Question about Canon FAX L-120 Plain Paper Laser
Caution check scan platform
This is the message which is constantly appearing on the lcd screen
  • ntobeko zikhali Mar 26, 2009
    caution check scan platform"
SCAN PLATFORM LOCATED UNDERNEATH NAER PAPER TRAY HAS DROPPED DOWN NEEDS CLIPPING BACK INTO POSITION.
Posted on Jan 21, 2008
You need to check the scanning platform that is above the paper tray. it may be loose. you will have to close it properly and hopefully it will start working.
regards,
kumar
Posted on Nov 15, 2007
SOURCE:
Running Epson Scan Setup it says "Could not find files ..." Why?
Hello maybe your current driver is vrong or corrupted.
You can download the right driver from here:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=88368&prodoid=63070478&infoType=Downloads&platform=All
But you have to select your windows system 32 or 64 bit
to make the scanner working.
Uninstall the old driver before you install the new.
Good luck
Jan 01, 2013 | Epson Perfection V500 Flatbed Scanner
Canon L120 - What does this error message mean?
Check Scan Platform, means:
The scanning platform is dirty, or not set into scanning position.
Solution
Clean the scanning area, or lift the scanning platform into place.
Nov 26, 2011 | Canon L120 Fax Laser Printer
I want to enlarge the font on my htc mozart phone. Is this possible? I also want the message tone to reoccur so I know that I have a message if the phone is not with me initially. Can I set this up to...
Hello
Unfortunately SMS text size can't be modified at this time but they however use big characters at the top of the screen to show you where you are. Almost everywhere through the OS, the characters are so very different to other mobile platforms. When reading emails or reading through the browser, you can always pinch and zoom,
Jun 09, 2011 | Cell Phones
Printer does not print and 2 messages appear: 1)
Enabling bidirectional support Windows 7 / 2000 / XP / Vista:
Access the Printer Properties:
For Windows 7
  • Click the 'Start' button from the bottom left of the Windows screen, and then click on 'Devices and Printers'.
  • Click your right mouse button on the listing for your printer, and then select 'Printer properties' from the menu that appears.
For Windows Vista
  • Click / Select the 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, click 'Printers' directly from the 'Control Panel'.
For Windows XP Home Edition
  • Click / Select the 'Start' button from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
  • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
For Windows XP Professional Edition
  • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
For Windows 2000
  • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
In the printer's Properties window, select 'Ports', then 'Enable bidirectional support'
SECOND QUESTION:
ERROR LCD: The type of print head is incorrect. Insert the correct print head
Solution: Reseating the MP500 / MP800 print head
Reseating the Print Head Reseat the print head to correct print issues or clear an error. Reseat the Print Head:
  1. Confirm that the printer is powered on and press the button. (The paper output tray will open.).
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Remove the ink tanks by pressing the tab of each tank.
    Caution: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. Make sure to remove the ink tanks one by one.
  5. Raise the print head lock lever.
  6. Tilt the print head slightly towards the front of the machine and lift out gently.
    Caution: Do not touch the print head nozzles , electrical contacts , or ink supply ports . Doing so may cause printing problems.
  7. Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
  8. Insert ink tanks into the print head.
  9. Press the mark on the ink tank firmly until you hear a click.
  10. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    The ink tanks are installed properly.
    The ink tanks are not installed properly.
    Note: Click for Ink Tank Lamp indications.
  11. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
You can check the status of each ink tank according to the way its lamp flashes.
  • On: The printer is ready to print.
  • Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
  • Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
  • Off: An error has occurred and the printer is not ready to print.
I trust this is helpful. Please express appreciation.
Dec 10, 2010 | Canon Pixma MP800 All-In-One InkJet...
I get a message on the screen that says, "recording disabled." How do I fix this? I have a Sony Handycam DVD/RW Wide LCD
This message appears when mini dvd disc got some error in recording tracks, if its rewritable mini disc then format it as option is available in camera settings menu and if disc is once writable then use another disc as it can not be formatted.
Caution: Format will erase/ delete all files on dvd disc and refresh the dvd disc.
Jul 25, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
Hi, In my Pioneer Avh-P3100Dvd' s screens appear
hi boss my nokia 3230 do restsrt & hanging problam
Mar 01, 2010 | Pioneer AVIC-D3 Car DVD Player
Canon Fax-L120/L100
Check the manual for how to clean the scan platform (glass).
Jul 02, 2008 | Canon L120 Fax Laser Printer
Coulnd't send a fax
I had the same problem and called canon helpline.
They said to unplug the machine from the mains, then take out the plastic guard where the paper tray is fitted. There is a lever just above the paper tray. Make sure that it is pressed up completely. Then reconnect to mains.
I tried it and it worked.
Dec 27, 2007 | Canon FAX-L1000 Plain Paper Laser
When I turn on the printer "Download Mode" appears on the lcd screen.
The machine might be trying to download the latest firmware wait a few minutes it may go if not it is it the user manual under on screen messages.
Thanks J
Sep 13, 2007 | Sharp AL-1661CS All-In-One Laser Printer
Canon FAX L-120 Plain Paper Laser Logo
3,084 people viewed this question
Clive
Clive
old marine
old marine
