Question about Motorola Mobility RAZR V3
Phone displays is not working.
My display goes black and I can still use the phone except I can't see anything.  I popped the battery out and then back in and it came back on for about 20 seconds.
  • 425 Answers
most common problem is lost contact in you flex connector or defective flex connector. try opening your phone and check the connection.
if everything if fine, then your LCD must be defective. have it replace and im sure your prob is solved.
Posted on Oct 16, 2007
Batteries and phone very hot
There is a short in the phone that causes a high rate of battery discharge resulting in a overheating battery.
This cell phone is faulty and I suggest you get a new cell phone.
May 21, 2013 | Nokia 5130 Cell Phones
My phone is on and works fine, all except the screen is black and I can't see anything. This is no water damage
Hi, it's not a water problem,but a flex because there is a flex inside that connected to the screen of the phone that makes the phone display is faulty and it needs to be replaced so that the screen can display.
When you replace the flex, problem solved.
Take care.
Oct 18, 2010 | Motorola Mobility Rival A455 Cell Phone
HTC herm200 phone not working properly.. :(
its just the display problem u can just replace the display and it will be done!
Jul 15, 2010 | HTC Cell Phones
When I plug my charger in there are no bars going up and down on the display showing that it is charging. This is after I accidently plugged in the wrong charger and heard a pop. The phone shut off after...
I would suggest just using the phone until you wear the battery down and then put it back on the charger and charge it up over night and see if it charges. If that works then probably the pop you heard was the part of the display that shows the bars going up blowing out but at least the phone will work for you.
Dec 25, 2009 | Cell Phones
My phone is a samsung u700. its screen is blank and its not displaying anything. backlight on . what could the problem be.only light from the
first remove the battery just 5minites .................then display is out try change dis play .......
May 30, 2009 | Samsung Cell Phones
Phone screen goes blank to a grey color (externallY) .
same problem, broke my screen, ordered a new screen off ebay and replaced it. now it works fine most of the time but sometimes external display freezes. sometimes goes black, sometimes goes multicolor pixelated (full screen, in blocks, or lines) when this happens sometimes touchpad still works, others not. removing battery usualy temporarily fixes.
Mar 09, 2009 | LG VOYAGER VX10000 Cellular Phone
New phone won't turn on just has "Hellomoto" screen
hi.there...don't worry.. what happens with your new normal..why? when your battery is low and there a pop up screen at the display "battery low...please recharge" that's mean you must charge the battery soon.
when connect your phone to charger adapter and your battery is very low / weak condition the display only showing "hellomotto" and nothing else. but it's normal! diplay need more power from you battery to showing all information.after the battery reach the minimum power to display it ( usually after 15-20' charging) try to push red bottom at your keypad phone and the display will showing again..good luck..
Feb 02, 2009 | Motorola Mobility RAZR V3
Iphone screen beoken, black liquid showing; phone stops working
hello basicly the the liquid is the lcd that lays between the screen that gives you the display if this fluid escapes it will no longer display properly and as it leaks more display will be lost ,to solve you will need to replace the screen
Jan 18, 2009 | Apple iPhone Smartphone
No display
we have to give it to maintant and tell them about how does it work.
Sep 07, 2008 | Nokia 6300 Cellular Phone
Static electricity
I had the same problem when I answered my cordless phone static charge went thru me and into my phone and I had now display, so i changed the batteries in the handset and it worked. So I hope this works for you.
Feb 29, 2008 | Uniden DCT646-2 Cordless Phone
Motorola Mobility RAZR V3 Logo
43 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
