Question about Computer Monitors
    Problem Solver:
  • 12 Answers
If you have a digital monitor, press the menu button on the front of it and adjust H size and centering.  Failing this, try changing your refresh rate in Display settings>>Settings>>Advanced.  Failing have a bad power supply in your monitor.
Posted on Oct 15, 2007
0 characters
3 Points
My Dell E2209WC have black horizontal bands/lines all over the screen.
if the lines are like blinking and appearing and vanishing, then try adjusting the cable attached to your monitor or buy a new cable that is attached between monitor and system unit.
Feb 22, 2011 | Dell 2209WA 22 inch Monitor
A 1/2
there are 2 possibilities 1. you have changed screen resolution by accident, try using that [right click desktop and properties, look in tabs there] or 2. your screen is old and it has "burned out" in some parts
Oct 14, 2009 | Relisys Intro TE988 19" CRT Monitor
Laptop monitor has a 2 inch black band along ride
Either the video driver is corrupt on your comp, The monitor is broken, or your motherboard is broken
Sep 04, 2009 | Dell Computer Monitors
Blank part on my monitor
This sounds like a claim. Give it back to your seller.
May 28, 2009 | Hannspree HANNS·G HC174DP 17 inch LCD...
Apple 30 inch monitor
No, this is not normal. This could be one of two problems. 1) internal connection to the "Y" array is somehow been compromised either through some defect in manufacturing or simply a loose connection. 2) The LCD converter board in the monitor is defective. In either case it's internal to the monitor and would have to be serviced. Have you checked with HP to see if the device is still under warranty? It just might be If not, you can try opening the unit and checking the connection on the left hand side towards the area you mentioned. But beware that the monitor does contain leatal voltages.
Nov 20, 2007 | HP vs15 15"LCD Flat Panel Monitor
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computer Monitors
2 inch black on both sides of the monitor (Horizontal)
1 it is due to horizntal output trnansistor. 2 capacitor connected to horz output. 3 flyback transformer. hope this will help you.
Oct 08, 2007 | Hansol (720ESB) (Black, Silver) 17 in.CRT...
Monitor has a bad sector
I suggest you tackle logic board.
Oct 04, 2007 | Acer AL1913 19" LCD Monitor
Screen Adjustment
On your monitor at the bottom there is 3 buttons. The one all the way to the left is the "menu" button. The next one (going right) is the "NEGATIVE" button. The next one (going right) is the "POSITIVE" button.
You can move your screen around. First, start by pressing the menu button.Then, a menu in blue, with a bunch of little white icons will appear. Next, go over two icons by pressing the positive button twice. Then, proceed to push in the "menu" button again. A bar will appear. By pressing your negative button, your screen will move left. Pressing your positive button will make your screen move right. Adjust your screen until the black on both sides are of even proportion. Then, press the menu button to return to the orginal menu you started at. Proceed to press your positive button two more times. Then, press your menu button. Then, once again, use your positive button, and your negative button to adjust your screen to even out the black on the top and bottom.
Dec 24, 2006 | HP Compaq FS 7550 17" CRT Monitor
Computer Monitors Logo
669 people viewed this question
Top Computer Monitors Experts
Brian Sullivan
Brian Sullivan
Are you a Computer Monitor Expert? Answer questions, earn points and help others
