Question about Toro Lawn Mower With Toro Power Tools
Mower will not stay running
I have a Toro 20016. It will start but immediately stops running. How can I repair
  • 1 more comment
  • Anonymous May 15, 2009
    My Toro starts, too, and then stops in a few seconds. I cleaned the air filter and it didn't help. I checked the hose from the gas tank to the carb and did not find any leaks. The dealer is so busy it would be 4 weeks before he could get to it. So --------
  • phincj May 17, 2009
    starts, but only runs a few seconds. removed carb, thoroughly cleaned carb. and bowl nut, put carb back on. looks as though it is fixed jet briggs & stratton. reassembled and same problem. sprayed chem tool into carb opening, starts and runs for a few seconds. should I just go ahead and replace the carb???
  • Becky Hood-Hensley
    Becky Hood-Hensley May 19, 2009
    my toro 20016 is doing the same thing. been looking for a new fuel filter. can't find one. does this lawn mower even have a fuel filter?
I had the same problem. I took off the carb bowl and found debris in there. Be sure to drain the gas out of mower first. I cleaned the carb and surrounding area w/ carb cleaner. Make sure the nut on the bottom has its holes cleaned out. I also replaced the washer on the bottom. While I was at it, I changed the spark plug and oil. It runs like new now.
Posted on Jun 05, 2010
  • 41 Answers
You have a problem in the fuel system. First start by checking fuel lines,filter,vacum fuel pump.If this checks out,remove carb. and clean. Check for water and trash in bowl of carb. or tank. This sould solve your problem.
Posted on May 14, 2009
Mower strarts are runs if I prime pump it then stops like its out of gas.
check the bulb for a pin hole leak it is sucking air. the check diafram in carb.
Jul 16, 2014 | Toro Garden
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
How to change the drive belt on a Toro 20016 SP Mower
The Toro 20016 mower is a front wheel drive mower and fairly simple to change the belt on. Start by disconnecting the spark plug to prevent start ups while working on the machine.
Remove the blade and adapter. The adapter includes the pulley for the belt.
two screws under the mower, with 3/8 heads hold the black cover over the belt. remove the cover and now you will see the transmission
The transmission, depending on the year of your machine will have a guard holding the belt on. Bend or remove the guard to remove the belt. Install you belt in reverse order.
You can get parts and special tools like the blade stop at a store like www.arcolawn.com
Feb 23, 2011 | Toro Lawnmower Lawn Mower Sp Drive Belt...
After priming starts, runs and stops
If you over fill the oil your mower will not start until you remove excess oil. This should be checked first, This is a much easier fix.
Jun 20, 2010 | Toro Garden
Mower wont start
You will need to replace an aluminum "key" in the flywheel. Whenever you hit something, the key is designed to shear so you don't break something major.
Sep 02, 2009 | Toro Lawn Mower With Toro Power Tools
Toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
May 30, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 20016 engine surges up and down - then stalls
You have carburetor problems. Chances are the diaphragm needs to be changed and the carb. needs a good cleaning. If you need tips on carb. cleaning, let me know.
Jim
May 28, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
1,391 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
