Question about Danby DWC283BLS Wine Cooler
I have a Danby Wine Cooler model#dwc283bls-1. This is a 2 temp. zone cooler. The top is cooling properly and the bottom is not but both fans are working. What can I do?
5 Suggested Answers
  • 27 Answers
SOURCE: wine cooler
cheak the machine main on/off switch, cheak the in$out phase line
Posted on Jun 21, 2008
SOURCE: E4 Code
Between phone calls to danby and my neighbor, we fixed this problem. My E4 was on the left (lower chamber). If you have one on the right it is the upper chamber. The E4 is a defrost sensor that can be ordered from Danby's distributor (call Danby for the one in your area). The part and shipping were around $30.
If your E4 is on the left...
- remove the top shelves
- open the cover inside the cooler above the digital read outs (the top unscrews)
- inside is were the repacement sensor plugs in
- replace the one with the long cord
- run the sensor down the back to the lower chamber
- replace all covers and parts
If the E4 is on the right...
- look on the right hand wall for a black plastic grate, the sensor is under this grate
- replace the sensor (simple plug and play)
- replace the racks.
Please pass this on, it was a ***** to deal with Danby and I nearly trashed the cooler out of sheer frustration.
Posted on Jan 01, 2009
  • 1151 Answers
SOURCE: we have a danby dwc283bls wine cooler that no
that's always a possibility but not always the case. The thermostat may not be cycling correctly or set wrong. The condenser could be dirty or if there is a fan, it may not be running. Freeze ups can also cause an "Out of temp." condition. Check it out.
Posted on Apr 15, 2010
  • 1739 Answers
SOURCE: danby wine cooler not cooling
This product is now retired however was able to locate your manual here:
http://www.danby.ca/cms/uploads/products/en_manual/DWC283BLS_%28web%29.pdf
Verify you have power to the unit?
Have you provided proper spacing of 5" between the unit and any adjacent wall? Note these are free- standing units and are not meant to be built in.
Make sure it is not located adjacent a heat source or in direct sunlight.
Check to make sure you have set the temperature controls correctly. See page 4 of the manual. Note if the power is interrupted your settings are erased and the cooler will default to the preset temperatures.
if you have power and the temperature settigns are correct ther eis likely an issue with the compressor and it may need to be serviced.
To find your nearest service dealer go to the following site:
http://www.danby.com/language_sel.php?ref=%2Flocator.php%3Ftype%3Dservice
Select your county and then click on Service in the horizontal menu bar.
Posted on Jun 05, 2011
F230073 p c card
try there http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC283BLS/3055/0169000/50031952/00001?blt=06&prst=0&shdMod=DWC283BLS
Dec 16, 2013 | Danby DWC283BLS Wine Cooler
Need parts diagram for dwc283bls-1
http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC283BLS/3055/0169000?pathTaken=&prst=0&shdMod=DWC283BLS
Dec 25, 2012 | Danby DWC283BLS Wine Cooler
Hot on the sides and in the back in the bottom,
Your coils are built into sides and top of cooler. Allowing unit to cool, by disipating heat.
Oct 15, 2010 | Danby DWC283BLS Wine Cooler
We have a danby dwc283bls wine cooler that no longer cools, and the compressor gets warm (above normal) does it need to be recharged
Apr 15, 2010 | Danby DWC283BLS Wine Cooler
Top evaporator fan not working and compressor hot , not cooling below 79 degrees
the top fan is not suppose to run all thetime only when its too cold and the heater kicks then the top fan will come on,you probley have a leak in the system
Nov 10, 2009 | Danby DWC283BLS Wine Cooler
Compressor runs and gets hot but does not cool unit
This product has been discontinued
i dont think many danby units are parts supported
more likely generic after market parts fitted by air con mechanics do the job
relay first might be a thematic one and an compressor motor fan relay
then check gas pressure
https://www.winecoolerdirect.com/danby-wine-cooler-dual-zone-dwc283bls/DWC283BLS.html
Service Manual.pdfwww.reliablepartsinc.com/danby/Manuals%20.../Service%20Manuals/DWC282%20%...
Mar 06, 2017 | Danby DWC283BLS Wine Cooler
Danby Wine cooler runs and runs
not hard to replace but you are correct if it is not cycling off at the temp you want it to then the temp control is the problem
Apr 12, 2008 | Danby DWC283BLS Wine Cooler
Danby DWC283BLS Wine Cooler Logo
630 people viewed this question
Top Danby Furniture Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Dennis Boxerman
Are you a Danby Furniture Expert? Answer questions, earn points and help others
