Question about Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Im on the tv, the screen shut down few minitues.
The stand by indicator flicker on eight times
  • 55 Answers
It sounds like the tv went out and needs to be repaired. Common causes are a bad power supply, circuit board, or power control board.
Posted on May 14, 2009
TV turns red,shuts off, stand-by light blinking 8Times
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Feb 27, 2014 | Sony KP-51HW40 51" Rear Projection...
My sony bravia had two thirds of right side was very dark it used to fix itself in about twenty minutes. I replaced the t-con board no change. Than i removed one of the four connectors to screen but left...
would say that the screen lights have gone. usually they flicker for a while then come on. then off etc. more than half the screen has gone so the power from the inverter is not being used so it turns off the tv. it is a very fiddly job replacing them as you can damage the screen in the process. more easyer just to get a new screen.
Oct 02, 2013 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
Screen Flicker then tv shuts off
please re solder  first all parts specially in hot area, and observe if problem still occur, then next is replace filter capacitor. observe also too hot parts and check for change value resistor.
Feb 25, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
Cannot connect acer extensa 5220 laptop to hd tv via aga
Hold down Fn and tap F5, you may have to tap F5 a couple of times to get it to switch screens.
Regards.
Feb 19, 2010 | Acer Computers & Internet
Booting problem in acer 4520
*********** board needs to be replaced
Dec 08, 2008 | Computers & Internet
Green screen and shut down
TV screen flashes with Red lights for few times. sometime it shut down TV or red color is lost showing pictures without Red looks terrible. Any solution
Sep 17, 2008 | Sony KP-51HW40 51" Rear Projection...
KP-51HW40 - Auto shut down problem
I had the same problem. i was told by one of these so-called experts @ fixya that my flyback transformer needed to be replaced (the 8 blinks on the standby was the indicator). but i recently replaced it and im having the same problem. sorry. no advice. good luck.
Jun 18, 2008 | Sony KP-51HW40 51" Rear Projection...
RCA D52W20 52" TV SHUTS DOWN AFTER A FEW MINUTES
this is the filment circuit having a problem. i think you will find it is a loose connection on a solder joint. Goodluck
Jan 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV Flikers and StandBy Light Flickers
Your pdp panel sounds faulty - Count the red flashes this is an error code.
Nov 13, 2007 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Tv doesnt complete power on, shuts itself down 3 times
the 3 start attempts in the tv indicate a horizontal shut down fault. if you have repair knowledg, the most likely thing is the capacitors in the horizontal circuit, check those. then check diodes. if the tv still does not work then you have a bad high viltage transformer or a bad hight voltage splitter. further testing becoms dangerous to do at home due to the high voltage. if the caps are bad the typically run around $4- 12 each, h.v. parts $75 to $125. each + you local shop rates. good luck.
Jan 03, 2007 | GE D52GW12 52" Rear Projection HDTV-Ready...
Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV Logo
218 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
