Question about Proview PL926WBi 19" LCD Monitor
Proview PL926Wbi LCD Monitor White Screen
I have a Proview 19" widescreen PL926Wbi monitor.  I have had it a little over a year and I had noticed things going wrong as well.  It started out where when I was on the computer the screen would all of a sudden change colors, like sorta dim.  I would have to nudge the monitor to get it back and it would be fine.  Lately however, I have had some of the same problems the other guys had.  When I first turn my monitor on when I start my computer, my screen stays white.  After about 5 minutes or so, I would shut the monitor off and back on, it would come back up normal.
I read that one guy"Delphiuser" stated he changed the capacitors and had it up for about a day with no problem.  I wanted to know if it worked out.
  • 5 more comments
  • Anonymous Nov 03, 2007
    when you power offf the moniter or its sleeps the screen whites out and you have to unplug and rplug it several time before it works again.
    DCLCD 19" DCL9A+
  • Anonymous Nov 04, 2007
    Have the same problem with two Proview 15" LCD monitor/TV . Talked with Proview tech support that basically told me I'm out of warranty. Would love to fix these myself so I'm interested in the capacitor solution.
  • Anonymous Nov 05, 2007
    Same thing.
  • Anonymous Jan 10, 2008
    I'm having the same problem but now the screen flickers and makes a noise like a fluorescent light bulb trying to come on then the screen goes black. If I turn it off then back on, it continues to do the same thing.
  • Anonymous Jun 03, 2008
    I have a proview Pl926 as well and after one year my screen went black. I started doing research over the web, and found out that there were 100's of people with the same complaint. Stating the Proview is a rip off and there monitors go out after one year. Which is the amount of time of there warrantey. I called the company and they said they would charge me 100.00 to repair it plus shipping cost. I spoke with someone and they told me it probably was the back light and i should change it, I am going to try that first and see if it works. However, i will never order anything from Proview in the future. I brought a samsung and i am very happy with it. The picture is clear and they offer a three year warrenty on the monitor. Just wanted to share my experience with you. Take Care Dreana
  • Anonymous Jun 18, 2008
    moniter starts Out with white sceen the after about 1 hour It will work after turning off and back on.
  • anonybear Nov 24, 2008
    My PL926Wbi blacked out after one year, too. maybe backlight issue?
White screen when starts, eventually stays white always.
Fixed the problem by replacing 6 capacitors in the power supply. Made a web page with full instructions.
Posted on Sep 10, 2008
I found in the refuse, a Gateway FPD 1520, 15" LCD monitor that started off losing the screen half-way, losing sync, etc. The "mechanical agitation" method was applied and remedied the problem. Awhile ago, it went to a white screen (or, as it was back in the day- a clean raster). I opened it up and found that the ribbon cable on the left was loose. I applied a series of layers of adhesive-backed foam (the kind you stop drafts in your home with) until it was greater than the height of the metal enclosure to put pressure on the unbehaving connector. It does seem a bit loose and this will keep it snug. Maybe hot glue or other adhesive if it wiggles loose again. Seems to have solved the problem at the moment.
Posted on Aug 31, 2008
JUST FIXED MINE.. Replaced 3 dead Capacitors!!! Opened It up and saw the 3 dead Capacitors.. Went to Radio Shack picked up a soldering iron kit.. for 8 bucks and bought 5 Capacitors for a total of 16 bucks!!! 16 bucks.. damn who would have known.. SO CHEAP TO FIX IT YOURSELD .. I NEVER SOLDERED in my life.. AND IT WORKED FOR ME!!
Posted on Dec 28, 2007
ProView 19" Flat Screen Monitor comes on with
The dark or black picture is caused by a failure in the back light power supply. The problem can be corrected by replacing a few parts called capacitors on the board. Replacing them will require a little soldering but anyone can do it. Here is a link to a page that shows what needs to be replaced.
I hope this helps, if so please rate my solution.
Sep 17, 2011 | Proview PL926WBi 19" LCD Monitor
White screen comes on when powered on
**Caution. Hazardous voltages inside.
This could be a loose connector inside the monitor connecting the LCD panel. A careful check of these delicate connectors (open, reinsert the cable, close the connector) or remove and reconnect the plugs may fix it. White screen means there is no drive to the LCD panel AT ALL.
Mar 30, 2010 | Proview PL926WBi 19" LCD Monitor
Does my Proview PL926WBi 19
Any monitor will work with any computer provided the correct graphics card driver is installed. When you install Vista and you do not install the graphics driver, Windows will default to Generic VGA driver and you will not get the best resolution that the monitor can display.
Jan 29, 2010 | Proview PL926WBi 19" LCD Monitor
Pl926wbi 19"proview monitor,screen goes black every 3 seconds,
Bad capacitors on the pcb boards internally unsoldering ad replacement is indicated.
Feb 17, 2009 | Proview PL926WBi 19" LCD Monitor
ProView PL926WBi
bad capacitors on the board, replace these and the inverters should get there power.
Dec 01, 2008 | Proview PL926WBi 19" LCD Monitor
Proview monitor
If walmart really won't look at it you can send it back to Proview. They have a 1 year limited warranty.
Nov 04, 2008 | Proview PL926WBi 19" LCD Monitor
Proview 926w 32-bit vista Driver
May 21, 2008 | Proview PL926WBi 19" LCD Monitor
Sylvania (proview) cl2072b flat panel monitor
Well the first and second paragraphs make me say the Inverter/power board must be replaced.
A white display typically means either your display cable (in your monitor) is loose or logic board is dead.
Either one of these things typically mean take it in for an estimate to repair, and if it's too much, buy a new one.
With your luck I think I might switch to big cheap CRT.
Mar 12, 2008 | Proview PL926WBi 19" LCD Monitor
Blank screen with message "mode not supported"
How have you connected the monitor to the computer?
Is it through the vga or the dvi port?
Pls press the monitor menu button and change the mode to vga or dvi depending on the connection that you have now.
You might also get a vga to dvi adapter and connect the monitor to the computer.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
1,568 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
