Question about Compaq Presario Notebook
My battery is not working properly... sometimes it stops charging... and suddenly it starts.. pl;z help me whats the actual problem..its only 6 monthsof time i have bought my notebook
  • Tyson Strickland
    Tyson Strickland May 11, 2010
    If you move the charing cable where its connected to the computer does it stop or start charging as you move it?
  • 51 Answers
I think that's the battery problem. You should send it to your service center, because there's nothing you can do with battery error.
another possibility is the battery is not tight enough.
Posted on May 14, 2009
Acer Aspire 4830T laptop battery behaving vaguely
Do you still have the old battery. If so charge it, and see if it charges properly. If so then you have a bad battery.
Mar 18, 2017 | Acer Aspire Timeline X 4830T 14 Inch...
1996 nissan pickup battery wont stay charged and alternator and battery are new. what could the problem be?
The battery is really just for providing power when the vehicle isn't running, and providing power needed for the starter to start the engine. The rest of the time the alternator is charging the battery and providing the power for the vehicle. You may have a short somewhere that is draining the battery when the vehicle is sitting and not running. If the vehicle does not run long after charging the battery, then there's a problem with the alternator. You can actually run the car without the battery, provided the engine is running and the alternator is working properly.
Jan 14, 2013 | 1996 Pickup Short Bed Xe Egr Valve Vacuum...
My volvo s60 wont turn over but theres power in the battrie
Anything less than 12.6 volts, at the battery---is a battery that needs to be charged
Not going above 12.4 when the engine is running ---would indicate
your alternator isn't working,is that what you were told
Jun 08, 2012 | Volvo S60 Cars & Trucks
R60 When laptop power is off battery is taking charge properly. But when power on and boot the laptop then LED blink of battery is proper green but battery not taking charge. Pl. note battery and charger...
Check what battery profile you're using by clicking the battery. See if one of the more conservative profiles will let the battery charge.
Make sure all your drivers are up to date using Windows Update. Some power problems can be fixed this way.
Jul 15, 2011 | Computers & Internet
The battery does not charge, its a new battery.what do i look for?
if its a new battery it could be as simple as it wasn't charged when you purchased it, If it was charged and your mower isn't charging it, the power source to the battery from the mowers motor isn't working properly,, not knowing if its a 12 or 6 volt system you need to check the battery ,, see which one it is,, using a multimetter ( if its 12v ) check the battery after you charge it with an outside source ( battery charger) you would have a reading of 12-12.5 volts on a normal check,, then start the mower, and check the battery as its running,, you should get a reading of 13-13.5 volts minimum, if your not, the alternator or magneto isn't working properly, if you do show the increased voltage at the battery connections, then you need to clean the contacts since the charge isn't reaching the actual battery
May 24, 2011 | Garden
Norelco SmartTouch-XL razor, stopped working won't charge
It is doubtful that the battery is bad because they dont normally go bad suddenly. Usually, they will degrade slowly and hold a charge less and less before they stop working.
It sounds like you may have a loose connection somewhere. Check the leads from the circuit board to the moto and also the tabs that connect the battery to the circuit board. These sometimes break.
May 03, 2010 | Health & Beauty
I have a 03 chevy 2500HD the amps and rpms go down when putting drive and reverse and pulling out from a stop. Battery went bad changed it now this problem started thanks a little puzzled
First, make certain that the battery you replaced is fully charged and that cable connectors are clean and wires are in good condition. Sometimes after sitting on a shelf , they aren't fully charged when you buy them. Your alternator can never charge the battery, it's designed to maintain the state of charge. You may be used to seeing readings that reflect your charging systems efforts to keep a failing battery charged. Those readings are not normal.
Your charging rate does change with engine rpm's up to a point...then the regulator takes over. Rpm's generally do drop a bit when in gear, and obviously change when accelerating from a stop. All your instruments are actually volt meters with different scales on them all rely upon actual line voltage to operate and though this is not as noticable as at a volt meter or amp meter, there subtle changes in all readings. Providing that you are getting proper voltage at the battery (generally 13.5-14.0 volts at the battery with engine running with accessories on) I would not worry about it. You can get your charging system tested at most larger parts stores free.
This isn't a fix, but rather an explanation as to what you may be seeing. If within normal range it's OK.
Jul 31, 2009 | 2004 Chevrolet Silverado 2500HD
ZZR400 turning but not firing
hi m8,,b4 i can assume anything else,just a couple test u need to try out,, make sure fuel is getting in carbs ,,just undo carb drain screw and check fuel is in the carbs ,, just to iliminate 1 thing,, then pull off one plug cap at a time take the plug cap off the ht wire of the coil, and snip a bit off the end ,, so u can see a strand or to of copper or brass wire in the core off the ht wire,, then screw the cap back on, repeat the process to all the other 3 plug caps,, while u r there make sure the coloured wires to the coil arnt pulled off or corroded,,cheers
Jan 24, 2009 | 1997 kawasaki ZZR 400
Compaq Presario Notebook Logo
26 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
