I have a mf8080cw. feeder takes in pages, flatbed scans pages. But the scans and copies both come out blank. new drivers installed straight from canon site, even did the firmware update. I'm stuck .. any ideas whats wrong with this thing?
These problems occurs when the scanner is unable to take a copy of the image that you are trying to scan.You can go to settings and run a scanner motor test on the scanner.Just check out the results of the scanner motor test.If the scanner motor test results are positive,then please clen the scanner bed with a cotton cloth and then perform a power drain on the printer.
Now in order to perform a power drain you need to keep the printr powered on n unplug the power cable from the back of the printer.And then press the power button down for 30-50 secs n then release it.Then plug in the power cable n turn on the printer. The scaner will respond. But if the scanner motor test results are negative, then the scanner needs to be fixed by a hardware technician
SOURCE: Canon ir3200 not scanning
C-
The problem is the password. Someone that is attached to the printer - their password has changed but it was not changed in the computer.
SOURCE: Does the tray feeder provide scanning several docs in one shot, or is it only for copying?
only for copying
SOURCE: Blank pages from Canon MX850 scanner
Try Removing the printhead of your printer and putit back, and do the clean nozzles and printhead alignment.
SOURCE: My canon ir3300i is taking
Hi
Corrupted printer driver is the problem, try to uninstall the printer driver and then reinstall it back. Then re add the printer in the add printer wizard.
Another is try to restart your computer and your printer. Regards
SOURCE: pixma300 when copying have blank down right side of document 6cm missing
Remove the toner...
Shake it gently...
Place it back and check if it works...
If the problem exists still , then its time to replace the Toner, because it is something associated with the DRUM of the toner...
