button it takes several seconds before it takes a picture if at all. It seems as though it is having trouble focusing and when...
There is a diaphragm between the shutter button and the shutter switch that causes the camera to focus before the shutter is pressed all the way down. It is likely that the diaphragm is punctured and needs to be replaced. There is also a small possibility that the hidden secondary battery inside the camera is going bad.
2answers
Shutter button popped off & I am out of warrenty.
You can replace it DIY. Here is a link show you how to replace the button and where you can get the parts.
FMA. Need to ask u something about the Sony h5.....
Are you sure you did not activate "Manual Focus"?
Near the shutter button, there's a "Focus" button. maybe you pressed it accidentally and now you're in "Manual Focus" mode.
If so, press it once more to get "Multipoint" mode back to life...
And read the camera manual. It's a goot place to look for this kind of answers.
9helpful
3answers
DSC H5 - shutter button problem
Here is a $2 fix to this problem.
It just takes some electrical tape, a small piece of manila paper or similar and one thumbtack.
After the silver shutter button fell off, I tried a thumbtack and found that it did a good job of doing the pre-focus and capturing of the image. I then took a piece of black electrical tape about 3 inches long and in the middle, pasted on a small circle of construction paper or manila folder type of paper slightly bigger than the head of the thumbtack. This piece of cardboard will lie on top of the thumbtack head. This prevents the electrical tape from sticking directly to the thumbtack so that the thumbtack is free to move up and down (and trapped in position) without being stuck to the tape. I then put the electrical tape in position so that the thumbtack is held with its pin stuck into the shutter button.
Works well and doesn't look that bad either since the black tape blends into the body and the thumbtack is not visible.
4answers
Pre-focus
The switch block can be defective as other functons are doing well. for assitance see the links else where and we can help you.
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
