Question about Mastercool 67471 Evaporative Cooler Air Conditioner
Motor sometimes will run and sometimes not
I put a new motor on my master cool. the low speed make a lot of nosie like is is trying to stop and go. sometimes the cooler will not start up.
the new motor said I may have to ajust the pully to make it run I turned the pullyout one full turn. It ran good for about 5 day now it will not start again all the lights come on on the thermastat but cooler will not come on.
  • 14 Answers
Sounds like the high and low speeds are trying to run at the same time are you sure you put the wires on the new motor on the same terminals
Posted on Jun 03, 2009
    Problem Solver:
  • 11 Answers
If the motor is still turning, good. It is not burned out. IF the motor is not turning with the unit on, it is either a reset switch (not all units have them) or the motor is burned out. New motors need to have the pulley adjusted so it is not too tight or not too loose.
Posted on May 31, 2009
How do I fix cooling fans that run when car is off
Replace the fan relays. The Radiator Cooling Fan Motor Relay is located: Under hood, driver side, front side of strut tower, mounted in relay panel
Application:
High speed The Radiator Cooling Fan Motor Relay is located: Under hood, driver side, front side of strut tower, mounted in relay panel
Application:
Low speed,here's a new part.
http://www.autozone.com/cooling-heating-and-climate-control/relay-radiator-cooling-fan-motor/duralast-relay-radiator-cooling-fan-motor/plymouth/voyager-2wd/1996/6-cylinders-3-3-0l-mfi/412240_0_0
Sep 22, 2015 | 1996 Plymouth Voyager
Remove c-24 errorminolta di450/500
Sir/Mam,
C0F24 Code is the code for the sensor that monitors the drum. I would remove the drum cartridge two black screws pull out the drum assy. Remove the drum be careful do not nick or harm the drum the sensor is located on the left side of the to the rear of the of the drum looks like to little eye of a bug. Dust with a brush NO VACUUM static could destroy it. Re-install drum and re-install cartridge. When the last time a PM was done Developer replaced and Drum replaced?
Dec 14, 2014 | Minolta Office Equipment & Supplies
Furnace transformer/fan-relay wiring to fan-motor
All you need is 2 fan speeds, 1 for cool and 1 for heat. Leave the low speed disconnected. Normally we have high speed for cooling, and med. or low for heat. So either speed connected to the heating circuit is fine.
Apr 12, 2017 | Heating & Cooling
Motor does not go from low speed to high speed If the motor is set to low speed it does not turn on until the high speed range is hit then it tries to go from stop to high speed and throws thw belt
MOST OF THE TIME IT IS THE DIGITAL THERMOSTAT OR LOOSE TERMINAL AT THERM. THESE STATS ARE TRICKY TO CHECK. LIKE WHITE ROGERS 4 WIRES CONTROL WITH A RED WIRE TO GREEN YOU GET PUMP WHITE YOU GET LOW YELLOW YOU GET HIGH AND SO FORTH. MASTER COOL DOES IT DIFFERENT SO YOU BUY THEIR TSTAT
Apr 21, 2010 | Mastercool 67680 Evaporative Cooler Air...
The motor stops while you are using it and the stand by lights up
you are over heating the motor ...that is caused by low airflow ... make sure the bag is not full, hoses not clogged and secondary filters (sometimes on the output side) are not clogged ... make sure there is lots of air going thru the motor .. the motor cant run long without air to cool it ... it has a thermal switch that trips when it gets too hot .. the thermal switch resets itself when the motor has cooled ...
Aug 05, 2009 | Electrolux Vacuums
My fan also has quit the assembly is new so i
Use a known working relay of the same type and turn on your a/c on high, then put in the relay where the old high speed fan relay was. If it comes on, it's the relay. Try this on low speed as well. If they don't come on when the A/C is on, it could be your pcm/ecu as well. If it doesn't communicate with the sensor, it won't turn on. Check with A/C running to narrow it down. If they work here, look into the engine coolant temperature sensor.
Jul 17, 2009 | 1999 Chrysler 300M
High cool not working
Compressors on these units runs at only one speed. The change to high cool is only a change in blower speed moving air faster over the cooling coil. I would have the running capacitor for the fan motor checked. A bad capacitor can cause your type of problem. The other problem could be that the high speed winding in the fan motor is bad. Try it operation in the fan only position through the two speeds. If it works in the low and high speed for fan only your problem could be in the selector switch.
Jun 23, 2008 | Dometic Rooftop RV Air Conditioner
Ruud heat pump outside fan
You may be right in looking at the motor. It uses a different speed on heat than cool. The heat cycle uses low speed, usually red. Some manufactures use blue (medium). Cool uses black, high speed. If you are confident, switch the low speed wire with the high speed and see if this changes anything. If the fan motor isn't the problem, check the other setting (cool) if the overload trips, you may need to look into a new capacitor or compressor, if so, you can install a hard start kit. these are start boosters, and are inexpensice, sometimes they will give another year out of the comp. but I've put them on and they have lasted 5 years.
Mar 15, 2008 | Heating & Cooling
Mastercool 67471 Evaporative Cooler Air Conditioner Logo
367 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
Boyet Soriano
Boyet Soriano
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
